LR upper control arms
Discussion in 'Suspension' started by lynyrd3, Aug 20, 2011.
  1. Aug 20, 2011 at 4:54 PM
    lynyrd3
    lynyrd3 [OP] STRENGTH DETERMINATION MERCILESS FOREVER
    Bill
    East Central Upstate NY
    Will installing LR UCAs give more room for bigger tire ? Have my Bilstiens set @ 1.75 . Running 265/70/16s now .
  2. Aug 20, 2011 at 4:58 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The function of the LR UCA's is to allow for a correct alignment after lifting the front 2 1/2" and above
    For 33" tires you will need to raise the billies to 2 1/2" and get wheel spacers if you plan to run 285's on stock OEM wheels .
    You can skip the spacers if you run a 255/80/17 or 255/85/16 but you still need at least 2 1/2" up front
  3. Aug 20, 2011 at 4:58 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    not really...they'll just correct any alignment issues you may have in the future if you decide to go with a bigger lift
  4. Aug 20, 2011 at 4:59 PM
    ColtsTRD
    Scott
    AZ
    beat me to it ;)
  5. Aug 20, 2011 at 5:11 PM
    lynyrd3
    Bill
    Thanks , I do have a little bit of drift in the steering when going over uneven road . UCAs very close to the back of the tire. Any thing I can do about that without change to a smaller tire ? Thanks
  6. Aug 20, 2011 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    You had an alignment after putting on the billies ?
  7. Aug 20, 2011 at 5:20 PM
    lynyrd3
    Bill
    Yup, no problems other than a little drift at highway speed on uneven surface.
    Rides and handles great other than that .
  8. Aug 20, 2011 at 5:23 PM
    OZ-T
    Peter North
    British Columbia
    If the UCA is not contacting the tire , what's the problem ?
  9. Aug 20, 2011 at 5:27 PM
    lynyrd3
    Bill
    Just thinking maybe getting a better alignment with LR UCAs . Just
    do not know if it is worth spending the money ?:confused:
