Lt front with mid rear advice.
Discussion in 'Long Travel Suspension' started by FixedTRD, Feb 22, 2011.
  1. Feb 22, 2011 at 10:53 PM
    FixedTRD
    FixedTRD [OP] Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    After seeing so many nice looking LT trucks here I really want to LT my truck as well. Here is my question I currently have the all pro 1.5 full leaf with the fox 2.0 with piggy in the rear. I am debating to run either engage or the all pro LT, really leaning towards engage tho, can I still run it with my rear setup and Lt the front for now until I can save and do the rear or would the rear give out?
  2. Feb 23, 2011 at 8:04 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    You'll have a pretty bad bro lean and the front end will way out perform the rear, but yea you can do it.
  3. Feb 23, 2011 at 8:15 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you can, but honestly the way to if your going to LT one end and have the other mid trav, you want to LT the rear first
    what are you running in the front suspension?
    here is prob the best bang for you buck to LT the rear
    http://www.definedengineering.com/products.html
    i had LT front and mid trav rear and it was fun, but i couldn't really use the front close to it's full potential because once going a good speed through rough terrain and whoops the rear end would start to buck and kick up... had to slow down to keep control of the truck
  4. Feb 23, 2011 at 8:55 AM
    FixedTRD
    Will
    Alhambra, CA
    You have the All Pro LT right? How does that work out for you, what type of rear setup are you running thanks.
  5. Feb 23, 2011 at 11:19 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i been running LT up front and mid travel in rear.... hasn't stopped me yet out in the desert...
    my broken motor mount stopped me, but other than that, the set up has survived the past 2 years...
    you won't be able to drive as fast as the trucks fully built front and rear, but if you don't have the money to do it all at once, then take your time and do it all in pieces...
  6. Feb 23, 2011 at 4:03 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    why do people say do the rear first? saving to buy nelson18matts front end...
  7. Feb 23, 2011 at 4:05 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    the rear bucks like crazy, and cant keep up with the front suspension
  8. Feb 23, 2011 at 4:48 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    what Paul just said...
    although if you know how your truck rides, and get familiar with the terrain, you can still have your fun until you get the money to do the rear...
    you don't necessarily have to build the truck up so quickly if you don't have all the money at once...
    nothing wrong with building the truck up in stages...
    just a matter of how you want to do it and in what order...
  9. Feb 24, 2011 at 7:38 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  10. Feb 26, 2011 at 12:56 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Yes I do. Works very well and is a very durable/well built kit.
    I'm running an AP 3'' leaf pack, Timbren bumpstops, and Fox 2.0 RR's in the rear. The rear is a world improvement over stock, but a world away from an LT rear end. Just go look at the back end of your truck and look at how much distance there is between your bumpstop and your frame. Just a couple of inches, that's all the up travel you get without going LT.
    So when you go airborne and the rear has a chance to unspring itself and hang down a little, it soaks things up really well. But when you're just running down a rough road, it only has that couple of inches worth of travel to work with to soak up the bumps.
    I plan on picking up an ATO shackle flip kit to add some travel, as well as swapping out to hydraulic bumpstops. I have the bumps, I just need to buy some mounts and weld them on.
  11. Mar 2, 2011 at 12:16 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    haha matt that is a serious buck!
  12. Mar 2, 2011 at 2:36 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    haha, yeah dude, that was before rear LT
    that was scary and unexpcted, i hit the jump and then all of a sudden all i saw was the ground and was like "oh crap!"...lol
  13. Mar 5, 2011 at 12:22 AM
    FixedTRD
    Will
    Alhambra, CA
    Thanks everyone but I got the All pro LT kit.
  14. Mar 13, 2011 at 9:43 PM
    FixedTRD
    Will
    Alhambra, CA
    Kit installed by my little boy.
    Dalandser likes this.
  15. Mar 13, 2011 at 9:49 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    :drool: ur trucks is badass....
  16. Mar 13, 2011 at 9:50 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
  17. Mar 13, 2011 at 9:56 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    You taught that kid well! Looks awesome!
  18. Mar 13, 2011 at 10:01 PM
    FixedTRD
    Will
    Alhambra, CA
    Hahah yes he's a fast learner. Thanks everyone I will post up better pics this week.
  19. Mar 13, 2011 at 10:05 PM
    S.B.
    Sean
    Faster than I was. I was taking apart and puting my dike together at 5. And hes what? and working on your truck. Lucky. Can't wait to see that thing in the desert.
  20. Mar 13, 2011 at 10:08 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    looks bad ass brotha... cant wait to see it at mod day!!!
