LSD Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lowrange, Oct 26, 2016.
  1. Oct 26, 2016 at 7:08 PM
    lowrange
    lowrange [OP] Supreme Commander of the Army of the Tacoma
    Joe
    Are Can Saw
    15 TRD Sport
    2015 Sport - ready to change differential and transfer case oils.
    No LSD sticker on rear and no mention of LSD oil in the manual. Only reference in the manual states: Toyota Genuine Gear Oil LT 75W-85 GL-5 or equivalent.
    So my question is do I need LSD oil/additive?
  2. Oct 26, 2016 at 7:09 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Why are you changing the oil in these?? It's by no means needed or required...
  3. Oct 26, 2016 at 7:11 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Don't listen to ^ guy. You definitely want to change it, every 15k is a good measure.
    To answer the OP, no you don't need an additive. Just make sure it is 75-85 or 75-90 that meets GL5 standards or better.
    stickyTaco, TacoCat and Nimble9 like this.
  4. Oct 26, 2016 at 7:13 PM
    NewRider
    Travis
    '87 4runner
    Waste of time and money but ok..
  5. Oct 26, 2016 at 7:13 PM
    T Fades
    Simi Valley, CA
    Waste of a few bucks to make a $30-35k truck last long? I'll take my chances.
  6. Oct 26, 2016 at 7:15 PM
    NewRider
    Travis
    '87 4runner
    Last long??? Ask the first gen guys how many times they change those oils... hell I've got almost 250k on mine with 1 swap because I swamped it... and it's still fine!
    Lester Lugnut likes this.
  7. Oct 26, 2016 at 7:23 PM
    lowrange
    Joe
    Are Can Saw
    15 TRD Sport
    Listed as part of the 30K service
  8. Oct 26, 2016 at 7:25 PM
    NewRider
    Travis
    '87 4runner
    Ok... i'm out then.. I know not everyone has grown up around mechanics but it seems like we all understand that the suggested service intervals (minus oil changes) are just bogus..
  9. Oct 26, 2016 at 7:28 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    LOL. Those pesky fluid change intervals. Its all just a big conspiracy.
  10. Oct 26, 2016 at 8:29 PM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Did you noticed all of the metal shavings that cover the drain plug magnet? Total worth the $40 in gear oil just to get those shavings out IMO
    TacoCat, JeffreyB, T Fades and 2 others like this.
  11. Oct 26, 2016 at 8:34 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure what the 2015 manual says, but the Warranty & Maintenance Guide for my 2013 recommends "inspecting" the transmission oil every 30K miles, but doesn't recommend changing it, under "normal" operating conditions. (Not a good plan.) It does, however, recommend "changing" the transmission oil every 30K miles under "special" operating conditions (i.e., Driving while towing, using a car-top carrier, or heavy vehicle loading).
    In spite of all that, I also recommend changing dino oil every 30K miles (and synthetic every 60K miles).
  12. Oct 26, 2016 at 8:36 PM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Changed mine every 50 or so. Not hard to do at all.. takes about 20ish minutes if you know exactly what you are doing.
  13. Oct 26, 2016 at 8:44 PM
    lowrange
    Joe
    Are Can Saw
    15 TRD Sport
    I was talking about the differentials and transfer case, not the transmission.
  14. Oct 26, 2016 at 8:49 PM
    Norton
    Sorry. I wasn't clear enough - IIRC, recommendations were similar for the diffs.
  15. Oct 26, 2016 at 8:51 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  16. Oct 26, 2016 at 9:22 PM
    brah.coma
    brah.coma Well-Known Member
    06 2.7l 5spd 4x4 Reg Cab
    As a trained mechanic we typically know what we can get away with. But I would never recommend my behavior to another owner. Too many variables and not my personal responsibility. I think they call it "preventative maintenance." Similar to how they teach us to do both sides wheel bearings (& calipers) when only one goes out. It's not a matter for a practicing KIA.
    Biscuits likes this.
  17. Oct 26, 2016 at 9:27 PM
    Pigpen
    Dan
    Northwest Montana
    OP, Mobil 1 is a popular option. No, you don't need the additive. If the only oil on the shelf has additive, it won't hurt.
  18. Oct 26, 2016 at 9:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just had my 15 Manual out the other day as I was doing the 15K Maintenance and it had changing out Front and Rear Diff under "Special" section.
    Norton[QUOTED] likes this.
  19. Oct 26, 2016 at 9:38 PM
    Pigpen
    Dan
    Northwest Montana
    The regular interval is 30. I tow and haul a lot. At 30 the rear is ready for a change. The front isn't usually, but I often do anyway.
  20. Oct 27, 2016 at 5:19 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    2015 Tacoma Owners Manual rear diff calls for:
    Toyota Genuine Differential Gear Oil LT 75W-85 GL-5 or equivalent
    LT = non slip differential
    No mention of LX - Toyota's LSD oil in the 2015 owners manual
    shakerhood likes this.
