LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Jul 24, 2024 at 2:11 PM
    #1481
    planetbuster
    planetbuster Well-Known Member
    San Diego
    2014 DCSB TRD OR Lifted+supercharged
    right on sir, hang in there. some teenager at some point will see this and it'll inspire him to get his ass into the garage and grab a wrench.
    Pittsy[OP] and Torspd like this.
  2. Jul 24, 2024 at 4:33 PM
    #1482
    Pittsy
    Pittsy [OP] AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    I got new hardware for this fuel rail, but this Fast Fuel rail is just a piece of shit. The brackets don’t line up very well, and they put the rails and a crazy “cambered in” angle relative to the manifold and injectors. Can’t for the life of me get this to stop leaking.
  3. Jul 24, 2024 at 5:47 PM
    #1483
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds like altogether a mismatch.
  4. Jul 24, 2024 at 6:19 PM
    #1484
    Pittsy
    AZ
    I think the mismatch is LS engine // Toyota Tacoma
    TACOTU3 likes this.
  5. Jul 25, 2024 at 12:15 AM
    #1485
    Pittsy
    AZ
    So basically I’m running into this problem. The fast intake, has 0 documentation about how far away the mounting posts for fuel rails are. The Fast Fuel rails have 0 documentation, period.
    I want to buy the radium engineering fuel rails, and they use stock mounting holes.
    I also need to get a new set of lower o rings for the fast intake. Fast uses their own proprietary non OEM size o ring that I’ll need to get. I also will need a new set of uppers that fit the radium fuel rail.
    Debating whether or not I tow the truck to the center console place tomorrow AM.
    I still need to run a power wire from my switch pros for the rugged radio setup. And a power wire for the accessories for the center console. And a power wire for my Starlink. And organize and zip tie the engine bay wiring again. I got heat exhausted today after spending all day yesterday out there. I got pissed off and frustrated at the fuel rail situation today. You’d think fast rails would be a perfect no bs no fuss fit on a fast intake, but apparently it’s common to have serious fitment issues depending on the Injector you run. :annoyed:
  6. Jul 25, 2024 at 7:02 AM
    #1486
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you contacted FAST about the fuel rail issue? Do they have recommendations?
  7. Jul 25, 2024 at 7:07 AM
    #1487
    Pittsy
    AZ
    I tried yesterday but they close so early. Gonna call them here shortly. The brackets they use are just bent 3/16 steel L’s with some holes punched in them. Pretty shitty.
  8. Jul 25, 2024 at 8:00 AM
    #1488
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well I’ve been waiting for my next “ I told ya’ so “ and you just tee’d it up beautifully for me thanks :rofl:
    the Toyota gods are angry :bananadead:
  9. Jul 25, 2024 at 8:03 AM
    #1489
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good
  10. Jul 25, 2024 at 11:45 AM
    #1490
    Pittsy
    AZ
    after I asked the dude at fast why the fuel rails fit so poorly on their own intake, he goes, yeeeeeaaah its a common thing we hear, most people just make their own brackets out of barstock...
    Jumping off the fast train now, got some radium rails on the way, along with their fit/plumbing kit, and new injector upper and lower o rings, all should be here tomorrow, fingers crossed.
  11. Jul 25, 2024 at 11:59 AM
    #1491
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Thats straight up insane, and good to know not to bother with them. I'm happy with my stock ls3 intake off marketplace and holley fuel rails. everything fit perfect. probably could have just run the stock ls3 fuel rails too, but @tacotunner06 said they weren't bad ass enough.
    Torspd likes this.
  12. Jul 25, 2024 at 12:00 PM
    #1492
    Pittsy
    AZ
    Their intake is the bees knees for NA power from what ive heard and read and researched. 102mm TB Opening paired with a nick Williams 103mm TB.
  13. Jul 25, 2024 at 12:02 PM
    #1493
    WormSquirts
    Braeden
    BC
    I just don't like supporting companies that don't support their customers. I'm just gunna run the stock TB. I can't see a larger TB making much of a difference without boost to use the extra air.
  14. Jul 25, 2024 at 12:05 PM
    #1494
    Pittsy
    AZ
    I agree with you 100%. Won't be purchasing anything else from them. He tried selling me on their 1 piece oem style rail but I don’t want to be 0/2
  15. Jul 25, 2024 at 4:49 PM
    #1495
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Jul 25, 2024 at 5:21 PM
    #1496
    Pittsy
    AZ
  17. Jul 26, 2024 at 4:19 AM
    #1497
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He must not have tested the matching brand fuel rails. Lol
    stickyTaco likes this.
  18. Jul 26, 2024 at 9:35 AM
    #1498
    Pittsy
    AZ
    apparently not :rofl:
    Torspd[QUOTED] likes this.
  19. Jul 26, 2024 at 10:52 PM
    #1499
    Pittsy
    AZ
    Radium rails fit perfectly. No leaking. Got pressure backed down to 42.5psi. I think I’m gonna call it a night while I’m ahead, I had a 13 hour day at work. Started working towards my A&P. Got the weekend off, so I’ll put this thing through its paces, if everything goes well on its first test drive.
    Tacoma1192, llibrm, Torspd and 4 others like this.
  20. Jul 27, 2024 at 7:05 PM
    #1500
    Pittsy
    AZ
    First drive went great. Issue hasn’t come back yet. First WOT pull on the transmission is awesome. Shifts super smooth.
    Tacoma1192, RugglesTarlek and TACOTU3 like this.
