LSD rear diferencial oil in a TRD Offroad NON LSD truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBBsti LTD, Oct 2, 2012.
  1. Oct 2, 2012 at 8:18 AM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    All the 75W90 oils at my local autoparts say LSD in the label. My truck is a 2010 TRD OffRoad with a locking rear differential.
    Is the LSD oil OK for the rear differential?
  2. Oct 2, 2012 at 8:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, it will be fine. They're probably likely just LSD compatible and do not actually contain the additive required for a limited slip rear end. Regardless, you will not have any issues using them in a non-LSD differential.
