Lube "propeller shaft"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deke, Feb 20, 2017.
  1. Oct 20, 2021 at 8:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Whatever happens to be in the grease gun that day
    ever notice that Chevys have more zerks than anybody but they still fall apart the quickest?
    Squirt, GrizzledBastard and Junkhead like this.
  2. Oct 20, 2021 at 8:17 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  3. Oct 20, 2021 at 8:19 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    True story, u joints started squeaking under load on my ranger and I just sprayed some WD40 and never heard the noise again for years. Those were non serviceable ones.
    shakerhood and b_r_o[QUOTED] like this.
  4. Oct 20, 2021 at 8:28 PM
    MGMDesertTaco
    I use Lucas Oil Red 'N' Tacky grease. https://lucasoil.com/products/grease/red-n-tacky-grease
    It's NLGI #2 rated, runs about $6 a tube at Home Depot or Walmart and seems to work fine. I've read that a moly grease would be better suited for driveshaft u joints, but selection was limited last time I went Walmart. I might try this next time...
    https://www.amazon.com/Valvoline-Sy...t=&hvlocphy=9061147&hvtargid=pla-570957897276
    I believe my 2017 only has 1 or 2 zerks on the front driveshaft, so a tube lasts quite a while.
    Junkhead likes this.
  5. Oct 20, 2021 at 8:32 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Thanks for the info, I’ll look into it.
    My 18 has 2 maybe 3 zerks, I can’t remember.
  6. Oct 20, 2021 at 9:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think my truck has 2, but its been awhile since I greased it last though.
    Junkhead[QUOTED] likes this.
  7. Oct 20, 2021 at 9:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    As you know there aren't that many greasing points on the truck. I've used it on the driveshaft U-joints, wheel bearing seals, SPC ball joints. Went through less than two tubes over 8 years. I picked Lucas X-Tra because it's a major-brand NLGI #2 grease without molybedum disulfide (which can absorb water and generate sulphuric acid) and available in local stores.
  8. Jul 26, 2022 at 7:18 AM
    zakzilla
    zakzilla New Member
    Zach
    2021 Cement TRDOR
    Hey, just to let you know, carmanualsonline.info has the maintenance schedules if you'd like them.
  9. May 12, 2023 at 1:40 PM
    TDRsport
    TDRsport Member
    2017 Tacoma TDRsport MT
    If you live in a cold climate aka Canada I recommend the low temperature grease which remains soft in freezing weather. My Smittybuilt winch was almost impossible to free wheel in freezing weather until I took it apart and re-greased everything inside with a low temperate grease. Now it free wheels with almost no effort. I assume it the u-joints would move a lot easier as well. I used a locally available Motomaster brand.
  10. Jul 7, 2024 at 1:25 PM
    dougluvgold
    dougluvgold Member
    Douglas
    2023 tacoma trd off road 4x4 dbl cab
    2023 4x4 off road doesn't have one single grease point on any u joint or well anywhere . I find it odd and worrisome that i can't know for sure enough friction points are well lubed , I'm always thinking every vibration or sound is is contact of somewhere i should be able to grease but cant . wont ever know till it completely fails then that's when and only warranties can fix it , not failing lets fix completely failed then fix which is bull crap
  11. Jul 7, 2024 at 1:36 PM
    perterra
    perterra Well-Known Member
    Tejas
    Buy an 04, part the 23 out. Not trying to be a smart ass, but I never rolled around looking for shit to grease.
  12. Jul 7, 2024 at 1:40 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    That's what they call one on a Corvette.
  13. Jul 7, 2024 at 2:09 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    The Corvette has a real torque tube. It's a fixed tube bolted between the front motor and rear transmission with a shaft running thru it.
    That dealer was wrong saying the Toyota had a torque tube.
  14. Jul 7, 2024 at 2:20 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    I usually use full synthetic grease from Mobil 1.
  15. Jul 7, 2024 at 2:33 PM
    #35
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    My 2006 Taco had 5 zerks.
    My 2018 Taco had 0 zerks.
    My 2021 Tundra had 0 zerks.
    My 2022 Taco has 0 zerks.
    Curious if these same statements exist in the manual for the 2024, and if one of those trucks will ever have an OEM zerk fitting.
  16. Jul 7, 2024 at 4:38 PM
    #36
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Zerks reduce strength and cause failures under high load. Zerks in the cap don’t always flow to all ends also leading to failure. Look at ANY high strength high load competition ujoints they have zero Zerks.
    The only purpose of Zerks is time saving. You don’t have to disassemble to grease. If I have to pull a joint to grease I replace it, grease it and install. I can’t tell you how many times I pulled a joint and found the Zerks weren’t sending grease to all ends of every cross. As a millwright I laugh every time someone gets their panties in a bunch about maintenance but won’t go the full distance because it takes too much time (or they don’t have the knowledge how to do it).
    Toycoma2021 and I-Give-Up like this.
  17. Jul 7, 2024 at 4:57 PM
    #37
    Exracer2
    Colchester Ontario
    Someone made a comment about grease and moly grease. Moly has better water resistance. That’s the #1 reason I use moly. In a driveshaft ujoint I don’t worry about water unless I am regularly submerging them. Even then if they have Zerks I go EP (extreme pressure) and grease them regularly.
    Always think of the environment you are operating in more than engineering the best this or that. Lots of overthinking in this thread which tells me there are people with a lot to learn and not enough experience. Sorry but YouTube does not replace proper training and experience. We are talking low joint angles (low speed movement) low loads on stock non lifted trucks. Only when you go to high angles do speeds and temps rise and therefore greasing needs increase. Think of how a joint works. Low angles have low movement between the caps and the body over each rotation. High angles have high movement and higher temps as the joints move a lot more each rotation. High angle are much harder on joints and grease. I have literally melted the cross off a joint trying to run home after a 4wheeling trip at a speed I knew was too much considering the lift I had (Jeep). Now to illustrate how easy it is to change I replaced it at the side of a freeway in under 10 minutes. Due to the lift and abuse of the joints I kept spares in the Jeep at all times including tools to change them. Stock trucks do not require zerks and joints don’t last forever so get over it. Replacing them is no different than replacing tires, belts or oil. They are consumables.
  18. Jul 7, 2024 at 6:46 PM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
    And Porsche 924, 928, and 944.
