LS6 Swap 2nd Gen Build + New Tundra
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Sep 26, 2022.
  1. Aug 10, 2024 at 7:31 PM
    #1701
    Pittsy
    Pittsy [OP] AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Yep it heard me….
    @Dm93 @caribe makaira
    the Holley is looking for fuel level sender resistance at the combination meter connector, is it there? I’ve tired both pin 4 and pin 8 on connector A and I’m reading 0% fuel no matter what. Fuel is a little above a 1/4 tank when I plug the normal meter in.
    And if you’re bored, I still need the indicator light power wires for the tire light, parking brake light, low beam, and door light. I’ve gotta be missing something here.
  2. Aug 10, 2024 at 7:48 PM
    #1702
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I need these for my Bimmer and my Taco. As soon as I saw them in the video, it made me immediately think of your build and struggles. I am super glad they worked out.
    Pittsy[QUOTED][OP] likes this.
  3. Aug 10, 2024 at 7:54 PM
    #1703
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You need to ground one of the wires and connect your Holley unit to the other if your Holley connection to it is just a single wire.
  4. Aug 10, 2024 at 7:55 PM
    #1704
    Pittsy
    AZ
    It doesn't matter if I ground pin 4 or 8? and the other just goes to the single wire in the holley?
  5. Aug 10, 2024 at 7:57 PM
    #1705
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pin 4 (Yellow/Black) is the level sensor ground on the stock system but it shouldn't matter which one you ground.
  6. Aug 10, 2024 at 7:59 PM
    #1706
    Pittsy
    AZ
    Thanks!
    Looks like tire light is pin 23 connector A
    Door light is pin 18 connector A
    Low beam is pin 32 connector A
    But I can't seem to decipher which one the parking brake light is?
  7. Aug 10, 2024 at 8:05 PM
    #1707
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The parking brake switch is connected to the ABS module which turns the brake light on, if your not using the ABS module anymore you will need to run a wire directly from the parking brake switch.
    Torspd likes this.
  8. Aug 10, 2024 at 8:09 PM
    #1708
    Pittsy
    AZ
    I still have my ABS module and it’s still
    Operating
  9. Aug 10, 2024 at 8:12 PM
    #1709
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    In that case the Brake indicator wire is Pin 10 (Black/White) and the ABS Indicator is Pin 9 Orange of connector C10 (B) but they are reverse logic meaning the ABS module grounds the wire to turn the lights off.
  10. Aug 10, 2024 at 8:31 PM
    #1710
    Pittsy
    AZ
    Pin 32 red/black only has .4v on it when the headlights are on. That’s right pin for low beams right?
  11. Aug 10, 2024 at 8:43 PM
    #1711
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes, are you sure you didn't cut the wire when you were ripping wires out? It goes through junction 2A in the engine room fuse box.
  12. Aug 10, 2024 at 8:59 PM
    #1712
    Pittsy
    AZ
    Yeah, it’s okay I got it now.
    but the door signal wire, it’s not illuminating on the dash for me. Does that get pulled down to ground too?
    and tire light? I can’t test that one
    edit door was switched to ground, but can you confirm tire light for me?
  13. Aug 10, 2024 at 9:01 PM
    #1713
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Tire light is reverse logic like the ABS and Brake lights.
  14. Aug 10, 2024 at 9:24 PM
    #1714
    Pittsy
    AZ
    Awesome!
    We’re fully functional!
  15. Aug 10, 2024 at 9:26 PM
    #1715
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Fancy:cool:
    Torspd and Pittsy[QUOTED][OP] like this.
  16. Aug 10, 2024 at 9:39 PM
    #1716
    Pittsy
    AZ
    You made it happen man!
    dk_crew and Dm93[QUOTED] like this.
  17. Aug 10, 2024 at 9:39 PM
    #1717
    Pittsy
    AZ
    dk_crew and Dm93 like this.
  18. Aug 10, 2024 at 9:51 PM
    #1718
    caribe makaira
    Caribbean, Puerto Rico
  19. Aug 11, 2024 at 3:14 AM
    #1719
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Got to admit thats an awesome dash cluster
  20. Aug 11, 2024 at 10:10 AM
    #1720
    Pittsy
    AZ
    Forgot to mention that I tired plugging the headsets directly into the intercom and it didn’t change anything @WormSquirts
