Lsd and tire chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05 TRD Sport, Jan 15, 2011.
  1. Jan 15, 2011 at 12:59 PM
    05 TRD Sport
    05 TRD Sport [OP] She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    The ice/snow is gone now but while it was here I thought about chaining up and taking a ride. Started to wonder if chains would adversely affect my lsd. Wouldn't want to mess up anything just for a joy ride. IDK, any ideas?
  2. Jan 15, 2011 at 1:30 PM
    Rodallg
    Rodallg Well-Known Member
    CA
    While I was up north during snow on the pass my LSD was doing all the beeping (no weight in the bed), once I put the chains on it never flashed or beeped at all.
  3. Jan 15, 2011 at 1:37 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The beeping is the VSC alerting you that you are sliding and it is correcting the slide. If you were on the highway, it is a way to tell you to back off the accelerator before you wreck your truck.
    The chains eliminated the sliding, so your VSC didn't beep. Your TRAC (LSD system) doesn't have any sounds but does brake any tire that looses traction so the tire with traction gets the torque to keep you moving.
  4. Jan 15, 2011 at 2:05 PM
    05 TRD Sport
    Red Prerunner AC
    Okay thanks. It was just a passing thought because here in central Ga. we rarely get any snow/ice. Just thought I'd throw it out there and see what people with more ice/lsd experience had to say about it.
  5. Jan 15, 2011 at 2:10 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    If your worried about it just hold the VSC switch 3 seconds and it will disable the auto lsd and give you an open differental.
  6. Jan 15, 2011 at 2:16 PM
    05 TRD Sport
    Red Prerunner AC
    Don't have a VSC switch
  7. Jan 15, 2011 at 2:35 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    You shouldn't drive on acid with chains or not ;)
  8. Feb 4, 2011 at 11:52 AM
    cdikkers
    cdikkers Minimum Wage!
    Casey
    New Berlin, IL
    Speedway Blue '05 PreRunner
    *BUMP!*
    Where would one order some chains from? I just had an unfortunate incident with my Prerunner a block from my house (After driving 70 miles today without incident). I came around a turn, kept turning, next thing I knew the front was in a yard, the rears were on the road on ice, and I couldn't get any traction to back out. Threw down salt, getting ready to air down, then a Dodge Ram showed up and gave me an offer I couldn't refuse. Only cost me a couple beers, but still I'm wondering if some chains wouldn't have given me enough traction to pull out. (4wd owners, please don't state the obvious!)
  9. Feb 4, 2011 at 12:07 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    cheaper to have a hand winch and a tow strap, then tire chains.. lot faster with the hand winch too
  10. Feb 4, 2011 at 12:10 PM
    cdikkers
    Casey
    New Berlin, IL
    I do have a tow strap and a logging chain, no winch though. The problem was, in my location there was nothing that I could have hooked onto even if I tried.
  11. Feb 4, 2011 at 12:45 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Chains in Atlanta?? Isn't that a bit extreme??
  12. Feb 4, 2011 at 12:56 PM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    bag of kittey litter..dump it around the tires and you have some traction. Even the floor mats can be used in a pitch. Otherwise, spinnem till they are hot..that melts some ice too. Been there done that
  13. Feb 4, 2011 at 8:30 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I used the mat method to get out of the yard the other day... I didn't use my mats of course. :D Then my wife recognized they were from her Neon.... yeah, not so much. The mats did work really well!
  14. Feb 5, 2011 at 6:04 AM
    mattygabe
    mattygabe Well-Known Member
    Western PA
    2011 Access Cab SR5
    Access Limited Soft Rollup Tonneau Cover
    I've used kitty litter before, but I think you've gotta have some significant ice or snow under the tire to make it worth it.
    In certain situations (snow cover on a steep incline, par example) the kitty litter actually hindered the cause to get a stuck Camaro out of the driveway - it sucked up all moisture, but then became a slippy mud-like covering, and that's all the tires were grabbing.
    Not a bad idea to have some on hand in a pinch, though! Could just as easily carry salt along side it, too!
  15. Feb 5, 2011 at 6:39 AM
    05 TRD Sport
    Red Prerunner AC
    Like I said, it was just a passing thought. Maybe once every 10-12 years we more than an inch or two of snow. This year it was ice from the beginning. I've got some chains out in the shop that I don't think I've ever used. I really don't even remember where they came from. After a couple of days of being iced in, I started thinking about taking a ride(milk sammich, ya know). Not like I was going to go out and buy chains.
  16. Feb 5, 2011 at 7:14 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You have mechanical Limited Slip same as me , definetely no problem with chains .
  17. Feb 5, 2011 at 7:19 AM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    Hahahaha, alright man, well, I am orginally from Peachtree City, then moved up north where we actually have to use chains on the bad days.... Total pain in the ass! I miss the A!
