LT kits and interchangable parts - Allpro Total Chaos
Discussion in 'Long Travel Suspension' started by BohlaaH, Mar 22, 2016.
  1. Mar 22, 2016 at 6:12 AM
    BohlaaH
    BohlaaH [OP] Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    I live in Canada where polyurethane bushings wear out quickly so this puts heims out of the question. I am looking at the allpro LT kit and am wondering if I could do TC uppers with the kit? The allpro have stainless Teflon lower uniballs but the upper is chrome plated which will chip and wear out regularly. Could I do anything to get a stainless uniball in the upper? perhaps just use a TC uniball? Also if any CANADIANS know where to find cheap allpro or TC +2 kits let me know!
  2. Mar 27, 2016 at 9:13 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    the uniballs are interchangeable, a uniball bearing only comes in pretty specific sizes. now interchanging arms is another story. the upper arms were made to work with the counterpart lower, swapping these will most likely screw up the geometry of the kit
    BohlaaH[OP] likes this.
  3. Mar 27, 2016 at 2:34 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Go with the TC kit. It's superior in every way.
    You can put whatever construction uniballs you want into the control arms. If you buy a used kit, I would recommend changing them out before installing. Just call up All Pro and ask what size they are, or wait until you get them and measure. If you have a shop press it's an easy job.
    You can't mix and match control arms. I mean, you can... it's just probably not going to work well. They're build to work with each other.
  4. Mar 27, 2016 at 6:41 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Good answer. I was already foaming over the TC kit, found a used one but I don't have that kind of cash to toss at my truck today. Maybe in a couple months
    ChadsPride likes this.
  5. Mar 29, 2016 at 7:42 PM
    cccrockettt
    cccrockettt Well-Known Member
    David
    central california
    Mid travel front and rear Fox w/ all pro
    Also looking at either all pro or tc long travel in the near future and wanting to know what examples you have on why tc is supposed to be so superior. I have been running all pro upper control arms for the last 70k miles with no issues what so ever. This was causing me to lean more toward all pro.
  6. Mar 29, 2016 at 7:51 PM
    Mxpatriot
    Well, I've been running all pro long travel for the last 5+ years, in addition to their bumpers, sliders, and skids.
    - The design is inferior. No ability to mount a secondary shock, no option for heimed UCAs, and the shock bolt design is prone to seizing up (long, long bolt that has lots of contact with the LCA). TC, and every other manufacturer who uses boxed LCAs, mounts the shock with tabs in a manner that doesn't create a nightmare when it comes time to remove shocks. I've dealt with it several times, it is an absolute pain in the ass to get that seized bolt out - even when it's been coated with anti-seize.
    - The powder coating flakes.
    - Uses a one-off size shock. A standard 8" coil over is too long and a 6" is too short; so you're stuck with one source for shocks - All Pro.
    They are very strong control arms - but so are the other brands.
    Buy whatever you want man. Shoot - I'll sell the kit right off my truck for the right price - and I'll go straight to TC.
    ocherp, 06HAOLE and beertimecontinuum like this.
  7. Mar 29, 2016 at 8:00 PM
    cccrockettt
    David
    central california
    I can see that in the old design but the new design looks like it addressed a lot of those issues. I'm also mainly looking long travel to make it easier to fit bigger than 33s that I have now. Most wheeling I do is slow and in the snow
  8. Mar 29, 2016 at 8:04 PM
    cccrockettt
    David
    central california
    What's the biggest advantage of heimed vs bushing?
  9. Mar 29, 2016 at 8:05 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    shouldn't need LT for 35s. Just a little chop here and there and your good to go
  10. Mar 29, 2016 at 8:11 PM
    Basikbiker
    Trav
    Hiems offer adjustability if you solid mount the lowers, and Hiemed are more of a bearing pivot over bushings, I just finished making sum Hiemed uppers and they are noticeably smoother, my bushings were shot too
  11. Mar 29, 2016 at 8:17 PM
    cccrockettt
    David
    central california
    My truck would require a lot of cutting and either limiting travel in the front or tubing which is more of a job than I want to tackle right now. Plus my end plan is for 37s
  12. Mar 29, 2016 at 10:36 PM
    Mxpatriot
    When you tweak your coil buckets / frame, you're not completely screwed and can still get decent alignment.
    FreidTaco likes this.
  13. Mar 29, 2016 at 10:43 PM
    Mxpatriot
    Why go with a new design from a company with a hit and miss history on long travel suspension when you can get a better kit at the same price from a company with a lot more experience with IFS?
    All pro makes some decent stuff, but they aren't the front runners in IFS suspension.
  14. Mar 30, 2016 at 6:19 AM
    cccrockettt
    David
    central california
    You make a good argument. I still have some time before I buy. I'll keep researching. Who is the best vendor for tc?
  15. Mar 30, 2016 at 9:07 AM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Depends where you live. In Canada I found a few dealers but the states has not bad pricing on toyteclifts.com. Any registered TC dealer will sell it at a good price. SoCalsupertrucks etc. But in Canada heims seize and are basically trash unless you want to change parts a few times a year. Bushings are the way to go and I won't be putting a secondary on my truck so allpro or TC would work for me. I would even buy your allpro kit if you had a good price
    DistortedAxis likes this.
  16. Mar 30, 2016 at 6:01 PM
    Mxpatriot
    Every kit is going to have exposed uniballs, one at the UCA and one at the LCA. A heim is simply a uniball on a rod end.
    I got it, more uniballs = more maintenance, but when the alternative is a truck that won't take alignment and drives like shit... I'd rather replace a few extra uniballs every other year or so.
    It's not a few times a year though... once a year, max. I am at like every other year on my uniballs. I lived in the rust belt of Missouri for years and now I live in Alaska - if you're replacing uniballs/heims several times a year there is something wrong with the uniballs you are using.
  17. Mar 30, 2016 at 6:04 PM
    Mxpatriot
    I'm just giving you guys an honest opinion. At one point, my suspension, bumpers, skids, sliders, etc. were All Pro front to rear. Much of that is still on the truck, some is not.
    The AP kit isn't horrible. It's just not the best of what is available at the price point.
    LTDSC likes this.
  18. Apr 1, 2016 at 5:23 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I vote Total Chaos over All Pro. The customer service over at Total Chaos is among the best I've experienced in the off-road industry.
    I bought my first Total Chaos kit from Downsouth Motorsports and highly recommend them. They are accustomed to shipping parts internationally as well. @Downsouth Motorsports
    Downsouth Motorsports likes this.
  19. Apr 6, 2016 at 11:39 PM
    Redeyejedi
    Redeyejedi In the beard we trust.
    Erik
    Hesperia, Ca.
    2013 pyrite mica 4x4
    Springy metal stuff!
    TC has a great crew. Pat is a smart guy when it comes to Toyota suspension. The parts they fab are race proven. They just killed it in the http://chaosfab.com/gazelle-rallye/ in Morocco. That race beats the crap out of a truck. It held up!
    06HAOLE[QUOTED] likes this.
  20. Apr 9, 2016 at 6:13 PM
    HeisKai
    HeisKai Member
    To one of OP's original concern: Allpro uses 1.25" uniball on UCA. You will NOT be able to find a full stainless 1.25" bore uniball. Only 1" or 1.5"uniball have full stainless version availabe. Benefit of 1.25" uniball is it allows more angle. My TC 2" LT downtravel is limited by the UCA uniball bind.
