LS UCA + 1.25
Discussion in 'Wheels & Tires' started by RiverBoyTRD, May 10, 2013.
  1. May 10, 2013 at 7:20 AM
    RiverBoyTRD
    RiverBoyTRD [OP] Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    I have the speed upper control arms and will be putting on 1.25 spacers with factory Trd wheels. how wide of a tire could I possibly go before control arm rubbage becomes a factor? 3/2 lift on right now
    Hoping a 305 wide will work, I will be cutting so that is a none issue
  2. May 10, 2013 at 4:06 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    evening bump
  3. May 10, 2013 at 4:21 PM
    eric3187
    eric3187 Well-Known Member
    i had 285's on trd rims with 1.25" spacer and rubbed the fender flares and part of the cab mount(chopped back a bit)
    as far as control arm, rubbing, not sure, but i know there are a few guys running 315/xx/16-17's on a 3" lift with lots a trimming
  4. May 11, 2013 at 6:39 PM
    DevL
    DevL Well-Known Member
    As wide as your wheel will hold. The UCA rubbing is the only thing that WONT be an issue though.
