LSD or not how to tell
Discussion in 'Technical Chat' started by bowzerdoo77, May 31, 2010.
  1. Jun 1, 2010 at 11:52 AM
    jusmac
    jusmac Well-Known Member
    sorry i meant other lines. Mine has the brake lines and then another set of steel lines running along the brake lines into the hubs. then the wires as well
  2. Jun 1, 2010 at 11:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Those might be wheel speed sensors for VSC, regardless they are not an indication of having an LSD.
  3. Jun 1, 2010 at 11:58 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Oh I know I have a locker. So if you have a locker you don't have LSD ??
  4. Jun 1, 2010 at 11:59 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Driving would tell you plenty. An open doesn't do this.
    http://www.youtube.com/watch?v=R2SUMttis4s
    Ok try this. My neighbor has an 06 single cab 4x4, with a 4 cylinder with an LSD rear and open front. Its not magic, this is a possible setup and could be this way for the OP. It may not be popular but there are some out there.
  5. Jun 1, 2010 at 12:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    If you have the locker you have an open rear diff until the locker is enabled.
  6. Jun 1, 2010 at 12:07 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    So locker means open got it. That's all I wanted to know.
  7. Jun 1, 2010 at 12:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I just built this but couldn't post a link to the page properly.
    The model you selected...FeatureDescriptionPrice7503 Reg Cab 4X4 4 Cyl 5 Speed Manual
    $20,160.00
    Mechanical Performance
    -5-Speed Manual Transmission
    -Outboard Mounted Shocks
    -16" Styld Steel Wheels, P245/75r16 Tires
    -Automatic Limited Slip Diff (Auto Lsd)
    -Coil Over Shock Double A-Arm Front Susp
    -Multi-Leaf Rear Suspension w/Staggered
    -Power Assisted Fr Disc/Rr Drum Brakes
    -2.7l 4cyl Dohc 16v Vvt-i 159hp Engine
    -Power Assisted Rack and Pinion Steering
    -4wdemand: Part-time 4x4 Sys w/ 2-Speed
    -Electronically Controlled Transfer Case
  8. Jun 1, 2010 at 12:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    Then he has the ALSD that comes with VSC/TRAC. Again, not a mechanical LSD.
  9. Jun 1, 2010 at 12:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes the electronic that comes with VSC/TRAC, not the mechanical LSD
  10. Jun 1, 2010 at 12:21 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    That little build I made was in reply to this.^
    The 06 tacoma my buddy has is a base model truck. With LSD the mechanical not the ALSD. His truck is not a TRD. Is it really that hard to believe that this can exhist?
    I've never seen an open diff spin both tires. Your saying if you have 100% traction on 1 tire the LS will spin that tire? The name says Limited slip because when a tire begins to slip it is supposed to send some of that power to the other tire. Hence the limiting the slippage.
  11. Jun 1, 2010 at 12:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes considering Toyotas own words are that the LSD is a V6 option ONLY
    http://www.customtacos.com/tech/files/specs/06/06_options.pdf
  12. Jun 1, 2010 at 12:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    His carfax says his truck has never been to a shop, as does the dealership he purchased it from. But we all know how dealerships can be. He purchased the truck with 18k miles on it. All I can say is that it is in the yard with a 4 and LSD.
  13. Jun 1, 2010 at 12:34 PM
    98tacoma27
    Ben
    Not Beech Creek
    The same can be said with Carfax. It has to be aftermarket.
  14. Jun 1, 2010 at 12:43 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I'm not sure what you were saying in the first paragraph? The truck in the video is mine, it is LSD. Nothing I have said is based off of the video. I'm also not trying to prove you wrong just get you to understand that it is possible to have an LSD rear in the OP's truck.
  15. Jun 1, 2010 at 12:45 PM
    #35
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    All I can say about his truck is that maybe it had the rear replace with another toyota rear end drum to drum. His dealership says it was an ordered option. As is the LSD on my truck, it doesn't have a package just somone ordered they truck with LSD.
  16. Jun 1, 2010 at 12:53 PM
    #36
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Info is coming from Hampton Toyota and Musson Patout. The video is mine I know you can't see it. I posted the build because you said you tried to build a regular cab truck with LSD and couldn't. ALSD is still a form of LSD just different workings. I understand my truck and the op's truck are different but I was comparing to show that just because it wasn't an option online doesn't mean it wasn't possible. With the package my truck has I am supposed to have open diffs front and rear, however somone ordered just the LSD rear on my truck. The same could have been done for the OP.
  17. Jun 1, 2010 at 1:35 PM
    #37
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    100% not true. Mechanical LSD that was installed on TRD Sports, Double Cabs Long Beds, and as the option in others will work with the wheel in the air...
    Mine delivers around 150 lb-foot to the wheel with other one in the air. With axle on jacks you can not turn wheels unless you use some brute force.
  18. Jun 1, 2010 at 2:17 PM
    #38
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    But it was a ranger. I am not coming down on Ford just that they are different unless you know for a fact that they are the same. My Chevelle rear is different from my Tacoma. I have never had 1 rear wheel in the air while on an incline to say it doesn't work but having a rear tire in the air in 2wd with the LSD functions just fine. Speaking about my 02 tacoma and my 07 tacoma.
  19. Jun 1, 2010 at 3:22 PM
    #39
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Na, but the 1 time I drove through a pasture to get to a bon fire. That was tricky as hell. I had a modified lsd (clutches, springs.) It was a blast.
  20. Jun 1, 2010 at 4:51 PM
    #40
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I count those as times you need a camera, and in my case I never had one.
