LT Front and Rear?
Discussion in 'Long Travel Suspension' started by iJDub, Apr 4, 2013.
  1. Apr 4, 2013 at 8:21 AM
    iJDub
    iJDub [OP] Well-Known Member
    Do most people just LT the front? and some people do both? Seems like most kits focus on LT for the front.
  2. Apr 4, 2013 at 8:23 AM
    Large
    Large Red
    From what I have read, it's more important to do a good rear LT setup, but yes most people do the front first.
  3. Apr 4, 2013 at 8:25 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    As mentioned in other threads. LT front is a terrible end goal. you will never get the full potential out of it. Most people do the front first with hopes of doing the rear. It is an expensive route to go. So thats why you see alot of people with just front kits. The rear requires some custom fab work. at a minimum a simple bed cage, cut through the bed with longer shocks, leafs , shackles and mounts.
  4. Apr 4, 2013 at 9:23 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    You can bolt on a front kit, any rear kit is going to involve fabrication and welding. That's why you see more trucks with front LT than rear LT.
    Rear LT is arguably more important and essential to use a front LT kit to its full potential.
