LT (light truck) vs. P (passenger) wheels
Discussion in 'Wheels & Tires' started by 2011Tacoma1293, Oct 19, 2011.
  1. Oct 19, 2011 at 12:01 PM
    2011Tacoma1293
    2011Tacoma1293 [OP] Well-Known Member
    Kevin
    Florida
    11 Tacoma 4cyl Barcelona red
    Is there a real difference in the tire between these to? can i put a P tire in a double cab tacoma? or is it LT for a reason? Help would be great cause there is a price difference
  2. Oct 19, 2011 at 12:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got P-rated on my double cab without any issues. I'm also heavier than most because I've got a shell and a bunch of tools. The difference is the number of plys it takes to make the tire. LT tires will be thicker than P rated tires which means they won't squat as easily with weight but also means LT tires are heavier than P rated. FWIW, I tow and haul frequently with my P-rated tires and they do not squat or feel squishy. The tires I'm running are Cooper AT3's.
  3. Oct 19, 2011 at 12:33 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Use caution going from LT to P. You have both load range and speed rating to worry about. (the LT have more plys on side wall if that sort of thing is important to you)
    Mine came with P-rated (245/75/16), dunlops.
    I replaced with LT C load range 245/75/16
    I wanted the extra side wall and deeper tread from the LT version. I might have gone over kill but ride and mpg have not suffered. Note that i kept same size just went more aggressive tread and higher load. I am in a snowy part of the country and didn't want too wide of a tire in the snow.
  4. Oct 19, 2011 at 12:41 PM
    2011Tacoma1293
    Kevin
    Florida
    Now would you go with A general grabber at2 (it will be going on a 17x8.5 wheel)or what other tire do you like that looks nice and agressive for not a bad price?
