LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Sep 12, 2023 at 1:36 PM
    #781
    Pittsy
    Pittsy [OP] Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    It was pretty expensive. Should be worth it. It’s a much sturdier pan than I have right now.
    Steves104x4 likes this.
  2. Sep 12, 2023 at 5:11 PM
    #782
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A good thing is, that should you ever decide you need some extra oomf, it already had ports for turbo drain lines. :D
    Hayden334, Camazon and Steves104x4 like this.
  3. Sep 14, 2023 at 1:24 PM
    #783
    Pittsy
    AZ
    The poor 4L75E if I ever did that poor Toyota axle.
  4. Sep 14, 2023 at 6:31 PM
    #784
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I mean, how much power are you hypothesizing?
  5. Sep 14, 2023 at 6:32 PM
    #785
    Pittsy
    AZ
    The motor is stock, so probably like 350 wheel. If I put a big single on it I’d be aiming for 6-700 wheel.
  6. Sep 14, 2023 at 6:45 PM
    #786
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All about the instant shock load then. They've handled that already.
  7. Sep 14, 2023 at 6:47 PM
    #787
    Pittsy
    AZ
    What’s handled that?
  8. Sep 14, 2023 at 6:47 PM
    #788
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The OEM rear axle. Of course that was on much smaller tires.
    hayrider2.0 likes this.
  9. Sep 14, 2023 at 6:49 PM
    #789
    Pittsy
    AZ
    Scary. The shock load of 700HP plus the shock load of LT, scary. Maybe one day I’ll get a full fab rear axle.
  10. Sep 14, 2023 at 7:32 PM
    #790
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I like to think the shock load of 250-280whp on my truck is a nice safe space. Front diff is definitely the weak link
    nudavinci64, Torspd and hayrider2.0 like this.
  11. Sep 14, 2023 at 7:42 PM
    #791
    Pittsy
    AZ
    At least my truck isn’t stick shift anymore. Might fare a bit better now that it’s auto. The trans is overbuilt for the application. Diffs are stock. That’s my next weak point I think.
    454 is gonna truss my axle soon. Maybe when I blow ring gears I’ll put an ECGS third in, but I’m not sure those will fare any better will they?
  12. Sep 14, 2023 at 7:46 PM
    #792
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    My ecgs third with 4.56’s lasted 2yrs on mid travel with 33’s, 4yrs with 35’s and lt, and just over a year after the switch to 37’s before the rear let go. Then went to a tundra rear with 5.29’s.
    nudavinci64 likes this.
  13. Sep 14, 2023 at 9:07 PM
    #793
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Do you run 4wd all the time, or just when you're crawling?
  14. Sep 15, 2023 at 5:06 AM
    #794
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Was that cryo treated as well?
    We all know though that gear ratio goes up, pinion size decreases. Thus at some point, depending on how the vehicle is used, a larger overall axle/ring&pinion are necessary to overcome that smaller original size.
  15. Sep 15, 2023 at 6:07 AM
    #795
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I recently started running 4wd when going fast. At least locally in the cinders. Going too fast chasing my buddy around in his race car and the added control is nice.
    That wasn’t cryo treated. But the new setup up front is. Front got everything that could come out cryo treated and rem polished and the rear just got rem polished. The 10.5” rear is freaking massive
    nudavinci64 and Torspd[QUOTED] like this.
  16. Sep 15, 2023 at 7:42 AM
    #796
    WormSquirts
    Braeden
    BC
    That's what I was curious about. I originally was thinking I'd just run 2wd going fast to save the front diff, and I wasn't too worried about it crawling because I can be gentle, but then I started thinking it might be nice to run it in 4wd going fast too, but then I'll be worried about breaking it
    snowsk8air2[QUOTED] likes this.
  17. Sep 15, 2023 at 7:55 AM
    #797
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    For years I ran my boosted taco on 33's in 4wd at the sand drags and beat the crap out of it, not to mention wheeling too. Toyota rear with 4.56s lasted a good while (~8 years). It finally decided to let go after about 2 years on 35s. I threw in a new ECGS 4.56 3rd a few weeks ago. We'll see how long it lasts. The front (minus a grenaded CV here or there) has been solid so far.. knock on wood.
    snowsk8air2 and Torspd like this.
  18. Sep 15, 2023 at 12:01 PM
    #798
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    It definitely adds a bit of control when you start going faster and faster
    nudavinci64 and tacotunner06 like this.
  19. Sep 15, 2023 at 12:44 PM
    #799
    WormSquirts
    Braeden
    BC
    I'll be running 39's with 500hp which is what worries me.
    I have been considering trying to find a tundra front diff and shoving it in the front, but they are really hard to find, and pretty big.
  20. Sep 15, 2023 at 12:44 PM
    #800
    WormSquirts
    Braeden
    BC
    anyway sorry @Pittsy for the thread take over
    snowsk8air2 likes this.
