LT need some professional help
Discussion in 'Long Travel Suspension' started by teddygrahams, Aug 29, 2011.
  1. Aug 29, 2011 at 10:18 PM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    So, i have an older camburg kit with ball joints and not the uni ball. I'm running about 12 inches of travel right now. My limiter to my drop travel is the upper ball joint, I have a lot of travel still left in the lower.
    I came up with the idea to reinforce the spindle and rebuild the upper a-arm to match the camburg setup but make it so its a heim instead of a ball joint.
    My questions are... has anyone seen this done before? and what tubing would you recommend for the upper arm?
  2. Aug 29, 2011 at 10:25 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    pm shocktaco.. he build his own LT kit. i dont know if he would be able to answer your question, but it should be in the right direction. i am in no way a professional so you haters here, im just trying to help :cool:
  3. Aug 29, 2011 at 10:27 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    F that if you are gonna build it make horizontal uniballs,
    let me find this guy on ttora, pretty much measures travel in feet not inches :eek::eek:
  4. Aug 30, 2011 at 12:44 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  5. Aug 30, 2011 at 8:22 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    you could probably just modify the camburg upper arms to accept 1" or 1.250" uniballs. its pretty simple and straight forward to do.
    other than that you could build a new upper with heims and uniball. you can use dom . no need for the aerospace grede stuff here. but best bet is modifying the arms. its something i can do if your interested.
    as for the dude that recommended horizontal uniballs. a vertically oriented uniball (bolt orientation is horizontal) will have to have custom spindles made also. along with getting all the grometry right the lower will have to be changed up too. that and i dont think the guy wants a whole new kit . just wants to modify what he has . i feel its an acdceptable way to do it and have been wanting to convert the 1.250" uniballs into my tc arms. they arent that much bigger dimensionally wise and they actually have a thinner profile
  6. Aug 31, 2011 at 10:19 AM
    teddygrahams
    the vertical uniball would be best. Why would i have to replace the bottom ball joint if i did the same geometry as the upper bjoint? also if i replaced the bottom bjoint with a uniball i would probably get a lot more droop
  7. Sep 1, 2011 at 12:28 PM
    Defined
    mike
    southern california
    if you did a vertical uniball setup the upper joint theoretically has an infinite range of mis-alingment. the lower uniball/balljoint will still limit the range of movement of your arms, unless you make them vertically oriented too
    just convert the arms to a 1.250" uniball , horizontally oriented ( like they are currently) and maybe do the lower uniball conversion too. this will free up some play in the joints and allow you more travel , as long as the shocks and bumps will allow it.
    otherwise you will need new uppers,lowers and spindles fabricated to to the vertical uni setup. then shock/bump mounts will want to be repositioned to take advantage of the extra travel. its not as simple and cut-n-dry like people make it out to be . its a lot of work.
    this is a vertical uniball setup:
