LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. May 22, 2021 at 7:17 PM
    #3921
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Pategonias are great. Why are you trying to DD a Taco with 37s? o_O
  2. May 22, 2021 at 8:02 PM
    #3922
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Short commute, but honestly I doubt it will be much worse than 35’s of the same width and 4.88s that I have now. We have transmissions that seem to want to shift to 5th as soon as mechanically possible so it’s the same shit- push the pedal to makey go go.
  3. May 23, 2021 at 6:23 AM
    #3923
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Love them and no I don’t daily drive it. But the tires have worked amazing in every terrain I’ve thrown em at. Only complaint I’ve heard from people is they don’t last long. But then I’ve also heard of full-size trucks getting 40k out of them with proper rotations and tire pressure. Either way my truck is primarily an off road use truck (only drove 3k miles last year) so longevity doesn’t really matter to me.
    Dayman Karate[QUOTED] likes this.
  4. May 23, 2021 at 6:25 AM
    #3924
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I was running 4.56 when I jumped to the 37’s and power wasn’t bad. Granted I have a supercharger. Biggest complaint with the 37” is braking. That actually was very noticeable. But my recent switch to 5.29 is where it’s at
  5. May 23, 2021 at 6:27 AM
    #3925
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That’s my biggest concern and reason for jumping to 17” wheels. Hoping to fit at the minimum some larger 4Runner brakes.
  6. May 23, 2021 at 6:35 AM
    #3926
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yep I did that pretty quickly after making the jump. That said even after a good brake bleed the pedal will feel softer with the 4Runner brakes. There’s a thread on here somewhere that talks about it and it’s a common problem with that swap. Basically the Tacoma master cylinder doesn’t push enough fluid for the 4Runner calipers larger pistons. If your truck has a vacuum booster then you can swap a tundra master cylinder and booster for about $500, but if you are like me with the electronic brake booster you’re screwed.
  7. May 23, 2021 at 8:37 AM
    #3927
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  8. May 23, 2021 at 10:50 AM
    #3928
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    I did the 4Runner brake swap and while I do have a bit of a soft pedal, it’s still way better performance over stock. On 34s and in the rain my truck could hardly stop going downhill, there was a few times where it didn’t stop at all and I had to use the e brake. I couldn’t imagine the braking with 35s or bigger. I also added ss brake lines which helped with the mushy pedal some.
  9. May 23, 2021 at 7:06 PM
    #3929
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Did the same on just 33’s and didn’t notice a huge gain until I did the tundra brake master cylinder. That made the biggest difference.
  10. May 23, 2021 at 8:11 PM
    #3930
    yaaj2005
    yaaj2005 Well-Known Member
    Fang
    Sacrament, CA
    2014 Toyota Tacoma TRD
    pics... only if you were 1 week earlier... just bolt some all pro lt shaft...damn... it always like like... when you need it, you don't see any, when you just buy them... they come up... maybe a spare???
  11. May 23, 2021 at 10:30 PM
    #3931
    DanaPtTaco
    Thomas
    Orange County, CA
    I mean the difference it makes is relative and different for every person. I'm surrounded by hills so that might also effect things. The Tundra mc swap is a big job from what I've read so unless the oem one doesn't cut it for me anymore I'm content where I'm at.
  12. May 23, 2021 at 11:32 PM
    #3932
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Unless you have the master with abs built in it’s really not hard at all. I paid like 250 for a junkyard master and booster and then made an extension for the pedal rod. Other than that you just have to make two jumper lines since the tundra master ports are on the opposite side and are 12mm instead of 10.
  13. May 23, 2021 at 11:47 PM
    #3933
    DanaPtTaco
    Thomas
    Orange County, CA
    You did an LS swap... your definition of not hard at all is far from my definition :rofl:
    rheath08 and EatSleepTacos like this.
  14. May 24, 2021 at 12:08 AM
    #3934
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    fair….lol
    YotaFAB and DanaPtTaco[QUOTED] like this.
  15. May 24, 2021 at 12:24 AM
    #3935
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  16. May 24, 2021 at 5:56 AM
    #3936
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I've been DDing Patagonias for a couple years, no complaints. The Wrangler Duratrac is a better tire, but it's almost 2x the cost, and it's not anywhere near 2x better.
  17. May 24, 2021 at 6:13 AM
    #3937
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    that’s good to hear. I looked at the Patagonias for 35’s but discount tire gave a good deal on cooper mtps I couldn’t pass up.
    I saw something on YouTube that said the Patagonia’s need to be inflated enough to ride on that center tread pattern of the tire because it’s a crowned tire? Not sure, but they were saying not to do a traditional chalk test on these and try to cover the whole width when driving on the highway.
  18. May 24, 2021 at 7:43 AM
    #3938
    Arcticelf
    Gladiator
    Nice.
    I run mine about 45PSI on pavement, but the sidewalls are super stiff, so I can air down to 12 or so for rocks and 8 for snow.
  19. May 24, 2021 at 7:56 AM
    #3939
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I came from running duratracs the last 10 years. I’d say they are very comparable tires. Don’t know that I’d say one is better than the other but they are both great tires.
    Weird, I’m running 27psi on the street and seem to get even wear. But then yeah drop down to 15 or so in the dirt
  20. May 24, 2021 at 7:59 AM
    #3940
    desertjunkie760
    Shane
    Check My Sig.
    I keep my street driving around 35 PSI and have noticed that the Pategonias ride in the center, as @Dayman Karate mentioned. Never really looked into it more. Just an observation. I run roughly 18 PSI in the dirt depending on what we're doing.
