LSD for '05 Tacoma 2WD?
Discussion in '4 Cylinder' started by TacoNewb, Jan 29, 2010.
  1. Jan 29, 2010 at 4:29 AM
    TacoNewb
    TacoNewb [OP] New Member
    San Diego
    05 Prerunner SR5, 4 cyl, 2wd
    ARB rear locker, ARB onboard air compressor, ICON coil overs, Total Chaos UCAs, ICON rear shock struts w/ reservoir, Re-geared, added leaf pack, flowmaster exhaust.
    Hi, I have a '05 Tacoma 2WD 4cyl. I'm wondering if there is an aftermarket Limited Slip Differential (LSD) someone can recommend.
  2. Jan 29, 2010 at 5:01 AM
    TacoNewb
    San Diego
    I've just checked it out, it looks like I don't have LSD. I'm want to use the truck for driving in sand, snow, icy road, and maybe some towing. I should've bought a 4x4 taco, but this is what I'm stuck with. Do you have any suggestions to upgrade my tacoma? So far I want to install a CAI, exhaust, and headers just to boost some HP. But I'm starting from scratch and don't know squat.
  3. Jan 29, 2010 at 9:57 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Detroit Trutrac is an aftermarket LSD
    Doug Thorley and LCE both make headers for the 2TR-FE 4cyl engine.
    Your air intake pulls from the fender, so it's already "cold"
  4. Jan 29, 2010 at 12:55 PM
    TacoNewb
    San Diego
    Thanks for the helpful information.
  5. Jan 29, 2010 at 5:01 PM
    afd23a
    The Dynamo of Dixie
    No problem. Check out some of the build threads and you'll see a ton of mods.
