LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Jul 10, 2025 at 10:58 AM
    #2561
    Pittsy
    Pittsy [OP] AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    I haven’t even probed it yet.
  2. Jul 10, 2025 at 2:30 PM
    #2562
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Was that an option the whole time?! I'm not really sure what's all involved with the AC stuff honestly
  3. Jul 10, 2025 at 2:34 PM
    #2563
    Pittsy
    AZ
    I mean it is, but it’s ghetto. If you go WOT you’ll overspin the compressor, if the engine overheats, it won’t shut the compressor off, if your evaporator core freezes over, your compressor won’t shut off
    Torspd likes this.
  4. Jul 10, 2025 at 2:36 PM
    #2564
    WormSquirts
    Braeden
    BC
    Oh I see, yeah not ideal
  5. Jul 10, 2025 at 2:38 PM
    #2565
    Pittsy
    AZ
    I mean it’s worked once before, so it’s gotta work again. I checked my fuses for the ac relays I’m using and they’re good.
    @Dm93 @caribe makaira is there an OEM that would be prohibiting the stock ac controller from outputting its turn on signal?
  6. Jul 10, 2025 at 8:34 PM
    #2566
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Srry been busy.
    Have you checked your inputs to the A/C Amplifier?
    A/C Permission signal Pin 7 (Blue) (needs to be 12v)
    Coolant Temperature signal Pin 19 (Grey/Black)
    Tach Signal Pin 22 (Black/White)
    A Dual Pressure Sensor input Pin 5 (Orange) (Needs to be Grounded)
    Evaporator Thermister input Pin 3 (White) (Sensor Ground) - Pin 4 (Black) (Sensor Signal)
  7. Jul 10, 2025 at 8:38 PM
    #2567
    Pittsy
    AZ
    Haven’t gotten to probing it yet, it’s been too
    Hot today to do much of anything. But I haven’t changed any of those input wires at all since it’s stopped working. Still planning on probing them, but wanted to see if there was any easy low hanging fruit to go after first
  8. Jul 10, 2025 at 8:57 PM
    #2568
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean aside from power and ground that's the signals required for it to turn the compressor on so one or more must be missing/incorrect, the Lock Sensor signal only comes into play when the compressor clutch is commanded on.
  9. Jul 10, 2025 at 9:03 PM
    #2569
    Suarezabraham
    Suarezabraham Well-Known Member
    Monterey, CA
    2014 Tacoma double cab 4x4
    Looking good.
  10. Jul 10, 2025 at 11:29 PM
    #2570
    Pittsy
    AZ
    If the ac amplifier was fried, I’d lose all control of the hvac panel correct? Just want to make sure I don’t have an issue there
  11. Jul 11, 2025 at 6:29 AM
    #2571
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No the A/C Amplifier only controls the compressor and recirc door, everything else is controlled by the panel switches.
    Pittsy[QUOTED][OP] and allenfab like this.
  12. Jul 11, 2025 at 12:13 PM
    #2572
    Pittsy
    AZ
    Going back to page 67 here....
    Looks like I have the wrong code uploaded to the Arduino currently. Not sure what code is running on it, but not the right one. I'll try and reupload it tonight and see if it magically starts working.
  13. Jul 11, 2025 at 7:03 PM
    #2573
    Pittsy
    AZ
    Okay so I got the correct code uploaded to the arduino, and confirmed with the scope that I have the correct waveforms actually being produced on the correct pins of the ac amp. What’s next?
  14. Jul 11, 2025 at 7:05 PM
    #2574
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you verify the other inputs?
  15. Jul 11, 2025 at 7:06 PM
    #2575
    Pittsy
    AZ
    Like permission signal? It’s just 12v right?
  16. Jul 11, 2025 at 7:07 PM
    #2576
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea that needs to be 12v.
    Also check that your dual pressure switch input is grounded, I'm assuming your using a pressure switch for that?
  17. Jul 11, 2025 at 7:16 PM
    #2577
    Pittsy
    AZ
    Okay, so my pressure switch wire (pin 5) has 12v on it with the truck turned off. Everything else is good.
  18. Jul 11, 2025 at 7:17 PM
    #2578
    Pittsy
    AZ
    @Dm93 when I check the resistance between the two posts on the pressure switch I get open lead
  19. Jul 11, 2025 at 7:18 PM
    #2579
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you using a pressure switch on that wire? If so is there refrigerant in the system?
  20. Jul 11, 2025 at 7:21 PM
    #2580
    Pittsy
    AZ
    Yep I sure am. And actually, I’m not sure if there is. I mean it might’ve leaked it all out, but it should still try and turn the compressor on no? Obviously shutting back off if there’s nothing detected? I recall dealing with that when I had the suction and liquid line reversed on the compressor side of things
