LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. May 30, 2019 at 7:00 PM
    #2001
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Ditto; how much on the bypasses? Lol
  2. May 30, 2019 at 7:04 PM
    #2002
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How much for the 10" KC's?
  3. May 30, 2019 at 8:02 PM
    #2003
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    \King 12" 2.5 triples in black 2 pairs
    https://classifieds.race-dezert.com/FOR_SALE:King-2.5-Bypass-Shocks-12-Inch-153921
    New ×2 king 3.5x16 4 tube bypass race series tube lay out to clear beams brand new $3000
    New ×2 king 2.5x14 coilovers with remote resis $900
    New x2 king 2.5x14 coilovers remote resis with 2" extended rod ends. $900
    New ×4 king 2.5x4 bumps ×2 4130 cans $1200
    https://classifieds.race-dezert.com/FOR_SALE:Parting-out-beamed-ranger-build-153786
    @FlapJack935
    2nd Gen TC LT
    https://classifieds.race-dezert.com/FOR_SALE:Toyota-Tacoma-GEN-2-Long-Travel-Kit-153625
    Fox 3.0 12" 4 tubes black
    https://classifieds.race-dezert.com/FOR_SALE2)-sets-New-Black-Fox-Shocks---3.0-x-12"-Quadruple-Bypass-153200
    3.0 18" Triple Bypass- $1500
    2.5 16" Double Bypass- $850
    2.5 16" Dual Rate Coilovers- $800
    4" Air Bumps (spacer currently installed shortening to 2")- $240
    https://classifieds.race-dezert.com/FOR_SALE:Used-King-Shocks-153799
  4. May 30, 2019 at 8:12 PM
    #2004
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    @GT7 grab the first ones. 12” triple bypass.
  5. May 30, 2019 at 8:20 PM
    #2005
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I already got 12” shocks just not bypasses. I just ordered my archive stuff yesterday so no money anyways :pout:
  6. May 30, 2019 at 8:37 PM
    #2006
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Didn’t remember if you had them or not.
    GT7[QUOTED] likes this.
  7. May 30, 2019 at 11:33 PM
    #2007
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I don’t think those bypasses would fit the Archive kit, I was told remote only. I put a 14” triple in there, kinda wish I had put a 12”.
    GT7 and Dalandser like this.
  8. May 30, 2019 at 11:35 PM
    #2008
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I converted a pair of bypasses to remote - not too much work unless you don't want to take them apart.
    Supra4x4[QUOTED] likes this.
  9. May 30, 2019 at 11:41 PM
    #2009
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Ahh, that’s true. Even still, a 2.5 bypass has to be the right tube layout, even with the tubes facing forward and 1.25 spacers, I’m close to rubbing tubes on articulation.
    GT7 and Dalandser[QUOTED] like this.
  10. May 31, 2019 at 8:05 AM
    #2010
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    That TC kit has been for sale for awhile now.
  11. May 31, 2019 at 8:06 AM
    #2011
    desertjunkie760
    Shane
    Check My Sig.
    Why do you say a 12"? I thought you were extremely happy with the 14".
  12. May 31, 2019 at 8:06 AM
    #2012
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I've posted it a couple times.
  13. May 31, 2019 at 8:07 AM
    #2013
    desertjunkie760
    Shane
    Check My Sig.
    It's definitely a complete kit and pretty much ready for install. Not sure about the pricing, I haven't added up everything.
  14. May 31, 2019 at 8:10 AM
    #2014
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Can’t utilize a 14” with soa.
  15. May 31, 2019 at 9:19 AM
    #2015
    desertjunkie760
    Shane
    Check My Sig.
    You can make a SOA cycle 14" of travel, or close to it. Just takes a lot of work and the right equipment. Unless you're specifically talking about bypass'?
  16. May 31, 2019 at 9:28 AM
    #2016
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I’m sure it is possible, but it wouldn’t be clean travel. When I was soa with a shackle flip and extended shackles my leafs would start separating before I could fully droop out my 12” shocks. So if you were strictly rock crawling and didn’t care about leaf separation I’m sure you could run long enough shackles to droop out some 14” shocks. But at that you’re probably not utilizing the full bump travel of the shocks.
  17. May 31, 2019 at 9:41 AM
    #2017
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Yep, 14" is possible but you are going to get leaf separation on droop, inverted springs on bump, or a combination of both.
  18. May 31, 2019 at 9:48 AM
    #2018
    desertjunkie760
    Shane
    Check My Sig.
    Likely going to have some separation on the droop and it'll be tight to utilize all of the shock stroke on bump travel. Forgive me if this is known knowledge, but what is the negative of leaf separation at droop?
    nudavinci64 likes this.
  19. May 31, 2019 at 12:42 PM
    #2019
    zscott
    Zach
    Utah
    I dont know how detrimental it is but when you droop out leaf springs to the point where they are separating or compress them to the point where they are inverting you are just really pushing the limits of the springs and decreasing the life span and increasing the risk of them breaking. Is it possible for them to function fine under those parameters? Sure. Is there a higher risk that they will break or wear out faster? Probably.
    I had 14s with SOA prior to going long travel. It worked fine. Nothing wrong with it but I really only used about 10-11" of the travel range most of the time. You really need the perfect terrain to get it to flex the full 14".
    snowsk8air2 likes this.
  20. May 31, 2019 at 1:19 PM
    #2020
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    @snowsk8air2 hit it right on the money. I am still happy, and I’ll make it work with some modifications (rewelding lower shock mount and tuning bumpstops). I’m using 4.9” shackles and it does help droop out the leafs. The main negative I have with the 14” is the bypass, IE where it sits in the tube zones at ride height right now and the lack of bump travel. I am sure glad I ordered a welded lower rod end though, that shortened up the compressed length by 1”.
