LSD standard on 2007 Tacomas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BanjoScott, May 30, 2015.
  1. May 30, 2015 at 8:02 PM
    BanjoScott
    BanjoScott [OP] Member
    Were limited slip differentials standard on 2007 Tacomas? Or Really pre-2009 tacomas?
  2. May 30, 2015 at 8:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Only standard on TRD sport and double cab long bed
  3. May 30, 2015 at 8:15 PM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Is there a mechanical solution to adding one to a 2014?
  4. May 30, 2015 at 9:05 PM
    BlueT
    NorthEast
    For any 2009+ I think best option is truetrac in the rear diff. You can always install factory LSD from 2005-2008 truck.
  5. May 30, 2015 at 9:07 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I don't see why you would spend the money to add an aftermarket LSD when you could add an aftermarket detroit locker for a similar price, or even better a selectable locker like an ARB for a little bit more than an LSD is going to cost you.
  6. May 31, 2015 at 6:19 PM
    BanjoScott
    Mine's an SR5, looked at the diff but didn't see "LSD fluid only." Just a sticker that said "CBS" not sure what that means. Either way, very happy with this truck.
