LSD + Locking Diff options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtmiller1001, Mar 30, 2010.
  1. Mar 30, 2010 at 7:18 PM
    gtmiller1001
    gtmiller1001 [OP] Well-Known Member
    Greg
    Houston, TX
    06 Double Cab TRD Sport V6
    BHLM, Painted Stock 17" sport rims black, 3" Toytec coil overs with 5100's, AAL, black bull bar, TRD filter, parrot bluetooth, anytime foglights, debadged, removed mud flaps, added bed lights, grillcraft, Wet Okole's, Weather Tech's.....and traded in for a Tundra
    I know this has to be on here somewhere and I read a few threads similar to what I'm asking but couldn't really find a direct answer, so if one is on here feel free to point me to it!
    I have an 06 2wd with the LSD.
    I pretty much drive on pavement but want the option to lock the rear diff if I am ever in an offroad situation.
    What's the most economical way to accomplish this? When I say economical i don't mean "cheap". I do mean cost effective for what I'm trying to accomplish. I don't go offroad hardcore like most on here. Just want the option to lock up the rear on command. I really don't want the burden of installing a compressor either.
    Suggestions?
    And is it possible to accomplish this and still maintain the functionality of the LSD for daily driving?
  2. Mar 30, 2010 at 7:21 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    shoulda got trd,,maybe you can get the E-locker on yours?
  3. Mar 30, 2010 at 7:23 PM
    gtmiller1001
    Greg
    Houston, TX
    It is TRD, just not the offroad b/c i don't go offroad.
    Ironically enough i had an 06 off road before this truck and totalled it. It had the rear locker.
    do you mean the stock e locker?
  4. Mar 30, 2010 at 7:30 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    ohh/....yea you might be able to get the stock e locker off an offroad, but itll prolly be expensive..
  5. Mar 30, 2010 at 7:36 PM
    gtmiller1001
    Greg
    Houston, TX
    from what i've read i would have to replace the whole rear axle to utilize the stock toyota locker.
    can anyone verify this?
  6. Mar 30, 2010 at 7:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can't have the LSD and a locker in the same differential on a 2006 truck.
    The LSD carrier needs to be removed to install a locker. You also need to remove the LSD carrier if you want to put a lunchbox locker in.
    There is no real cheap & easy way to put a locker in your truck.
    Options?
    1) Remove LSD carrier. Install ARB carrier, gear setup, air compressor, air lines, etc.
    2) Remove LSD carrier. Find OPEN carrier and install lunchbox locker (spider gears). Gear setup because of the open diff.
    3) Remove LSD carrier. Install some other type of locker that will require gear setup.
    4) Find TRD e-locker 3rd member - I don't know the details, but probably still just as expensive as the above options.
    You realize - once again - you'll have to get rid of the LSD?
    Doesn't the LSD give you enough traction? Why do you want to get rid of it?
  7. Mar 30, 2010 at 7:50 PM
    gtmiller1001
    Greg
    Houston, TX
    Shit. I think I'll stick with the LSD. To be quite honest, I have not had a problem with traction yet, just thought this would be a good project :D I would like to control the rear and lock it when I want to instead of relying on the truck to "sense" how it needs to distribute power. (and yes i know there are ways to "trick" it into doing what you want with the e brake and all) guess i'm just a control freak!
  8. Mar 30, 2010 at 7:54 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    From the sound of your needs the LSD should be sufficient... if not, invest in a towstrap and a come-along hand winch.
  9. Mar 30, 2010 at 7:54 PM
    Brunes
    Brunes abides.
    Rotorhead
    If you haven't found yourself in a situation where you have said "Shit-I can't go any farther without a locked rear end" then don't worry about a locker right now.
    I've gotten my sport thru plenty of places/obstacles without issue...Someday I'll lock it...but right now I can spend the cash on something else.
  10. Mar 30, 2010 at 7:56 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Thats what I was thinking...you can do it right sometime down the road when loot doesn't matter much. :eek:
  11. Mar 30, 2010 at 7:59 PM
    gtmiller1001
    Greg
    Houston, TX
    nuff said. I'm good with what i've got. I've got that "bug" to work on the truck lately. This weekend is coilover install, AAL re-install (after TSB) and grillcraft install:D
    The reason I got started on this was that I thought the salvage yard still had my 06 that was previously totalled (it had the locking rear diff). I was going to try and pickup the entire rear end from them, but it's gone......Then I got this urge to just find a way to lock the back.
    These urges are why Visa loves me!
    Thanks everyone for all the help, this forum has to be the most informative automative source i've seen to date!
  12. Mar 30, 2010 at 8:08 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    they have one for landcruisers only 8 7/8 ring gear dia.
  13. Mar 30, 2010 at 11:00 PM
    Janster
    Jandy
    Lancaster, PA
    Sell it and get a new truck with 4WD and a locker!!!
    Visa might not love you, but your bank will. :D:D
  14. Mar 31, 2010 at 5:40 AM
    gtmiller1001
    Greg
    Houston, TX
    lol...i would love a 4x4 but honestly don't really need one. it's one of those things that would be great to have but a little unnecessary for me. when it's actually time to get rid of mine i will definately get a 4x4 but for now i got what i got (and she's only got 50k on her).
    besides, i have to buy the wife a new lexus before i get a new truck :(
  15. Mar 31, 2010 at 7:42 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or just go to junk yard, find transfer case, electronics front diff and convert your truck to 4x4
    better yet put solid axle o n the front :D
  16. Mar 31, 2010 at 7:57 AM
    Janster
    Jandy
    Lancaster, PA
    Umm...... it's cheaper to go with his original idea of putting a locker in the rear.
  17. Mar 31, 2010 at 8:13 AM
    gtmiller1001
    Greg
    Houston, TX
    yeah, I'd really like to just swap the entire rear end out with a stock tacoma's that had the e locker.
    i'll probably just keep checking the local salvage yards for one and try to do some haggling.
  18. Mar 31, 2010 at 8:23 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Toyota is making deals now... get a 2010 Off Road TRD 4WD... and have the best of all worlds, even if you don't go off road... now you can if the desire is there!
  19. Mar 31, 2010 at 9:13 AM
    BlueT
    NorthEast
    yea but that will be still 2wd even with the locker... :D
  20. Apr 1, 2010 at 7:42 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Just put the parking brake on 2 clicks to lock it up when needed....
