LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. Sep 30, 2019 at 5:41 PM
    #2241
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They'd be perfect - valving from King wouldn't be any different from the factory. Tuning would have to be done anyway even if it was ordered as a "first gen" application since vehicles and driving styles are unique.
  2. Sep 30, 2019 at 6:15 PM
    #2242
    Gatordawg
    Gatordawg Well-Known Member
    Devin
    Santa Cruz
    For some reason I thought it had to do with the positioning of the bypass tubes or something like that, that allowed to mount properly? I’m no expert, just trying to make sure I’m getting the right stuff. So combined with the TC secondary shock hoops these will work no problem?
  3. Sep 30, 2019 at 6:15 PM
    #2243
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Shhhhhh I think @zscott was warming up to my payment plan option.
  4. Sep 30, 2019 at 7:21 PM
    #2244
    Brushape86
    Brushape86 Active Member
    Sonoma, Ca
    Details or more info? Shocks included ?
    LTDSC[QUOTED] likes this.
  5. Sep 30, 2019 at 7:35 PM
    #2245
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah if they fit 2nd gens the tube layout is good for 1st gens.
    LukeCC likes this.
  6. Oct 1, 2019 at 3:14 PM
    #2246
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    1st Gen
    https://www.chaosfab.com/96-04-Tacoma-Long-Travel-Boxed-Lowers-Kit-96000BK.html
    2nd Gen
    https://www.chaosfab.com/2005-2015-Tacoma-2-Race-Series-Long-Travel-Suspension-Kit-86002T-R.html
    Fox part # is the same, King part # is different. You'd have to call and confirm the differences.
    You could definitely make it work, I'm just not sure enough if it would be a direct bolt in to their secondary shock hoop.
  7. Oct 1, 2019 at 6:23 PM
    #2247
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Cycling the suspension needs to be done either way. An 8" shock is an 8" shock. Tube layout is similar to the point where nudging the tabs back an inch wouldn't kill the function of the shocks. You could make them work.
    Gunshot-6A likes this.
  8. Oct 1, 2019 at 6:34 PM
    #2248
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Oct 1, 2019 at 6:37 PM
    #2249
    desertjunkie760
    Shane
    Check My Sig.
    I agree that you could make it work, if you were willing to put in a little extra effort.
    An 8” standard shock could, I believe does in this case, have different ext/collapsed lengths than a spec’d shock which would require additional work to fit. Tube layout should be very similar and non issue
    Edit: I forgot we are talking about a spec’d shock to begin with. Not a standard. Just questioning the difference between 1st/2nd gen. The similar Fox part # makes me believe that any difference is minimal.
  10. Oct 1, 2019 at 6:47 PM
    #2250
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    So he might have to change the rod-end? pretty sure he could get the desired length just by specing a different rod-end. Like @Dalandser an 8" shock is an 8" shock, and rod ends are relatively cheap.
  11. Oct 1, 2019 at 6:53 PM
    #2251
    desertjunkie760
    Shane
    Check My Sig.
    Could be that simple. Could be more complicated.
    Not all 8” shocks are equal. They have different dimensions, especially on a bypass. If TC spec’d a shorter shock body, the bypass zoning will change. So yes, they will both cycle 8” but they will do so in different areas of the travel.
    Again, this is mainly in the comparison of a standard shock to spec’d. I believe @zscott has a spec’d shock to begin with which makes these comparisons irrelevant for the most part.
  12. Oct 1, 2019 at 8:12 PM
    #2252
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can look and see the zones are almost identical if not exactly identical. As much as things are able to be slightly different - with cycling and making sure things clear you won't have an issue.
    LTDSC likes this.
  13. Oct 1, 2019 at 10:18 PM
    #2253
    desertjunkie760
    Shane
    Check My Sig.
    We are obviously not communicating well on the topic at hand so... :thumbsup:
  14. Oct 1, 2019 at 10:28 PM
    #2254
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Dude idk why you don't accept people don't have to build everything like a lego set. Looking to buy everything from a parts list isn't the only way that great builds happen.
  15. Oct 2, 2019 at 6:16 AM
    #2255
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Next he will say he’s building for short track and never see dirt and change kits about 6 times. :rolleyes:
  16. Oct 2, 2019 at 6:38 AM
    #2256
    desertjunkie760
    Shane
    Check My Sig.
    That’s not at all what I am saying. I actually believe quite the opposite if you’re willing to put in the time and have the ability.
    The original question was if “x” shock would fit a pre built kit from TC. Much like a “LEGO set.” My response was only an example of part #s to show that there may be a difference between the two. I don’t know what those differences may be, which I’ve stated. I’ve also stated many times that you could make it work, if you have the ability and willing to put in the time but it may require some modifications to your pre-built kit.
    I even tried to drop the conversation because it’s obviously redundant and you and I aren't speaking the same language so idk why you’re trying to call me out.
  17. Oct 2, 2019 at 6:48 AM
    #2257
    desertjunkie760
    Shane
    Check My Sig.
    No, I’m actually building for for AutoCross. I just wanted 4x4 to pull off the line quicker and go around the little cones. I don’t understand why people want to take their trucks in the dirt. :jerkoff:
    Coot83 and LTDSC[QUOTED] like this.
  18. Oct 4, 2019 at 5:55 PM
    #2258
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  19. Oct 7, 2019 at 4:26 PM
    #2259
    orbot
    orbot Well-Known Member
    Looking for 2.5 14” coilovers
    I preffer fox but bilstein could work
  20. Oct 7, 2019 at 5:00 PM
    #2260
    soggyBottom
    soggyBottom Well-Known Member
