LT front Mid Rear???
Discussion in 'Long Travel Suspension' started by RiverBoyTRD, Apr 29, 2013.
  1. Apr 29, 2013 at 7:47 PM
    RiverBoyTRD
    RiverBoyTRD [OP] Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    I plan this set up in the near future. Leaning towards TC as of right now for the front and the rear I already have a shackle flip and plan expos within a built +1 shackle.
    There will be no 'high-speed' anything, so I never really though about LT the rear. I should be able to run a set-up like this correct? I plan on making the jump to 35-37 within the next 8 months, if that changes glass options?? Or should I rethink my plans?
  2. Apr 29, 2013 at 7:49 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    lt rear+mid front > lt front mid rear
  3. Apr 29, 2013 at 8:11 PM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    I'm stock, and fully approve of this. this will be my journey once she is paid off :eek:
  4. Apr 29, 2013 at 8:19 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Could you expand on this?
  5. Apr 29, 2013 at 8:22 PM
    jberry813
    jberry813 The Mad Scientist
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You'll get better performance out of rear LT and mid front than the other way around. If you LT the front first, the rear is always trying to catch up and ends up bucking the shit out of you, especially with a shackle flip kit which further reduces uptravel.
    There's no advantage to run LT up front if you're not going to be running fast. You can do the same thing with a solid MT setup.
  6. Apr 29, 2013 at 8:23 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    In the future I want to go with a TC 2" up front with Icons and an AP expo pack with shock relocate, shackle flip and 12" shocks for rear. And some hydro bumps in the rear too. I think that would work well for my uses. not doing anything really fast.
    Edit - May not be necessary but really badass. Something like Mr Grimms setup.
  7. Apr 29, 2013 at 8:29 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    I always wanted atleast a 35. I figured with a shackle flip I'd still get the most travel without having a big stopper to keep the tires from stuffing the body.
  8. Apr 29, 2013 at 8:30 PM
    stephen11ty7
    stephen11ty7 Well-Known Member
    Stephen
    Villa Park
    07 white taco
    Total Chaos 2" LT, Icon coilovers
    X2 why would you consider LT if you aren't planning anything high speed? That is its main purpose... The kits are built to be stronger and take that kind of abuse.
  9. Apr 29, 2013 at 8:36 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Added trac width, more travel
  10. Apr 29, 2013 at 8:39 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You can fit 35's without LT. Just need a grinder and your favorite BFH. Plenty of guys have done it on here.
    Its a common misconception that a shackle flip increases travel. It doesn't..at all..and in most cases decreases overall travel. It increases downtravel (droop), but at the sacrifice of uptravel.
  11. Apr 29, 2013 at 8:50 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    I never said it increased travel, I know it doesn't. I got it to to keep the highest point of travel further away from the body.
    I know I don't need LT, but besides new rims there really is no way to Increase trac width. I mean if I have to go full LT front and read it really is no issue, just added expense of read glass as well.
  12. Apr 29, 2013 at 8:53 PM
    anthony250f
    Anthony
    San Diego, CA
    you dont need rear glass with long travel....but it would be wise if you want 35s
  13. Apr 29, 2013 at 8:57 PM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    But with all that front travel the rear won't be able to keep up..
  14. Apr 29, 2013 at 8:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I like to think of modifications as an "as needed" basis. What is it you're doing that requires more track width? Second gen tacomas already have a WMS-WMS of 65". To put things in perspective a bit, a stock first gen taco is only 60" WMS-WMS and a first gen TUNDRA is 66".
    I'm not trying to change your mind about LT, but LT is pretty much the most damn expensive bolt on modification you can do to your truck...and it never ends. Once you go LT, you'll keep pushing it and shit always breaks and you're going to always be fixing it. My truck's been on jack stands almost as much as it's been on tires.
  15. Apr 29, 2013 at 9:18 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    I have 2nd vehicle so downtime doesn't matter my taco is my toy. I don't see how the rear as to 'catch up' in terms of travel. If nothing I do is over 40mph??
    I am under the impression that long travel was the way to go, for maximum droop and stuff. Or can a well built mid do just as good in rocks and off camber stuff?
  16. Apr 29, 2013 at 9:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Speed means nothing without terrain. Doing 40mph through Barstow main with your truck and the rear of your truck would damn near flip over the front from bucking so hard.
    Just saying, if I was in your shoes, based off what I read I'd just do a mid-travel setup and save the money I would of spent on LT for hookers and blow.
  17. Apr 29, 2013 at 9:26 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    So you're saying is mid travel then with leftover cash fly to lake tahoe and buy us hookers and blow, sounds reasonable
    ....do you have a boat?
  18. Apr 29, 2013 at 9:30 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Sounds like a plan to me :cookiemonster:
    I personally don't own the boat, but I have access to one.... with two supercharged 350s in it. :burnrubber:
  19. Apr 29, 2013 at 9:32 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Beats my waverunner that only fits 2 :rofl:
  20. May 10, 2013 at 10:39 AM
    Bubbarr
    Bubbarr Monkey Sweat
    Duane
    SD
    TRD Off-Road 4X4
    DynoLock Auto tailgate lock, 16" Konig Counter steer Off roads, 265/75/16 Goodyear Wrangler Duratracs, 2.5 King front and rear with remote reservoir, Built Right UCA, Deaver 3 pack, SD Truck Shop Custom Sliders.
    sounds like you should just stick with a mid travel
