lsd from factory?
Discussion in 'Technical Chat' started by HerNameIsLucy, Oct 4, 2009.
  1. Oct 4, 2009 at 2:53 PM
    HerNameIsLucy
    HerNameIsLucy [OP] I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Since I bought the truck I've always thought I had a stock one-wheel-spin-the-other-sit-there-like-a-retard rear axle.
    Couple days ago I got to a friend's house. She's having a yard sale. So traffic is coming so thick I couldn't stop there, had to turn around. Pulled into someone's driveway, backing out of it the front tires got caught on a 'bout 3 inch lip from driveway level to road level. The back tires chirped when I hit the gas, when I was driving away I looked and BOTH tires had left a rubber patch on the road.
    So I figure "maybe it's LSD in reverse or something"
    Today I went down a VERY rough dirt / mud road going out into the sticks. Had to break the tires loose in the rear several times. I get home, BOTH sides of the truck have mud in the wheel-wells. Mud that had obviously been thrown there by a tire, not just walked up on a tire.
    So I guess I got a LSD differential.
    How unusual is that for a 1st gen prerunner?
  2. Oct 5, 2009 at 5:59 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If it's 100% 'factory' - so unusual it's impossible ... NO 1995.5 - 2004 Tacoma came from the factory with an LSD.
  3. Oct 5, 2009 at 6:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you buy the truck new or used?
    If you bought it used, perhaps someone had an LSD installed in it?
    Generally, the 95-04's didn't come with LSD's. I had a FSM for a 96 tacoma and they listed LSD's in the FSM. I thought that was kinda weird....like maybe it was offered at one point or somewhere? I dunno...
    Have you had your VIN decoded for some info?
  4. Oct 5, 2009 at 6:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    An open diff doesnt mean only 1 tire will spin all the time. In many cases, both will spin provided one tire doesnt have any more traction thant the other. Best way to tell if you have an LS diff is to put one tire on Pavement, the other in dirt, then hit the gas. If the one in the dirt spins, and the one on the pavement doesnt, its an open diff.
  5. Oct 5, 2009 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    John....You should have an axel code on your door jamb. Next to the VIN number. It should look like this :
    B06A......Can you post it?
  6. Oct 5, 2009 at 7:21 AM
    HerNameIsLucy
    RIP Lucy.
    B03A...meaning 8 inch, 4.10 gearing, and 2 pinion open diff.
    Interesting. Nothing special at all about mine.
    Got this from TTORA:
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
  7. Oct 5, 2009 at 7:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well...The 4:10 gear is nice. :)
  8. Oct 5, 2009 at 7:31 AM
    HerNameIsLucy
    RIP Lucy.
    This is true! Little truck will chirp the tires with very little throttle. Someday it's gonna get me in trouble with Joe Lawman, when I ain't even trying!
  9. Oct 5, 2009 at 10:23 PM
    Quigtar
    Quigtar New Member
    09 LB DC 4x4 Mag Grey TRD Sport
    could have lifted the rear end up with jack and spin one tire. if other tire goes oppposite way you got an open diff
  10. Oct 6, 2009 at 6:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not always. My 2000 had an open diff, and when I jacked it up (all tires off the groung), and rotated the rear wheel forward, the other spun the same way.
  11. Oct 6, 2009 at 6:10 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Far out man!!! Oh wait.... You're not talking about the good lsd....
  12. Oct 6, 2009 at 5:03 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Bah! I' sure i have the open diff at 4.10 but i cant match it up. Closest looking code is A02A , that doesn't sound right for a reg cab 4x4.
  13. Oct 6, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nothing to match up. You have an 8.4" open axle with 4:10 gears. That code chart is only for the first gens.
  14. Oct 6, 2009 at 5:17 PM
    Tacoyota
    08 4wd
    Thanks Chris. I thought I had read the thread too lol.
