LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. Oct 11, 2020 at 7:06 AM
    #3181
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    Im about and hour south of Tucson, I currently have 700s if he hasn't bought them already.99CE65A3-6FCB-472E-BAA9-FBF56DC6BEB4.jpg
    Dalandser likes this.
  2. Oct 11, 2020 at 7:13 AM
    #3182
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    He does lol. I’m in flagstaff with his springs and he’s in Scottsdale. No clue when he’s coming up to get them and he hasn’t been too active on here lately. But I’ll text him and tell him to check on here and see if you two can’t work something out
    Coot83 likes this.
  3. Oct 11, 2020 at 7:16 AM
    #3183
    NcTaco27
    Brenton
    East Tennessee
    How bad do you think these 700s will ride on a stock weight front end lol.
  4. Oct 11, 2020 at 7:29 AM
    #3184
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What kit? What valving? And how are you driving the truck? I like the 700’s for taller ride height and that little bit of extra support on hard hits. But it definitely took some valving changes to make it soak up the smaller stuff as well.
  5. Oct 11, 2020 at 10:07 AM
    #3185
    NcTaco27
    Brenton
    East Tennessee
    It’s the JD 2.25 kit. Idk the valving but the last guy said it was soft on his dirt king kit, but idk what he had hanging on the front of his truck. And I go from crawling to flying in the same day.
  6. Oct 11, 2020 at 10:24 AM
    #3186
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    So pretty similar use to myself lol. Honestly I’d give the 700’s a shot and see if you like them. The internal bypass will help with small chattery stuff that would typically be a little harder to tune with the higher spring rate
  7. Oct 11, 2020 at 10:29 AM
    #3187
    NcTaco27
    Brenton
    East Tennessee
    I tried to get AccuTune to tune them and throw some springs on them but they won’t touch since they are IBP. I only got them cause they were 3/4 of the original price and don’t want to pay for bypasses rn. But I do have the correct spring plate That fixes preload. I just need to throw them on.9C3DC637-2AEF-4319-9C59-655328818CCE.jpg
  8. Oct 11, 2020 at 10:48 AM
    #3188
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Strange that they won’t touch them. And are you 4wd? Those spring plates look fine but the rod ends are definitely for a 2wd. Either way I’d get those shocks set up correctly for the JD kit and run those springs to see how you like them.
  9. Oct 11, 2020 at 10:51 AM
    #3189
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    FWIW all major brand 2nd gen lt kits I’ve seen use extended rod ends
    snowsk8air2 likes this.
  10. Oct 11, 2020 at 10:56 AM
    #3190
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ok I wasn’t sure if it was just 4wd to clear the axle or not
    Dalandser[QUOTED] likes this.
  11. Oct 11, 2020 at 11:06 AM
    #3191
    NcTaco27
    Brenton
    East Tennessee
    The JD fab kit lets you use the stubbies. I was basing my shock setup on his kit. They are both standard 8” kings but he has custom fittings and a different spring plate. So I did the same. And yes it’s 4wd, I have the 934s ready to go with my kit.
  12. Oct 11, 2020 at 11:09 AM
    #3192
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    His kit doesn't have a lot of the same geometry as major brand kits hence being able to use standard length rod ends.
    whatstcp and NcTaco27[QUOTED] like this.
  13. Oct 11, 2020 at 11:10 AM
    #3193
    NcTaco27
    Brenton
    East Tennessee
    All about the pocket.
  14. Oct 11, 2020 at 11:26 AM
    #3194
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    @Coot83
    Coot83 likes this.
  15. Oct 11, 2020 at 12:13 PM
    #3195
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I have his sitting at my house for whenever he comes up next lol.
  16. Oct 11, 2020 at 12:15 PM
    #3196
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Looking for a set of 2.5x14 in fox coil overs and a set of 2.0 bumps threaded or non threaded and a set of 2.5x12 triple bypasses. Thanks in advance
  17. Oct 11, 2020 at 1:07 PM
    #3197
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    These are off the truck now and available.
    Fox 2.5 16" dual bypass shocks.
    Shafts are good.
    No leaks.
    New seals and oil earlier this year.
    Light rash here and there.
    SOLD
    20201011_115549.jpg 20201011_115434.jpg 20201011_120015.jpg 20201011_120113.jpg 20201011_115522.jpg 20201011_115719.jpg 20201011_115724.jpg 20201011_115947.jpg
    SOLD
  18. Oct 11, 2020 at 5:37 PM
    #3198
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yep and getting the cv away from the shock
  19. Oct 11, 2020 at 10:34 PM
    #3199
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Hey man are you still going to need 600s when I take mine off?
  20. Oct 11, 2020 at 11:45 PM
    #3200
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    anyone got some Total Chaos 3.5" shafts laying around they want to sell?
