LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Jun 8, 2024 at 10:44 PM
    #1401
    Pittsy
    Pittsy [OP] AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    If ya want something done right, you gotta do it yourself, or know of someone very, very reputable.
    EdinCincinnati likes this.
  2. Jun 9, 2024 at 12:27 AM
    #1402
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    :popcorn:
  3. Jun 9, 2024 at 3:48 PM
    #1403
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Amen!
  4. Jun 10, 2024 at 5:59 AM
    #1404
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    I've had a lapse in following this thread but since this is a permanent install with the Arduino and op-amp (could latch-up under overvoltage spike) for the AC there is risk of both frying or latching up from electrical noise and load dump. Adding some PTC fuses in series with power and IO's is a good idea as well as some TVS (unidir zener will also clamp reverse polarity) devices across the lines to keep all the voltages clamped to a safe level. ON the IO's teh PTCs can potentially be omitted if teh TVS is after the resistors, which will limit current. The PTC fuses will ensure that you could have (in theory) a overvoltage or short indefinitely without frying anything. Noise can set microcontrollers into unknown states as well. It is good practice to use a watch-dog timer (i believe the atmel on the ard mega has one). For teh Arduino, this may need some inline C code if teh Arduino libraries do not expose this function. The WDT will reset the micro if it gets hung up.
    This is a good tech reference on this. You can ignore teh fancy active stuff in the article. How to Choose the Right Protection for Your Circuit | Analog Devices
  5. Jun 10, 2024 at 6:08 AM
    #1405
    Pittsy
    AZ
    I understand the PTC fuses but you lost me with the watch dog stuff. I remember when I was in FRC in high school, we had code issues sometimes and the serial monitor would print “watch dog not fed!” Lol
    somebody[QUOTED] likes this.
  6. Jun 10, 2024 at 6:17 AM
    #1406
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    The watch dog is basically just a timer that runs in some dedicated hardware on the chip (not in your program execution space). If the timer expires (at the interval of choice), the WDT will reset the chip and code will begin execution from the start. Feeding the dog is just resetting this timer so that the WDT does not reset the chip. This feeding is just 1 function call that is stuck in your main loop of the code.
    It looks like someone wrote a lib for the WDT. Watchdog - Arduino Reference
    Torspd likes this.
  7. Jun 12, 2024 at 12:30 PM
    #1407
    Pittsy
    AZ
  8. Jun 20, 2024 at 4:22 AM
    #1408
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    What’s the latest?
  9. Jun 20, 2024 at 6:51 AM
    #1409
    Pittsy
    AZ
    Shifters!
    allenfab likes this.
  10. Jun 21, 2024 at 12:40 AM
    #1410
    wesintexas
    wesintexas Well-Known Member
    wes
    Austin
    2013 TRD Sport DCLB
    Excellent build thread Pittsy. This should give the Taco some much needed uumph.
    Keep it coming.
  11. Jun 22, 2024 at 6:47 AM
    #1411
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    @Pittsy what year Tundra booster and MC ended up being the correct combo ?
  12. Jun 22, 2024 at 7:15 AM
    #1412
    Pittsy
    AZ
  13. Jun 22, 2024 at 8:04 AM
    #1413
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  14. Jun 22, 2024 at 8:43 AM
    #1414
    Pittsy
    AZ
    The extension is used to reach the pedal.
  15. Jun 22, 2024 at 6:26 PM
    #1415
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    so it’s not like the extension from the big brake kit that goes from booster to the mc ?
  16. Jun 22, 2024 at 8:21 PM
    #1416
    Pittsy
    AZ
    Nope, it’s the piece that extendeds the brake pedal clevis to the brake pedal itself.
  17. Jun 27, 2024 at 4:57 PM
    #1417
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    @Pittsy…is it drivable yet?
  18. Jun 27, 2024 at 4:58 PM
    #1418
    Pittsy
    AZ
    Not yet. Should be going to driveline shop pretty soon.
  19. Jul 2, 2024 at 8:24 PM
    #1419
    Pittsy
    AZ
    Fluids went in the truck today, no modifications were necessary to the coolant hard lines. Bleeding this truck sucks though.
    I reached out to PPE engineering, they’re the most popular Lexus exhaust header and system manufacturer by far, and they happen to be local to me.
    I had to have my old exhaust chopped out to get the trans out, and instead of welding that mild steel POS back in, they’re gonna make me an EL y pipe, resonated, dual mode muffler, and fender exit out of stainless for me once my truck is back and shook down.
    Torspd and BEAR_KNIFE_FIGHT like this.
  20. Jul 2, 2024 at 9:09 PM
    #1420
    Pittsy
    AZ
    I’ve been a long time customer of theirs. I asked him about it when I had my IS500 there.
    He said they are super busy and behind schedule right now, but the second he has a slot he’s going to let me know when to drop the truck off. Shouldn’t be too far out. I got a lot to do between now and then anyhow.
