LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Mar 7, 2024 at 12:23 AM
    #1241
    Pittsy
    Pittsy [OP] AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    I don’t know that it’ll be easy. Losing 3/4 is a typical 4l60 thing. Usually from getting hot, but it never got above 180. I’ll reach out to monster and see what they can do for me. I’ll probably go turbo 400 since it’s the most similar in footprint.
  2. Mar 7, 2024 at 12:56 AM
    #1242
    Pittsy
    AZ
  3. Mar 7, 2024 at 5:03 AM
    #1243
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Valve body problem? Solenoids not allowing the change? Throwing darts into the air.
    XPOTRPR likes this.
  4. Mar 7, 2024 at 5:21 AM
    #1244
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Was thinking this too. If no other symptoms or noises, felt vibes, etc.. really anything that would indicate a mechanical failure.. I'm wondering if a solenoid is stuck.. or came apart in the valve body.
    Torspd[QUOTED] likes this.
  5. Mar 7, 2024 at 6:31 AM
    #1245
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We don't have all of the details, but it sounds like a similar problem that I helped a mate with on his Infinity. Wouldn't change out of 2nd. Different car, yes. The electronics on the valve body failed.
    XPOTRPR likes this.
  6. Mar 7, 2024 at 7:59 AM
    #1246
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
  7. Mar 7, 2024 at 8:09 AM
    #1247
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    You said Monster Transmission?
    Look at Eric the Car Guy. He has had the worst luck with them. And overall bad feed back from Monster Transmission. Especially with 700R4/4L60E stuff.
    Yea a TH400 is easy peasy to work on and rebuild also.
    Torspd likes this.
  8. Mar 7, 2024 at 9:13 AM
    #1248
    Pittsy
    AZ
    I don’t even know where to begin testing this.
    I guess dropping the pan would be my first step.
    would be really weird for that to be my issue.
    you’re telling me
    yeah I knew monster was a less than ideal company to deal with but I didn’t buy it directly from them. Definitely wouldn’t given the option.
  9. Mar 7, 2024 at 9:55 AM
    #1249
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any ability to hook up a high end scan tool to see the transmission functions?
  10. Mar 7, 2024 at 9:57 AM
    #1250
    Pittsy
    AZ
    It’s a Holley ECU, so no, but it tells me everything. What are you looking for?
  11. Mar 7, 2024 at 11:21 AM
    #1251
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A way to test the solenoids and check for line pressure changes.
  12. Mar 7, 2024 at 11:22 AM
    #1252
    Pittsy
    AZ
    I’m able to view line pressure on the Holley.
  13. Mar 7, 2024 at 7:16 PM
    #1253
    Pittsy
    AZ
    Pulling the trans tomorrow. Going to try and leave the engine in the truck. I don’t see why I can’t.
    this thread is gonna turn into why I hate this truck and why I’m in so much pain dealing with it.
    2WD and TACOTU3 like this.
  14. Mar 7, 2024 at 7:35 PM
    #1254
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Just remember Saturday and how fun it was. Just some more gremlins on a big project.
  15. Mar 7, 2024 at 7:48 PM
    #1255
    Pittsy
    AZ
    This is a pretty big gremlin. I know what you’re saying though.
    super high highs, super low lows with this thing.
  16. Mar 7, 2024 at 9:08 PM
    #1256
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll overcome, and it will all be worth it. Any large undertaking such as this, is going to have plenty of hurdles. You will persevere though.
    This^^^^
  17. Mar 7, 2024 at 9:12 PM
    #1257
    Pittsy
    AZ
    Just frustrating considering that this is my third engine and third transmission in this truck.
  18. Mar 8, 2024 at 12:13 AM
    #1258
    WormSquirts
    Braeden
    BC
    Third time's the charm
    stickyTaco, N8tiveTaco21 and dk_crew like this.
  19. Mar 8, 2024 at 7:33 AM
    #1259
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Chin up buddy. I have had 6 engines.
    stickyTaco likes this.
  20. Mar 8, 2024 at 7:39 AM
    #1260
    Pittsy
    AZ
    I remember when I thought that about my first LS.
