LS Swap in a 3rd Gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Huck89, Oct 18, 2022.
  1. Dec 1, 2022 at 6:51 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    An LS will be easier to swap than any of your suggestions (besides boosting the 3.5 which I agree with). It's physically smaller and has easy to use aftermarket plug and play stand alone controllers. The aftermarket is huge and it's plenty "advanced".
    There's a reason they're so popular. Have a feeling LS swaps will become popular on these trucks as they age. They're still too new and expensive now for most people to hack up.
    And I for sure want a 400-500 HP Tacoma. Just don't want to pay for it.
    TireFire and SFcoma like this.
  2. Dec 1, 2022 at 7:12 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Heh.. have you not seen the people adding 110 lb PER SIDE sliders, 185 lb bumpers and full undercarriage 3/16" steel armor?
  3. Dec 1, 2022 at 8:40 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    On power nation tv, extreme 4wheel drive recently did an ls swap in a tacoma. All looked factory when done.
    SFcoma likes this.
  4. Dec 1, 2022 at 3:00 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I figured all that was the reason for the LS.
  5. Dec 2, 2022 at 8:47 AM
    softacominustomato
    softacominustomato Member
    2002 tacoma prerunner extend cab
    zero
    I am also thinking a b58 with a zf8 speed…..
  6. Apr 2, 2023 at 7:40 AM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    I had a modified N54 in my 335xi which put out more than 450 HP/500+ ft/lbs at the wheels at 18 psi. I had to upgrade to my brakes b/c it was too scary to drive w/o it. I only felt comfortable driving it full throttle on an empty highway. It was too fast to enjoy on well traveled streets.
    Putting this HP/torque in a 6000 lb+ truck is less scary if driven correctly.
    I currently have OV Tune twin turbo kit installed and its been a nightmare. I believe there are only two of us out of about 15 TW members who remain with the TT installed. The tuning side of the TT kit has been the main issue (which ironically Mat from OVT claimed was his forte).
    The stock fuel pump can not support above 6-7 psi since there is discrepancy in fuel delivery to the pistons at the end of the fuel rails compared to the pistons at the beginning. Properly tuning the direct and indirect fuel injection system can compensate to a certain point but the solution is upgrading the fuel pump.
    However, the stock fuel pump is a PWM (pulse width modulation) pump but the stock FPC is designed to run the pump in a non-pwm way. This has created difficulty switching out to an aftermarket pump without modifying the stock FPC. Mat from OV Tune tried to overcome this problem with tuning but never was successful.
    Using the Lexus V35A-FTS fuel system may be a solution but doing the legwork costs money and time.
    Stew from Meso customs blew up his 2GR-FKS V6 and tried to install a turbo charged I6 (might have been b58) but abandoned this for a V8 swap. FYI there is a 3rd Gen tacoma that is using the twin turbo V6 from Cadillac CTS
    softacominustomato and Speedbird like this.
  7. Apr 12, 2023 at 2:29 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
  8. Jul 12, 2023 at 4:09 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I guess I might be the 3rd guy that still has a TT and haven’t had any issues. It actually runs great. Sorry you’ve had difficulty. No trouble with fuel delivery either (6-7psi, little snails) just nut and bolting all the time. That said, I’m on this thread because an LS3 swap would be awesome and eventually my motor will go. About half there at 100k.
  9. Jul 14, 2023 at 7:41 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
  10. Jul 14, 2023 at 8:14 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    6MTPro[QUOTED] likes this.
  11. Jul 14, 2023 at 8:32 AM
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    I get tempted every now and then but having my Tacoma dead nuts reliable and everything fuction as normal wins out. I bought a shit box to swap and have fun with. Taco stays on daily duty only gets minor mods.
    Wero94 likes this.
  12. Jul 14, 2023 at 8:36 AM
    6MTPro
    HI -> CA
    The diesel toys conversion is cool too but at 30k it's steep.
  13. Jul 14, 2023 at 8:50 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I liked it initially. I just didn't like the fact that he was swapping out the cluster and some controls for GM ones. But then again, I wasn't the one doing the build.
  14. Jul 14, 2023 at 8:53 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Damn, what !?! I thought he was asking $40K. I would have bought that for $30K. What a steal
  15. Jul 14, 2023 at 8:57 AM
    #35
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    @Drewthecarguy
    But the issue with selling a heavily modified vehicle is your market shrinks significantly. Modifications don’t add a ton a value, just make it harder to find the right buyer.
    Speedbird likes this.
  16. Jul 14, 2023 at 9:00 AM
    #36
    Gen3TacomaOBX
    S
    That's all a latest gen swapped v8 will fetch? Bummer, seems low for the investment.
    TireFire likes this.
  17. Jul 14, 2023 at 9:13 AM
    #37
    Hogleg918
    Oklahoma
    Motor is out of a 2012 Camaro, body had 180k miles on it. I don't think that is all that bad.
  18. Jul 14, 2023 at 5:42 PM
    #38
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Seems about as much (or less) then a stock 2016 would sell for.
  19. Jul 16, 2023 at 8:44 AM
    #39
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    Glad to hear you are still running the turbos since OV tuning has abandoned the TT kit project. I agree with LS swap
    Positive update on Powermax TT kit. I switched back to OEM fuel pump and pump controller & have been working with Ziggy (Marc) from
    Yota Werx Tuning on a tune. Now running great at 8 psi without misfires.
    Thanks to both Ziggy (Marc) for tuning help and JamesT (who provided upgraded fuel rail, upgraded turbo oil drain).
    I highly recommend Yota Werx Tuning for NA or FI applications (Maggy SC or TT) for Tacoma
    Wero94 likes this.
  20. Jan 5, 2024 at 12:21 AM
    #40
    Wero94
    Wero94 Well-Known Member
    2016 tacoma trd Sport double cab
    Those he makes TT kits too?
