LSD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BCTaco14, Jul 26, 2011.
  1. Jul 26, 2011 at 12:12 PM
    BCTaco14
    BCTaco14 [OP] Well-Known Member
    How do you know if you have an LSD?
    I have a 2006 Tacoma SR5 TRD Sport
  2. Jul 26, 2011 at 12:12 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You have an LSD for sure.
  3. Jul 26, 2011 at 12:13 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    All TRD Sports prior to 2009 have a mechanical LSD
  4. Jul 26, 2011 at 12:16 PM
    BCTaco14
    great to know. You guys are the breast!
    Thanks again WW Firefighter!
  5. Jul 26, 2011 at 12:21 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    lolwat
  6. Jul 26, 2011 at 12:38 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
  7. Jul 26, 2011 at 12:45 PM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
  8. Jul 26, 2011 at 12:48 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Are the walls melting?
  9. Jul 26, 2011 at 5:32 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    For others, there is also a sticker on the differential warning you to use the LSD additive or approved oil. There are just 4 model years with the clutch pack mechanical limited slip (2005-2008).
  10. Jul 26, 2011 at 9:46 PM
    kanaka808
    kanaka808 Well-Known Member
    jason
    henderson
    2010 4x4 sport
    what does 09+ have??
  11. Jul 26, 2011 at 9:47 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Just say no.
  12. Jul 26, 2011 at 9:53 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    TRAC and auto LSD which uses the brakes rather than clutches to control wheel spin.
    plus for a 4wd you get lsd in the front too
  13. Jul 27, 2011 at 6:59 AM
    David K
    Just a follow up: AUTO LSD is TRAC in 2WD but without any engine output regulation (ie. more power and a stronger limited slip action). To help confuse the names, Toyota also calls AUTO LSD the "TRAC OFF MODE".
    In H4, TRAC (as it is still called) has no engine output regulation (like AUTO LSD).
    Yoytoda makes an excellent point that since 2009, all 4WD Tacomas have limited slip in the front and rear in H4 (4WD HIGH RANGE).
  14. Jul 27, 2011 at 10:04 AM
    Yoytoda
    Roland
    completely stock
    i think you meant to say that in 2wd there is engine regulation.
    and to recap on my point of lsd front and rear on all 09+ tacomas this means my $18,000 tacoma has the same traction aids as a $30,000 TRD sport :cool:
    you dont get anything extra except seats and color matched stuff with the trd sport over an SR5
  15. Jul 27, 2011 at 10:11 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    What about the bed outlet?
  16. Jul 27, 2011 at 10:20 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    LSD?? ---------------> YES PLEASE :goingcrazy:
  17. Jul 27, 2011 at 1:23 PM
    Yoytoda
    Roland
    completely stock
    oh yea, well worth an extra $1000 or 2 ;)
  18. Jul 27, 2011 at 1:27 PM
    Yoytoda
    Roland
    completely stock
    yes but you have an OR i was comparing a sport to an sr5. still has the room the v6, trac. so the gap is much smaller between the sr5 and the sport compared to the OR which has real enhancement for traction like ATRAC and locker and start and downhill assist.
    all worth extra money since it is easier to paint parts than install locker and atrac and other e goodies
  19. Jul 27, 2011 at 3:14 PM
    David K
    That is what I was saying, just in this way...
    What I said: "AUTO LSD is TRAC in 2WD but without any engine output regulation"
    This is correct, because TRAC in 2WD has engine regulation (and AUTO LSD does not)... or more visual:
    H2: TRAC, engine regulation.
    H2: AUTO LSD, no regulation.
    H4: TRAC, no regulation.
    The big problem (IMO) is Toyota uses the name 'TRAC' for both H2 and H4 limited slip, but between H2 and H4 they are different in degrees of strength.
    Thanks for the comment and allowing me to clarify! Have a great day!
  20. Jul 28, 2011 at 4:42 PM
    MattDubs
    MattDubs Well-Known Member
    St. Augustine, FL
    6" Procomp
    Soooo... I Have a 06' DC SR5 PreRunner and to this day Ive bee told and have always thought I had an open rear end since its not a TRD model... That was until I went to the beach today and gassed it pretty hard only to see both wheels kicking up sand!
    WTF?
