LT the Rear or Just Bolt in Deavers and Good Shock???
Discussion in 'Long Travel Suspension' started by Blk04SR, Jan 25, 2013.
  1. Jan 25, 2013 at 12:20 PM
    Blk04SR
    Blk04SR [OP] Well-Known Member
    SoCal
    07 TRD Offroad PreRunner
    A Few...more to come!
    So I was thinking of getting a Deaver 10 -pack and some Icon 2.5 rear shocks to complete my mid-travel set up. Some time down the line I will do a Long travel in the front. Should I just do A SUA kit like Giant Motorsports and call it day...I have a dirtbike and I like their set up because I can still use the bed and throw my bike in the back and ride.
    Thoughts to the LT guys?
  2. Jan 25, 2013 at 1:14 PM
    Blk04SR
    SoCal
    Yes I did read a few topics here that people have suggested that...
  3. Jan 25, 2013 at 1:31 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Rear lt more important than front for go fast terrain. Having a dirtbike in back with lt is okay but may accelerate spring wear.
  4. Jan 25, 2013 at 6:53 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    i would recommend the defined engineering stage 1 kit with a little better shock. it will get you started with the proper leafpack for the truck from word 1 . then when you go lt up front you already have the foundation for building a lt rear. just add longer shocks and air bumps and your set . with a dirtbike and mild offroading you will kill the j66 pack in no time. my sua leafpack will last years without a major service.
  5. Jan 26, 2013 at 9:04 AM
    Blk04SR
    SoCal
    ^^^ I've seen your kit, it has custom Deavers, what are so special about them? I was also think about the J66 with air bags.
  6. Jan 26, 2013 at 9:27 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    Depends on what you want to do? if your hauling, yes spring wear will be an issue, if youre only wanting to go fast I'd go with the Defined SUA kit.
    http://www.definedengineering.com/products.html
    If youre truely only wanting to stick with Mid-travel id have Doug(4wd) build you a set of his OMD's based off of your stock springs. Yes they work, and well. After my bad experience with Deavers I will never touch their products again.
    http://www.tacomaworld.com/forum/suspension/194386-tacoma-spring-refurbishing.html
  7. Jan 26, 2013 at 9:57 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You said it yourself.....custom!
  8. Jan 26, 2013 at 5:16 PM
    Blk04SR
    SoCal
    Right, that is what I am afraid of...the spring wear with having weight in the bed.
    ^^^ well tell me what is so good about them and how they will not wear out if haul weight around in the bed...for all i know they might be custom but still have the same issue as the Deaver 10-pack...what sets them apart are they thicker leafs with more packs or what? I would have to assume they are still pretty soft and would have a thinner leaf stacking them in 10-12 packs...I dont know...????
  9. Jan 26, 2013 at 7:25 PM
    Defined
    mike
    southern california
    what sets them apart is keeping arch in the spring and the springs do not go into negative arch ,there by making them last longer . thers a few other things about my springpacks that make it unique but thats for me to know and the consumer to enjoy. i would worry more about wear with a SOA leafpack than SUA.
    the defined kit is a perfect match for any 2nd gen tacoma no matter what the off road discipline is . its what toyota should have put in the truck from the get go. i have 3 years of hard abuse on my prototype springs with nothing other than visual inspections. my springs in the championship winning stock mini tacoma has logged thousands of miles with no other maintenance other than visuals as well. if thats not a quality , long lasting spring i dont know what is!
  10. Jan 26, 2013 at 8:09 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    BLK04SR,
    Given what you are seeking and your location, do a search here for "4WD"s thread on "refurbishing leaf springs". You will find a wealth of information and "4WD", Doug can build you a set of awesome springs at very nice price.
  11. Jan 28, 2013 at 7:52 AM
    Blk04SR
    SoCal
    Do I need to give him a set of springs? I cant be down at all as the truck is my DD. Yeah that has been suggested from someone above.
    I am still not sold on the Defined kit...nothing against them I am sure they have a good product but still not sold on the "custom" Deaver spring...that will will hold up to weight in the bed...
  12. Jan 28, 2013 at 9:01 AM
    Defined
    mike
    southern california
    i have nothing else , besides you coming by and me showing you why going sua is the route you should go and why an SUA leafpack is better than any company's bolt in SOA pack. if your interested let me know.
    one last question. if you dont trust defined's custom deaver pack then how is it that you trust the deaver 10-pack or the giant 64 kit ( leafpack also a deaver product) ? dmz springs are also made by deaver as well as everybody running an f55, f67 and h70 packs...
  13. Jan 28, 2013 at 12:38 PM
    SoCaltaco65
    ^^^^THIS
    Deaver Customs are made in the same shop as the production springs. If you want a true custom spring then have national Spring in El-Cajon build you a set, but be prepared for a huge bite in the wallet.
  14. Jan 29, 2013 at 7:11 AM
    Blk04SR
    SoCal
    ^^^I dont trust anyones. I am doing homework and its coming up pretty bad.
    ^^^Im just wondering what sets a custom spring apart from a productions spring...no good responses.
  15. Jan 29, 2013 at 8:00 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    While springs aren't perfect, custom built is the best way to go compared of "off the shelf". Not trying to convince you either way but this is how I see it.........
    Custom can be built to the specs of your truck, weight, what ride height you want and use. SUA in general will have a higher spring rate and more arch, which gives more up travel without going into negative arch (that's what makes springs sag and I've gone through 2 packs already). If I'm not mistaken Defined also has a heavier duty spring for more weight which adds a heavier aal to the pack. I would rather trust a guy that has put the springs through more abuse than I will and would rather take his word over marketing descriptions on websites.....he's got a reputation in this business to up hold and has gone above and beyond in the Toyota market and here at TW!
    On a side note, AP expos with a 2.5" shock is another good option if you stay SOA as they are built to hold 300-500lbs and keep 3" rear lift. Plenty of guys like these springs and put them to the test!
  16. Jan 30, 2013 at 12:20 PM
    Blk04SR
    SoCal
    I have been looking at the AP Expos, the key to this I dont want a 3" lift. I have also been debating the Dakars and taking out one of the overload springs to reduce the lift, I saw a Tacoma the other day in a parking lot with a OME lifts with Dakars in the rear.
  17. Jan 30, 2013 at 4:27 PM
    wolftree
    Rick
    Ohio
    BLK04SR,
    PM "4WD" and talk with him directly. He can tell you how many hours it will take him.
  18. Feb 1, 2013 at 12:32 PM
    Blk04SR
    SoCal
    Thanks. I think I am just going to go with a custom set of spring from national. They are priced just as much as Deavers and I dont have to use ,y current springs and have someone build me a pair.
  19. Feb 1, 2013 at 12:43 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    id go with defined.
    what other information are you wanting on the custom pack? he has already told you everything... he cant give you all the secrets. off the shelf deavers sag like a mad man, pretty quick.
    SUA ftw
  20. Feb 1, 2013 at 1:01 PM
    eric3187
    eric3187 Well-Known Member
    I will be running Dakars with King shocks with the compression adjusters on my truck, with TC lt up front and a coil over only. once everything gets to me i can report back on my thoughts.
    running with the dakars since 1)already on the truck 2) need/want the under axle clearance 3) i will be pulling an expedition style camp trailer a lot.
