Lube my taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by fuckmdroads, Aug 28, 2019.
  1. Aug 28, 2019 at 12:46 PM
    fuckmdroads
    fuckmdroads [OP] Active Member
    2004 TRD Offroad Tacoma, 3.4L V6 4x4 w/5 speed manual
    Road Salt Rust Mod
    Trying to change out all the other fluids on the taco.
    The manual says I need...
    API GL-4 or GL-5 SAE 75W90 gear oil for manual/transfer
    API GL-5 SAE 75W-90 hypoid gear oil for front diff
    API GL-5 SAE hypoid gear oil for rear diff
    I did my rounds on TW and believe I should use…
    Rear Diff - Redline 75W90NS
    Front Diff - Redline 75W90
    Transfer Case - Redline MT-90 75W90
    Transmission - Redline MT-90 75W90
    As far as the parts needed..
    Would this kit cover me on both differentials and the transfer case?
    And this for the tranny?
    Also would this shit be good for the propeller shaft lube? The guys over at bobistheoilguy hyped it pretty hard.
    Please let me know if I am on crack/have any suggestions.
  2. Aug 28, 2019 at 12:57 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Looks good to me
    Few tips -
    Remove the fill plug on the diffs, t-case and transmission before removing the drain plug. You don't want to drain them and then realize the fill plug is stuck on or stripped.
    With the front diff, the fill plug I believe is a hex key plug, and it is very easy to strip. Make sure you clean the dirt and road grime out of it before attempting to break it loose or it will strip on you (been there done that).
  3. Aug 28, 2019 at 1:23 PM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    While changing your transmission fluid consider dropping the pan and changing the filter screen.
  4. Aug 28, 2019 at 1:30 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Per what the OP posted, he has a manual and not an automatic transmission.
  5. Aug 28, 2019 at 1:34 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Everything looks good IMO. Note that you can use the same oil in both front and rear diffs. I went with the regular Redline 75w90 on each end of my truck and it works just fine still. I do have the rear e-locker as well.
  6. Aug 28, 2019 at 3:35 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    As far as grease goes, I personally use general purpose marine grease on anything with a grease fitting. Probably unnecessary but if it’s tough enough for saltwater trailer bearings, commercial boat winches and outdrives, it can’t hurt sitting in my ball and ujoints....
    Taco*Sauce06, CS_AR and Xbeaus like this.
  7. Aug 28, 2019 at 3:54 PM
    fuckmdroads
    Road Salt Rust Mod
    Any recommendations for marine grease?
  8. Aug 28, 2019 at 4:00 PM
    fuckmdroads
    Road Salt Rust Mod
    Do you think the LS Redline version would be worth it in the rear diff? or just go with the normal 75W90 in both? Would it make nay difference?
  9. Aug 28, 2019 at 4:01 PM
    fuckmdroads
    Road Salt Rust Mod
    Thanks for the tips!
  10. Aug 28, 2019 at 4:46 PM
    Rachelsdaddy
    Southern NH
    I buy Napa brand grease.
  11. Aug 28, 2019 at 5:22 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I am impressed you plan to buy new crush washers instead of tightening the shit out of the old ones.
    Tighten the oil plugs with new washers only 1/2 to 3/4 turn past finger tight...kind of like an oil filter.
    There is virtually no mechanical load or high vibration on the plugs. They won't come loose.
    Rachelsdaddy likes this.
  12. Aug 28, 2019 at 5:25 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  13. Aug 28, 2019 at 5:46 PM
    fuckmdroads
    Road Salt Rust Mod
    I read a bunch of TW threads and there was one guy in the responses that recommend it. I figured buying a crush washer is better than never being able to get it off.
  14. Aug 29, 2019 at 6:37 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I don't even know what the LS Redline version is. I used the normal 75w90 that you linked in your first post in both diffs on my truck.
    This stuff
    Xbeaus likes this.
  15. Aug 29, 2019 at 6:47 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Redline 75w90 as everyone mentions is good for the crunchy taco. I've had it in there for many years. Still looks brand new!
  16. Aug 29, 2019 at 6:51 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ive had Valvoline Conventional 75w90 in the rear and front diffs for awhile now. No problems. I plan on using it in the transfer case and MT90 in the trans at the next change. New gaskets for all, torqued to spec.
    GQ7227 likes this.
  17. Aug 29, 2019 at 7:22 AM
    Mallard386
    Mallard386 Well-Known Member
    Virginia
    2001 ext cab 4x4 4 banger 115k and counting
    TBD
    If you are interested in saving a few bucks I just used the Supertech brand from walmart in both my front and rear diffs and so far so good I haven't had any problems
  18. Aug 29, 2019 at 8:18 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The title to thread.........:rofl:
    Good advice from everyone.
    cruiserguy likes this.
  19. Aug 29, 2019 at 3:06 PM
    Rachelsdaddy
    Southern NH
    Since we are on fluid topic. Please choose an ATF fluid for me. I want to do the “drain, fill, drive, drain and change filter” thingie this weekend. Anything but Toyota ATF please. Also, roughly how much do they hold. Thank you
  20. Aug 30, 2019 at 7:12 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    +1 for using salt water marine rated high temp grease. It sticks like snot and doesn't wash out.
