lube chasis pics
Discussion in 'Technical Chat' started by nighthawk87, Sep 23, 2009.
  1. Sep 23, 2009 at 7:20 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    Does anyone have the pics for where the truck suspension/drivetrain can be lubed so it doesn't clunk anymore?
  2. Sep 24, 2009 at 8:20 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Pretty easy to spot on the 2nd gens.
    I believe there are 5 on the 4x4 models.
  3. Sep 24, 2009 at 8:26 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Just don't apply to much and blow out the seals!
  4. Sep 24, 2009 at 8:51 AM
    nighthawk87
    Do I have to buy a special grease gun to do this?
  5. Sep 24, 2009 at 9:28 AM
    johnecon2001
    Phoenix, AZ
    There are really only one or two available guns.
  6. Sep 24, 2009 at 9:43 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Around when you you do this? Granted i know depends on if you O-R alot, but just an estimate would be good
  7. Sep 24, 2009 at 9:46 AM
    nighthawk87
    I think mine needs it because when I stop it isn't smooth it shifts kinda.
  8. Sep 24, 2009 at 10:00 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    you supposed to pump it in until you can see new grease come out of the U-joint, and if its clunking you may need to replace it.
  9. Sep 24, 2009 at 10:18 AM
    nighthawk87
    not cluncking but when I stop I feel it shift...its not as smooth as it was the first day I got the truck
  10. Sep 24, 2009 at 10:19 AM
    PrezidentRedz
    Redz
    Owings, MD
    is this a manual or auto? also does your truck have the 2pc shaft in the rear?
  11. Sep 27, 2009 at 11:50 AM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    My 06 4x4 auto doesn't have any. It just has three universal grease fittings on the rear shaft. Not on the front. Mine has a rubber boot on front and rear shaft. They must not have put them on the earlier models. That sucks cause that means I just have to live with it or fork out a bunch of money to buy a different drive shaft.
  12. Sep 27, 2009 at 1:15 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The small pistol grip guns are handy for one hand operation, you can then hold the attachment on the zerk ftg with your other hand. Get a rubber extension hose for the gun.
    Correct me if I'm wrong here, but as far as I can see there's a total of 5 zerk fittings on the drive shaft of the 05 and up 4x4's. The 2 forward most zerks are harder to see, but they are there. You might have to rotate the drive line a bit to see them.
  13. Sep 27, 2009 at 1:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I haven't looked myself on mine....but wondering if that's the slip yoke zerk?
  14. Sep 27, 2009 at 5:12 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I found the front universal grease fittings on mine. They are in the center of the universal joints. My truck doesn't have the slip yoke fittings though. It has a sealed boot.
