LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. Mar 1, 2022 at 8:08 PM
    #4681
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Also with the 934s remember your have to notch the frame. So I’d say it’s a wash if your paying for that to be done.
    BurlyJim likes this.
  2. Mar 1, 2022 at 8:14 PM
    #4682
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    None on my radar.
    Dalandser[QUOTED] likes this.
  3. Mar 1, 2022 at 8:20 PM
    #4683
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Stock outer joint still with jd. And a warranty up to 40” tires. The jd stuff is awesome and I’m running a bit of it on my truck but the axles I think are a good/ not best option.
    Also this vs straight bolt in
  4. Mar 1, 2022 at 8:27 PM
    #4684
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Mar 1, 2022 at 9:00 PM
    #4685
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Why? If you can spend the $160 on getting the inners machined vs the 2k on RCVs and not have axle issues because things aren’t binding.
    With those odds, I’d risk the possibility of breaking axles a few times before going out and spending the extra money.
    To each their own I guess. :notsure:
    kasnerd likes this.
  6. Mar 2, 2022 at 5:15 AM
    #4686
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I guess after having 2 dk axles break on me under circumstances where I don’t think they should have broken, I just don’t like having to deal with that.
    BurlyJim, tacotunner06 and Airdog like this.
  7. Mar 2, 2022 at 7:28 AM
    #4687
    desertjunkie760
    Shane
    Check My Sig.
    Not that I disagree with the inconvenience, but I'd have to break more than two CVs to spend 2k on replacements. You also wheel substantially harder than most of the people out there. I guess my point is RCVs aren't for everyone looking to go LT.
  8. Mar 2, 2022 at 9:53 AM
    #4688
    BeeRadd
    BeeRadd Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    I've heard great things about those RCV's. If I get a super charger, or 4 link the rear, those will definitely be in order.
    I think if you're a moderate wheeler that went LT so it's less harmful on the truck and to go a little faster, the cheaper option is for you (me).
    But if your turnin heads in cinder hills like ol Ryan up there, then yeah those axles are probably the way to go lol.
    Just my .02
  9. Mar 2, 2022 at 10:44 AM
    #4689
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Issue with comparing the rcv’s and 934’s is the 934’s are 28 degrees compared to factory 21 but I can’t find anything stating what the rcv axles are capable of. Cause the two limiting factors for droop on lt kits with horizontal heims will be uniballs on the uca and cv bind.
  10. Mar 2, 2022 at 12:30 PM
    #4690
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    True and if you aren’t running big tires or running in the rocks a lot then the cost probably outweighs most of the benefits. Big tires, supercharged and rocks it was on the list of needs for me for a while.
    I keep forgetting to try and measure this because it has been brought up before. But I can say that they eliminate them being the limiting factor for droop. I’m limited by the uca uniball only now
  11. Mar 2, 2022 at 2:10 PM
    #4691
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Maybe it makes more of a difference on shorter LT kits since the angles at drop out are steeper? Just spitballin’ :notsure:
  12. Mar 2, 2022 at 2:45 PM
    #4692
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    yeah I wanna say we’ve talked about it in Harry’s thread before about trying to determine cv angles. I just know anyone who says rcv’s are indestructible just hasn’t tried hard enough…lol. At KOH we were camped next to some guys who broke both their rcv front axles (granted they are solid axle front) so their not indestructible. They ended up getting some other axle shafts from someone and they had to cut and shorten their housing the night before qualifying…
    snowsk8air2[QUOTED] likes this.
  13. Mar 2, 2022 at 2:51 PM
    #4693
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Either way though @snowsk8air2 i would say that though these options are more expensive than just machining the cup I would say they are both preferable by far.
    BurlyJim and snowsk8air2 like this.
  14. Mar 3, 2022 at 9:24 PM
    #4694
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  15. Mar 4, 2022 at 1:26 PM
    #4695
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Are you talking about the Curt Leduc Swap Meet? I'll be there but I'm not from Phoenix
  16. Mar 4, 2022 at 6:42 PM
    #4696
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
  17. Mar 4, 2022 at 7:17 PM
    #4697
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah it is.
    My thoughts too
  18. Mar 4, 2022 at 9:36 PM
    #4698
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    Yea, was looking for a Phoenix person to give money to snag parts then I’d pick them up in 2 weeks when I’m out there.
    2004Taco[QUOTED] likes this.
  19. Mar 4, 2022 at 9:49 PM
    #4699
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You need more parts? Isn't that like Fort Knox needing more gold?
  20. Mar 4, 2022 at 11:34 PM
    #4700
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
