LT overkill for me?
Discussion in 'Long Travel Suspension' started by ScreamingTaco, Mar 23, 2012.
  1. Mar 23, 2012 at 3:14 PM
    ScreamingTaco
    ScreamingTaco [OP] Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    New questions...
    What would happen if I converted to SUA (lets say, a DMZ kit) and ran it with stock shocks until I had more money?
  2. Mar 23, 2012 at 3:16 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Do what Piratefish recomended.
    http://www.definedengineering.com/products.html
    Stage 1 kit.
  3. Mar 23, 2012 at 3:19 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total chaos Long travel kit, swayaway coilovers, deaver leaf pack with icon resi's
    Yeah Jtachi in AZ ran the defined spring under with the stock shocks for awhile just dont max out the rear end while you have it set up that way cause you will blow those stock shocks in a heart beat
  4. Mar 23, 2012 at 3:44 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Sounds like mid travel setup.
  5. Mar 23, 2012 at 3:50 PM
    allmotorrex
    allmotorrex Grove Street Fabricating
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    keep in mind that kit will reduce your ground clearence by putting tha springs under the axle instead of over, idk if this would be a big deal for u or not
  6. Mar 23, 2012 at 4:00 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    OP I had the AP LT and their full rear setup as well. If your not planning on driving fast or jumping than the AP kit will fit your need. You can still drive a decent speed with the AP it will hold up.
  7. Mar 23, 2012 at 4:42 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    I am saving for the Total Chaos 2" over kit for the front. My truck is a DD and I dont want the extra width. Im sort of going for the Expo type of truck not the full on air catching type.
    Im not too worried about losing a little ground clearance, I think it will be worth the extra travel. I would strap the rear with the stock shocks.
    I guess you can tell I would say LT it and be done
  8. Mar 23, 2012 at 5:32 PM
    ScreamingTaco
    My issues have been more to do with high centering and approach/departure angles. Lots of rolling hills with water/wind erosion... not so much rocks and steep hills.
    To give some perspective, this is what it looks outside my house.
    Flat enough to go moderately fast, but hard ground under your wheels and you risk tearing a wheel off if you're going down an unfamiliar path and a lot of scrub that'll tear wires/hoses off the bottom of a vehicle. We do about 50-60mph across it in work vehicles, but that would tear my Tacoma apart.
  9. Mar 23, 2012 at 5:39 PM
    ScreamingTaco
    And here's some nearby terrain that we play in.
  10. Mar 23, 2012 at 5:40 PM
    FixedTRD
    Will
    Alhambra, CA
    A mild setup or if you really want the AP lt will fit your need.
  11. Mar 23, 2012 at 5:43 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If I was in your shoes, I'd just do a solid mid travel setup and use the leftover money on blow and hookers.
  12. Mar 23, 2012 at 5:47 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    hahaha x2
  13. Mar 23, 2012 at 5:51 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    judging by the terrain in your area, there is no reason for you to go long travel... you'll never get to use it to it's full potential and it'll be a waste of $$$
  14. Mar 23, 2012 at 5:54 PM
    ScreamingTaco
    Cool.
    Funny how a couple of pictures cuts right to the heart of things. :cool:
  15. Mar 23, 2012 at 5:56 PM
    #35
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    Word. And triple bypasses :cool:
    Bro just run the defined kit as a few have said earlier with his high clearance brackets, a bed saver type cage and a solid front mid travel. Booya
  16. Mar 24, 2012 at 6:24 AM
    #36
    ScreamingTaco
    Did some reading up on different points of view last night.
    The trails and crawling guys are generally against SUA. They say the whole point of SUA on a desert truck is to reduce spring wrap and lower the truck to compensate for the longer springs. The idea (as you guys know and I learned) is to get the most travel and acceleration with as low as reasonable centre of gravity... hence the lower lifts and smaller tires.
    A long travel truck is definitely cool, but I'm not looking to build a bro-truck so I want things to be functional for my intended purpose. I figured that long travel would give me some extra travel that might be useful when wheeling down trails or articulating through dry river beds since it'd keep my centre of gravity low, but at the speeds I'll be going the extra travel won't really be called upon and I'd be better off investing the money building up other parts of the truck.
    Still, I thank you dudes for helping me and not heckling me too badly since I learned a lot from this.
  17. Mar 24, 2012 at 6:59 AM
    #37
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    Looks like we do alot of the same wheeling. My truck is being built for trails and crawling to also be able to tear up the dunes on occasion. I have spent most of my life hitting trails and crawling and just started taking the truck to the dunes so those mentalities prevail in my build.
    Anyhow a solid midtravel front with a good set of leafs SUA and you should get what you need.
  18. Mar 24, 2012 at 10:29 AM
    #38
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    your terrain looks like my terrain and nobody does SUA because it takes away from ground clearence! Tha biggest thing u need to look at is when u flex on trails are u gonna be hitting ur springs, and more than likely that answer is yes with a SUA.
    Think about driving through a rut, if your rear axle isnt already touching tha ground its probably damn close and then add 4" to 5" of spring under there and u wouldve got stuck as soon as u entered tha ruts! Tha key word in your case it seems to me is "CLEARENCE"!
    So for the back i would look at AP springs, standard for just a 3" lift if you dont carry a lot of weight all tha time in your bed or expo for a 4" lift, which will match tha AP LT kit turned up high, or a 3" lift if you carry weight in tha bed. Match springs with a bolt flip kit to give you even more clearance and keep you from snagging your bolts, and a good set of bump stops.
    And as far as tha front goes, you will spend 2k for a very solid mid travel setup that will give you 10" of travel (which is perfectly fine for your terrain) or you can go the LT approach with APs LT and spend 5k with fenders and have a little wider track, which takes some away from tight trail riding, but will provide you with about 12" of travel and a very good looking front end:D
  19. Mar 24, 2012 at 12:42 PM
    #39
    rcfreak201
    rcfreak201 Well-Known Member
    x2!!!!
  20. Mar 24, 2012 at 1:26 PM
    #40
    ScreamingTaco
    I'm probably going to go with a Fox CO w/ Total Chaos UCA in the front and a Fox shock with either the AP or Deaver leaf pack in the rear. Like you said, clearance is important. I was thinking in terms of travel and flex but neglected to consider dragging my axle through the mud.
    I have about $7000 to work with and with the money I'd spend going LT I could go mid and afford high clearance front and back bumpers... which will put me a lot further ahead than an extra couple of inches of travel.
