LT Tire pressure?
Discussion in 'Wheels & Tires' started by AJKlug1, Jul 4, 2021.
  1. Jul 4, 2021 at 6:32 PM
    AJKlug1
    AJKlug1 [OP] Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    What Cold pressure is everyone running their LT265/70/17 E loads. I set them to 32 cold but when it moves at super slow speeds you can see the tire bowing out at the bottom. I understand that once you get driving you'll gain about 2-4 psi so I feel like 36 cold could be too high. Might end up doing a chalk test if there's no common answer. TIA!
  2. Jul 4, 2021 at 6:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Lots of answers, most agree 30psi is the sweet spot for LT
    I run 28psi cold and 30psi warm.
    You'll never get full shoulder wear unless you tow in the rear.
    Driving down a gravel road often is all you need to see the shoulder.
    Mastiffsrule likes this.
  3. Jul 4, 2021 at 6:35 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Alright, thanks:thumbsup:
  4. Jul 4, 2021 at 6:46 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    LT tires require more pressure than SL tires for a given load. Here's a calculator to find the appropriate pressure based on your vehicle's stock size and pressure.
    I disagree. It might be fine if you're running around unloaded, but this would certainly be under-inflated based on GAWR.
  5. Jul 4, 2021 at 6:54 PM
    Bishop84
    Under inflated for load 100% but for street driving it will wear better and drive smoother.
    42psi on even 1/2 tons burns off the center tread of LT tires.
    Thatbassguy[QUOTED] likes this.
  6. Jul 4, 2021 at 6:58 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I find 35 is a good compromise between ride, wear, and mileage.
    Thatbassguy likes this.
  7. Jul 4, 2021 at 7:05 PM
    Thatbassguy
    James
    True. I do agree that the recommenced pressure for stock size LT's feels excessive. As long as people remember to air up when towing/hauling, it's probably fine to run lower pressure for regular driving.
    I have a 4Runner, and when I switched to LT's it recommended 44. I wound up running 36 or 38 and had good wear. Now I'm on 295/70/17's and the recommenced pressure (35) feels good.
    Bishop84[QUOTED] likes this.
  8. Jul 4, 2021 at 7:13 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    I did the chalk test and landed 31ish. Cannot remember exact cold. 32 psi hot is perfect contact. Any higher was not full contact. Above 36psi the truck would shake big time on highway
    davidstacoma and Thatbassguy like this.
  9. Jul 10, 2021 at 2:19 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I have generally used the tire pressure on the label in the truck on my vehicles, 32 psi for my Tacoma. Took my Tacoma in for service including tire rotation and on the way home had the bumpiest ride ever., it tracked straight but seemed to want to wander. Checked the air pressure when I got home and they had put 36-37 psi in the tires! Set them at 32 and my ride and handling was back to normal lol.
    Mastiffsrule[QUOTED] likes this.
