LT install help!
Discussion in 'Long Travel Suspension' started by Lil'Taco, Sep 6, 2012.
  1. Sep 6, 2012 at 7:50 PM
    Lil'Taco
    Lil'Taco [OP] Well-Known Member
    Scotty
    Corvallis, OR
    2010 PreRunner Sport DCSB
    Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights, aFe CAI, Borla Cat-back exhaust, Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts.... It has more stuff done to it now.
    Oh yeah, I heard about doing that before but thought it was just getting them into the UCA, I thought it was to easy to do that, This must be what they were talking about.
    I'm going to go try this.
  2. Sep 6, 2012 at 7:50 PM
    Anteupp
    Anteupp Mega Member
    Andrew
    South East Wisconsin
    Total Chaos Long Travel 4x4, Fox Coilovers, DMZ spring under, 16" king tripple bypasses, Garage built bedcage/bumper, full cage coming soon...
    Like others have said it will fit, those poly bushing have plenty of give. Your just not trying hard enough listen to people with LT trucks
    and have installed stuff before. Take a big flat head screwdriver or thin crowbar and wedge it in between the bushing and bolt sleeve then push one way and slip the washer in. Once the washers in get someone to help you tap it in. I did my whole install + tower gussets which make this task even harder believe me it's doable just keep tryingand have patience hahahah
  3. Sep 6, 2012 at 7:50 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    Yeah those things haha
    Cool let us know if it works!
  4. Sep 6, 2012 at 8:35 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    I was attacked by a swarm of misquitos because of my work light so I had to call it for the night. I'm letting the bushings and washers sit in the freezer over night. Try in the morning and post results.
  5. Sep 7, 2012 at 6:42 AM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Good luck. Im watching this cause this is the kit I m going to install
  6. Sep 7, 2012 at 10:34 AM
    Lil'Taco
    Scotty
    Corvallis, OR
    Well freezing the bushings over night really did nothing for es of installation. But I was able to get everything out last night before calling it a night.
    Sooooo I talked to the guy that welded up my spindles last night and he said to either try spreading the UCA or grind a little off the coil bucket side of things. So I improvised.
    The wood started to bend and crack but I was able to spread the UCA just about 3/32" and tried it on for size
    OOOOH THAT'S A BINGO!!!!
    So now that I have a solution to the problem on to the rest of the install, I dropped the spindles off last night with Jeff (one of the fabricators) from Red Label Off-road in Vacaville. Never heard of anything about them but had been by their shop before and they had some pretty nice projects going on inside so it seemed legit enough for me. The guy I dropped the spindles off with ended up taking them home last night to weld them up and had the ready for pick up this morning at 9!!!!
  7. Sep 7, 2012 at 10:37 AM
    Large
    Large Red
    Beef
  8. Sep 7, 2012 at 10:43 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Nice! glad you got the main problem figured out!
  9. Sep 7, 2012 at 11:02 AM
    rondog
    rondog your TW web developer!
    Ronnie
    Escondido/San Diego
    I remember this when I installed mine...big flat head and another person to help out did the trick
  10. Sep 7, 2012 at 11:11 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    YOU BENT YOUR UPPERS!?!?!?!
    that wasnt a very smart move, that bushing is rubber, the washer will fit.
  11. Sep 7, 2012 at 11:37 AM
    Lil'Taco
    Scotty
    Corvallis, OR
    I talked it over with a shop first. We decided it was just when they manufactured them. Since they were in a jig they probably tweaked a little from heat and when they were pulled out came in a little. THERE WAS NO OTHER WAY THE WASHER WAS GOING TO GO IN:facepalm: (next to grinding metal), trust me I'm not new when it comes to automobiles, plus it was so extremely minuet it shouldn't do anything.
    And in retrospect a big pry bar and force is really the exact same thing.
  12. Sep 7, 2012 at 11:43 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    I had to beat.the.fuck. out of my truck to get the allpro long travel to fit. BFH to every mounting bracket.
    My uppers fit ok though...
  13. Sep 7, 2012 at 12:08 PM
    97yota4wd
    Eric
    Mesa, AZ
    gotta do whatcha gotta do i guess! i guess i have done some dumb shit on my truck so i cant really complain haha
  14. Sep 7, 2012 at 12:21 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Benjamin
    Marysville, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I had this same problem when I installed my UCAs. It was a pain and took a long time getting those washers in. If you don't mind me asking, how much did this kit run you? I'm looking into getting this kit and I couldn't find any pricing information on it.
  15. Sep 7, 2012 at 12:25 PM
    #35
    TenBeers
    TenBeers Well-Known Member
    Rich
    Wildwood, MO
    2012 DCSB TRD Off Road Magnetic Gray
    Factory Roof Rack, Westin Tube Steps, AVS Bugflector and Wind Deflectors, RideRite Air Bags, Custom Bed Rack, CVT Roof-Top Tent, Weathertech Floor Mats, Redline Hood Supports, Pop-N-Lock Tailgate Lock, some stickers
    Glad you got the project moving. Personally, I would have tried a c-clamp to compress the first bushing some to give more room on the second side to pound the washer in, using a little synthetic grease. There looks like a good spot to slip one in there with the other end on the UCA (chunk of wood in between to keep it pretty).
    But sometimes you gotta get mad and go Hulk on stuff.
  16. Sep 7, 2012 at 12:29 PM
    #36
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it is just tubing so it will bend but the powder coat probably cracked
  17. Sep 7, 2012 at 12:30 PM
    #37
    Lil'Taco
    Scotty
    Corvallis, OR
    I don't remember exact prices but I think they run around 2600 for just the kit
  18. Sep 7, 2012 at 12:31 PM
    #38
    Large
    Large Red
    I think we've all been down that road :anonymous:
  19. Sep 7, 2012 at 12:45 PM
    #39
    Lil'Taco
    Scotty
    Corvallis, OR
    Ok, Upper and Lower installed.
    Does it really matter which way the resi goes? Is it easier for it to be mounted to the front or rear? And if I decide to switch it up later would it be a problem switching the left and the right shock around?
  20. Sep 7, 2012 at 12:48 PM
    #40
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Congrats on the LT kit man. You'll love it.
