LT "look" without the expense
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MOTODOC, Dec 20, 2012.
  1. Dec 20, 2012 at 9:34 PM
    MOTODOC
    MOTODOC [OP] Well-Known Member
    NC—> MN
    2012 TRD sport 4wd
    first off, sorry if i posted this in the wrong section...i have been doing a lot of thinking, and seeing that i may be selling my bike soon, and i have always admired baja racing, i want to turn my '05 taco into a "LT" truck without all the necessities it would need to take an a** beating in the desert and survive.
    so, seeing that i live on the east coast and there is no desert, i will never take my tacoma out to actually jump it or go prerunning; however, i have always loved the stance and look of the long travel trophy trucks and have decided that i want to go that route rather than lifting it straight up like everyone else does in this area.
    currently, i have fox coilovers on the front (dont know the exact model :rolleyes:; they came on the truck when i bought it.....it originally was a california truck)...they have the remote res...and i think i have factory bilsteins in the rear (cant read the lettering bc they are faded). it's a v6 4.0L 2wd prerunner trd offroad ext cab with approx 98k miles as it sits now.
    would love to be able to utilize the fox coilovers if i can, especially considering i do not need 13" of suspension travel, but if i need to buy an entire new set up, i will. im assuming i would need upper and lower control arms along with, at least, some type of leaf set up in the rear. obviously, cheaper is better, but not if it is junk. would love to be pointed in the right direction because i also want to go with a wider tire and a aftermarket wheel (something like a 285 on a 16"-17" wheel), as well as a prerunner bumper.
    also, would it look stupid if i just put fenders on the front and not the rear? whatever "kit" is suggested, i definitely still need to be able to utilize my bed. no need for any bed cage, tire rack, engine cage or boxed frame; this truck will NOT be jumped. i have read the differences between long travel and mid travel kits, but i still would love for actual builders and people who own LT and MT kits on their trucks share their knowledge.:D
    any and all help would be greatly appreciated. and if anyone knows of a local shop in the charlotte/mooresville area that specializes in desert fab work, please let me know.
    thanks!
  2. Dec 20, 2012 at 9:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I have fiberglass and mid travel and it looks absolutely perfect. i am running wheel spacers and 35's so that really fills the gap.
  3. Dec 20, 2012 at 9:40 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    what mid travel kit? and how big of spacers? i would rather shun away from spacers if i can; depending on the thickness.
  4. Dec 20, 2012 at 9:41 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    if your coil overs are adjustable, you can crank em up for that bro leaner style, add some fiberglass and some wheel spacers, you're good to go
  5. Dec 20, 2012 at 9:41 PM
    PLC721
    Patrick
    Chandler, Az
    King Coilovers, DSM Boxed Uca's, All-Pro springs with custom shock hoops and 12" 2.5's in the rear. 1.25" spacers to clear the hoops and matching fronts. as long as they are properly torqued you won't have problems with spacers either.
  6. Dec 20, 2012 at 9:43 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    yeah, but if im cranking them up, do i not need at least need UCA's bc of the amount of stress and negative camber the front wheels will have?
  7. Dec 20, 2012 at 9:43 PM
    PLC721
    Patrick
    Chandler, Az
    yep!
  8. Dec 20, 2012 at 9:46 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    so basically i just need spacers, uca's, crank up the coils...and if i wanna put some 285's on there, and not have to worry about rubbing, get some glass fenders?
    how about the rear? what shock/leaf combo should i go with? i wouldnt mind replacing both rear shocks and the front coilovers if it will give me a little more travel and not but a HUGE dent in my wallet. i figure i can always sell the fox coilovers and someone may want the bilsteins.
  9. Dec 20, 2012 at 9:48 PM
    PLC721
    Patrick
    Chandler, Az
    icon progressive add a leaf and maybe some nice 2.0 or 2.5's will get you about 1.5" lift, question for you though, if you want fiber glass have you thought about a front bumper?
  10. Dec 20, 2012 at 9:48 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    im diggin' your truck. sh*t is sick.
  11. Dec 20, 2012 at 9:48 PM
    BMOC
    Paden
    Phoenix, AZ
    not necessarily. how high do you want to go? lol
    you can also lower the rear to get the same bro rider effect.
  12. Dec 20, 2012 at 9:50 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    i know if i go with glass, i will most definitely get a tube-style prerunner bumper that i would probably want to put at least 3 fogs or a light bar on.
  13. Dec 20, 2012 at 9:51 PM
    PLC721
    Patrick
    Chandler, Az
    okay good, glass with front bumper looks pretty goofy in my opinion!
  14. Dec 20, 2012 at 9:52 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    i dont want to lower the rear bc i still put stuff in the bed and sometimes it's enough of a load that it sinks the suspension; it doesnt bottom out..just dont want to lower the rear.
  15. Dec 20, 2012 at 9:53 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Im looking at doing a similar thing, about to get the baja fenders (im originally from NC also, and NO ONE rocks those fenders over here!) I was just looking into "bumper caps," if thats what theyre called. Theyre like 100$. I guess they are supposed to make a stock bumper fit better with the baja side fenders. Im only doin the front, the back is ok IMO
  16. Dec 20, 2012 at 9:53 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Go bigger than 285.
  17. Dec 20, 2012 at 9:54 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    fenders on a truck that still has the factory bumper looks funny, even if it is lifted...fenders only look good, in my opinion, with a wide stance in the front and a prerunner bumper.
  18. Dec 20, 2012 at 9:54 PM
    PLC721
    Patrick
    Chandler, Az
    or a plate bumper that matches the glass :cool:
  19. Dec 20, 2012 at 9:55 PM
    BMOC
    Paden
    Phoenix, AZ
    gotcha, yeah you will want uniball or lr bj uca's to get your alignment into spec
  20. Dec 20, 2012 at 9:56 PM
    MOTODOC
    NC—> MN
    2012 TRD sport 4wd
    if i put glass on the fronts and rears, i will probably go bigger than 285, but if i am just staying 1-2" bigger than stock height, just doing the front fenders and not the rears, then ill prob just stay at 285/75/16-17
