LT install help!
Discussion in 'Long Travel Suspension' started by Lil'Taco, Sep 6, 2012.
  1. Sep 7, 2012 at 12:49 PM
    #41
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    see of frame to the right? thats where a majority of people clamp the resi.
  2. Sep 7, 2012 at 12:59 PM
    #42
    Lil'Taco
    Lil'Taco [OP] Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    Yeah I looked around and decided that's where I'll do mine too.
    On another note, when attaching the shock to the upper mounting plate I tighten the bolt and nut so far and it seems to be catching a notch on the inside of the nut. It's the same for both plates to I guess it's suppose to be this way. My question is do you tighten it past that point or is it suppose to be loose (it doesn't make since to be loose but I've never dealt with a nut like this).
  3. Sep 7, 2012 at 1:03 PM
    #43
    tostidos
    Apple Valley, CA
    07 LT 6spd
    get the adapter level as possible so the flats dont catch. Tighten it down its not meant to be loose. Also I wouldnt over torque it as it will rotate there a little.
  4. Sep 7, 2012 at 1:15 PM
    #44
    Lil'Taco
    Scotty
    Wilsonville
    Oh yeah torque.... The only two torque specs I've found with the kit are for the nuts that attach the spindle. I looked in a Haynes manual for suspension torque specs and found the same two numbers. Is there somewhere where I can get torque specs from for everything else? Or is it all the same (tight)
  5. Sep 7, 2012 at 1:24 PM
    #45
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Id talk to camburg on torque specs. But i do know that you will beed to check all your bolt for torque after 50-100 miles. they will loosen up and offroading will get them loose as well constantly check your bolts on your kit.
  6. Sep 8, 2012 at 12:42 AM
    #46
    Lil'Taco
    Scotty
    Wilsonville
    So I painted the spindles before putting everything back together.
    Put all the parts back together and had to "reshape" the left brake dust shield. It was kinda weird that I had to do the left but not the right...:confused:
    Brakes on bleed and wiring all rerouted
    Wheel on and how it sits with no weight on the front
    Took it for a quick spin down the street and the left Dust shield still rubs a little, but only in reverse...? So I'm going to have to see whats up with that tomorrow.
  7. Sep 8, 2012 at 12:48 AM
    #47
    MySilverTaco13
    MySilverTaco13 Well-Known Member
    HBSoCal
    2012 Trd sport PreRunner
    :drool: sick truck im jelly congratulations :D so u getting some glass soon??
  8. Sep 8, 2012 at 7:38 AM
    #48
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    That looks great! I am definitely going with this kit when I decide to go LT. How did it drive besides the reverse issue?
  9. Sep 8, 2012 at 7:45 AM
    #49
    tostidos
    Apple Valley, CA
    07 LT 6spd
    X2 get some glass before you destroy your stock fenders! You'll be able to help pay for glass by selling your fenders.
  10. Sep 8, 2012 at 7:26 PM
    #50
    Lil'Taco
    Scotty
    Wilsonville
    I only drove it down the street and back and it is seriously towed out right now...
    I'll be ordering glass soon enough, before going off road. But I'm taking it to a shop to get all the gussets welded up Monday.
  11. Sep 8, 2012 at 7:28 PM
    #51
    Lil'Taco
    Scotty
    Wilsonville
    Oh yeah there it's day light now
    also got my bike washed today
  12. Sep 8, 2012 at 7:56 PM
    #52
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Thats m kind of car wash ! Looks like they are really scrubbing your seat well.
  13. Sep 8, 2012 at 9:08 PM
    #53
    MySilverTaco13
    HBSoCal
    whats your rear set up man?
  14. Sep 9, 2012 at 1:50 AM
    #54
    Lil'Taco
    Scotty
    Wilsonville
    ATX Artillery Wheels and Nitto Terra Grappler tires... As of right now that is all the rear is. I have plans for the same rear that FixedTRD was by DMZ, pretty much a rear shock hoop that doesn't cut the bed of the truck and allows somewhere around 12-14" of travel.... I think.
  15. Sep 9, 2012 at 4:25 AM
    #55
    MySilverTaco13
    HBSoCal
    awesome shoot some front LT vids for the peeps :D
  16. Sep 9, 2012 at 11:16 PM
    #56
    Lil'Taco
    Scotty
    Wilsonville
    By the way, I want your front bumper! fenders and bumper are next on my list then hopfully DMZ has found someone to start making a kit like your rear to be sold as a DIY sort of kit.
  17. Sep 13, 2012 at 11:36 AM
    #57
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Congrats!
