LSD or not how to tell
Discussion in 'Technical Chat' started by bowzerdoo77, May 31, 2010.
  1. May 31, 2010 at 9:39 PM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I just bought a 2005 reg cab 4x4 about a month ago how do i tell if i have a LSD besides the obvious.. (go get stuck) anybody know if there is a way to tell by a stamp on it or did all 05's that were not trd off road come with one or not thanks...
  2. May 31, 2010 at 9:40 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    If you have lsd there should be a sticker on the rear diff that says "LSD oil only" or something to that effect.
  3. May 31, 2010 at 9:43 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    1. There should be sticker on rear diff that says LSD oil only. Sticker is next to the fill plug on the diff.
    2. lift the rear axle (both tires in the air), try to spin one wheel with your hands. If you can not then you have Limited slip diff.
  4. May 31, 2010 at 9:44 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    ^ What he said. My 07 had that sticker but to engage it you gotta learn how to feather the brake!
  5. May 31, 2010 at 9:45 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    allright thanks ill do it..
  6. May 31, 2010 at 9:47 PM
    BlueT
    NorthEast
    No need for brakes if it is working correctly ...
  7. May 31, 2010 at 9:49 PM
    DWreck
    Derek
    Las Vegas, NV
    I had lsd in my 07, no way to turn it on without braking technique! No lsd switch or traction control off.
  8. May 31, 2010 at 9:55 PM
    BlueT
    NorthEast
    I have 07 too with LSD, Its always ON since it is mechanical. It just works unless clutch packs are burned out. ;)
  9. Jun 1, 2010 at 7:41 AM
    DWreck
    Derek
    Las Vegas, NV
    Well then maybe I just expected too much from mine! Oh well, got a 2010 4x4 now so no worries! lol
  10. Jun 1, 2010 at 7:44 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I had LSD once, it was great, but the flashbacks are a bitch!
  11. Jun 1, 2010 at 7:46 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    :eek: too funny...!!!
  12. Jun 1, 2010 at 7:48 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  13. Jun 1, 2010 at 7:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    The LSD is an option for the reg cab but only with the V6.
  14. Jun 1, 2010 at 7:59 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    The LSD can be ordered on almost any truck. My truck is a base model truck with no TRD option and has the LSD. However his front will be open. All fronts will be open.
  15. Jun 1, 2010 at 8:40 AM
    BlueT
    NorthEast
    Its not a locker for sure but depending where you going maybe a bad thing or good thing.
  16. Jun 1, 2010 at 8:44 AM
    Cyrusjj
    Cyrusjj SHREDITOR
    Charlotte NC
    2015 Tacoma Prerunner
    VICE UNLIMITED custom bumper PRP Race Seats Advanced Fiber Glass Bedsides and fenders Baja Kits Pre-Runner Long Travel Front suspension Kings 2.5 Reservoir Front Coil overs Total Chaos Gusseted front spindles Camburg Rear Bed Cage Camburg Spring Under Long Travel Rear Deaver Rear Leaf Packs Kings 18" Triple Bypass Rear Shocks Pedal Commander Tru-Trac diff 4.77 Re gear aFe Momentum Gt Intake System aFe Mach Force 3" Cat Back System Spider Trax 1.5" Rear spacers Full LED swap out throughout Shift Knob, Climate knobs, radio knobs Rear View relocation bracket Expedition Essentials 2TPAM USB Powered Accessory Mount All Pro IFS Skid Plate All Pro Apex Rock Sliders Kicker Q series speaker upgrade throughout Cerwin Vega 10" sub under Driver seat Alpine 4 channel X-A70F Amp under passenger seat. 1200 Watt Inverter Dynamat on floors and inner and outer doors HID Headlights Power Stop Drilled and Slotted Front rotors Ceramic brake pads BFG KO2 315/70 R17 Method NV Wheels Caliraised Light Bar Future Plans URD Supercharger
    If you start having visual sometimes auditory hallucinations...............then it could be LSD
  17. Jun 1, 2010 at 11:33 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Your more than welcome to come and drive my truck. The picture I posted above is off of my base model 07 Tacoma non TRD, with LSD. There are many trucks here on this site with such a setup. It is certainly a possibility.
    I have however never tried to build one on the net. They even have a few on the lots here and in Texas.
  18. Jun 1, 2010 at 11:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your truck is also a DC V6, so it is available on that model. It is not on available on a 4 cyl reg cab, which is what the OP has.
  19. Jun 1, 2010 at 11:43 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    So my 05 off-road double cab LSD or no?
  20. Jun 1, 2010 at 11:47 AM
    jusmac
    jusmac Well-Known Member
    if you have LSD you will also have have soem wires running along the brake lines to the hubs as well as the stickers and such.
    my LSD only engages when the passenger side rear starts to spin. Ive never seen and LSD that doesn't work along this line?
