LT AXELS???
Discussion in '1st Gen. Tacomas (1995-2004)' started by bruth, Oct 15, 2013.
  1. Oct 18, 2013 at 10:32 AM
    bruth
    bruth [OP] Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    After I modified the inner cv joint
  2. Oct 18, 2013 at 10:37 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    yes you can!!!!
    i figured it out!
    i have manual hubs and have tundy axles in my truck right now with it all together. i ahvent had a chance to run them yet
    You must have OEM tacoma axles, and OEM tundra axles, as long as you have that, the spline counts will be the same.
    on a manual hub tacoma you must swap the tacoma outer CV joint onto the tundra axle shaft. as long as you have both OEM cv axles, the spline counts will be the same!
    when i called Mike at ORS he told me the same thing.
    ***note-- i have not ran them yet, but they are together on my truck, i am waiting for brake lines.
    trucks looking good man!!
  3. Oct 18, 2013 at 5:05 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I scored my tundra axles from auto zone, with lifetime warranty for like $200 or something.
  4. Oct 18, 2013 at 7:59 PM
    bruth
    Brian
    Alamo ca
    nice!!!! Does anyone know what the best/most affordable high angle (long travel) CV boots are? I have found a couple but idk what to go with ill need the clamps too!
  5. Oct 18, 2013 at 8:10 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    930 bates. I got a link to part # somewhere....I will find it
  6. Oct 18, 2013 at 8:19 PM
    DIRT YOTA
    Cory
    Camarillo, CA
  7. Oct 18, 2013 at 9:07 PM
    bruth
    Brian
    Alamo ca
    Hell ya thanks buddy el rojo!!!!!
  8. Oct 19, 2013 at 12:01 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Fo sho man! :thumbsup: looking forward to see ur build come together! 1st gens FTMFW! :)
  9. Oct 19, 2013 at 2:09 AM
    bruth
    Brian
    Alamo ca
    Sweet man I'm ordering the boots tomorrow !!!
  10. Oct 19, 2013 at 12:26 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    so a set of OEM manual cv's and a set of OEM tundra cv's (i am pretty sure all tundras are ADD right?) then just combine the the Tacoma ends with the tundra mid shafts?
  11. Oct 19, 2013 at 12:42 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Yes, Yes, and i think so.
  12. Oct 19, 2013 at 1:57 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Yes and no, the spline count is the same but cv it self is stronger on the tundra.
  13. Oct 19, 2013 at 2:21 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    How is it a yes and no?
  14. Oct 19, 2013 at 2:40 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya don't know why I said yes and no...lol b
    Was merely saying ya splines r same but the tundra cv is a stronger cv then the tacoma. So manual hubs have advantage of unlocking hubs, add has stronger tundra lower and upper cv. :D
  15. Oct 20, 2013 at 12:11 AM
    #35
    bruth
    Brian
    Alamo ca
    Ya I guess it's alot better cause when you unlock the manual hubs then it completely disconnects the axels from the drive so there is no ware! And Tacoma is always engaged except the drive gear in 2wd
  16. Oct 21, 2013 at 2:49 PM
    #36
    4runnercaged
    cody
    arizona
    LOL
    yes you are correct.
    and cut off the inner lip of the tundra inner cv joint so you can fit the new boot
