LT information
Discussion in 'Long Travel Suspension' started by BeEatNU, Mar 15, 2013.
  1. Mar 15, 2013 at 10:23 PM
    BeEatNU
    BeEatNU [OP] Well-Known Member
    Nick
    Gardena, CA
    2013 Tacoma Double Cab Limited
    I tried searching but I am so lost, even google didn't help me.
    What is the point of LT suspension? What's the difference between ie. King coil overs and some FT suspension.
    sorry for the question!
  2. Mar 15, 2013 at 10:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    dumbing it down..
    LT uses longer arms in the front and different rear setups to get way, way more travel out of the truck's suspension
    It's mainly used for high-speed desert running, so the beefier coilovers and bypasses you see on the trucks are used to control movement of the suspension at speed.
    LT guys jump their trucks, run over whoops at speeds that would destroy normal trucks.
  3. Mar 15, 2013 at 10:40 PM
    BeEatNU
    Nick
    Gardena, CA
    thanks good sir.
    I very much appreciate it.
  4. Mar 15, 2013 at 11:10 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
  5. Mar 15, 2013 at 11:19 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    You can also crawl with LT!
  6. Mar 16, 2013 at 7:20 AM
    BeEatNU
    Nick
    Gardena, CA
