LT classifieds
Discussion in 'Long Travel Suspension' started by TC yota, Jan 22, 2017.
  1. Apr 14, 2022 at 2:57 PM
    #4821
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    I still have the springs from the Radflo 16”-650 at the house. I can get pics tonight if you want.
  2. Apr 14, 2022 at 4:58 PM
    #4822
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Apr 14, 2022 at 6:48 PM
    #4823
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    How much preload do you currently have in the 600s and why not add a little more to obtain your desired ride height?
    TMFF likes this.
  4. Apr 14, 2022 at 7:26 PM
    #4824
    orbot
    orbot Well-Known Member
    Good question
  5. Apr 14, 2022 at 10:27 PM
    #4825
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
  6. Apr 15, 2022 at 12:47 AM
    #4826
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hold out for the H70HD’s with a dclb
  7. Apr 15, 2022 at 1:44 AM
    #4827
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Ahh, Roger that. I wasn’t sure where I would be with the DCLB. Thanks for that. Hoping I’ll be able to redo the rear of the truck by the end of the year. Then it’ll be really time for some mobbing
  8. Apr 15, 2022 at 5:17 AM
    #4828
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    these springs won’t allow any more lift oven if I go more pre load, at least based off measurements.
    RoaminRoman likes this.
  9. Apr 15, 2022 at 7:04 AM
    #4829
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  10. Apr 15, 2022 at 9:18 AM
    #4830
    desertjunkie760
    Shane
    Check My Sig.
    Gotcha, you're concerned about binding. How much actual preload is in the spring? I run 16x600 springs and only have about .75" of preload IIRC.
  11. Apr 15, 2022 at 11:12 AM
    #4831
    orbot
    Sometimes the spring is not the actual solution
  12. Apr 15, 2022 at 11:24 AM
    #4832
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Wouldn’t it be dependent on how much weight one plans to carry? I’ve been chatting with some of the other guys who have gone down the h70 route with JDfab, on DCLB, some measuring 9+ inches of up travel from ride height. I planned to go this route as well with a frame notch, but I usually don’t carry much more than my spare and a tool box.
  13. Apr 15, 2022 at 11:40 AM
    #4833
    desertjunkie760
    Shane
    Check My Sig.
    I'm curious to know what you're implying.
  14. Apr 15, 2022 at 12:21 PM
    #4834
    orbot
    Maybe be wrong, each truck is different but maybe your issue is valving
    i have played with a few shocks and some times the valving is the thing to put attention on and not just the spring tate
  15. Apr 15, 2022 at 12:29 PM
    #4835
    desertjunkie760
    Shane
    Check My Sig.
    The complaint wasn't mine originally but I don't disagree.
    @NcTaco27 complaint is ride height which is directly related to spring rate/preload. Valving has no effect on ride height.
    Airdog likes this.
  16. Apr 15, 2022 at 4:48 PM
    #4836
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Im
    Could be their kit - Dirt King uses HD’s, most 1st gen race trucks use them too. I’m only getting 6.5” of up travel with my H70’s on my extra cab 1st gen with dual 35” spares, a jack, and a cantilever kit.
    RonRon23[QUOTED] likes this.
  17. Apr 19, 2022 at 9:05 AM
    #4837
    NcTaco27
    Brenton
    East Tennessee
    I’ll have to measure pre load, but those who want to notch frame with jd fab kit beware of negative arc. I’m not really %100 sure if this amount is bad but it might wear the springs out, idk just thought I’d throw that in since I haven’t seen anyone else frame notch with the kit. But I get about 10” of up travel.
    Edit - I ended up ordering 18" 600lb king springs from down south, so well see how they work.
    RonRon23 likes this.
  18. Apr 21, 2022 at 1:17 PM
    #4838
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Any 2.5 x14 smoothies for sale? Need some for my 06. Lmk
  19. Apr 21, 2022 at 1:33 PM
    #4839
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I have H70's with bed cage and only bedsides (DCLB). I didn't think I wanted the heavier springs of the HD's but I'm really regretting that decision now. I may have 4" of up travel to the bumps. Worse decision I ever made. Made even worse by selling my old springs before I really tested the new springs.
    On a similar note, does anyone know the difference in the two springs (H70 vs H70HD)? Is it the whole pack or just 1 or two main springs that give it the extra carry (lift) capacity.
  20. Apr 21, 2022 at 1:52 PM
    #4840
    orbot
    Want new or used?
