Lubing UCA's?
Discussion in 'Suspension' started by ETaco23, Feb 14, 2009.
  1. Feb 14, 2009 at 11:14 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Hi guys, Im gettting some TC UCA's soon and was doing some research and found that alot of people have been having squeeking from them. I was wondering what type of lube is good for the zerks and ball joint? thanks!
  2. Feb 15, 2009 at 12:15 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I put mine on last week, used finish line teflon grease (found it at a bicycle store) and loaded it into a grease gun. no squeaks yet :)
  3. Feb 15, 2009 at 5:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I havent heard of any TC UCA's makeing noise. If they are propperly greased upon install, they should be quiet. When installing them, rub grease all over the bushings, and bushing sleeves, then, after install, grease them with a quality grease. Dont over grease, as you can cause the bushings to bulg. If this happens, remove the grease zerks, and allow the extra grease to run out. If the Uniball is makeing noise, use Tri-Flow, are some other quality dry Tefflon lube.
  4. Feb 15, 2009 at 6:08 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    What he said. I actually overfilled mine when I installed them. It's a PITA to get the extra grease out, but ya gotta do it :thumbsup:
  5. Feb 15, 2009 at 6:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What do you mean, its a pita!? Remove the zerks, and let it run out. ;) Depending on how much you put in, you might have to loosen the UCA bolt.
  6. Feb 15, 2009 at 6:32 AM
    Delmarva
    Tucson, AZ
    The angles are weird... and getting the zerk back in is a bitch... I had to loosen the long UCA bolt and the ball joint and work the UCA up and down until enough grease squeezed out...
  7. Feb 15, 2009 at 6:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah. Ok, Im gonna give you a PITA approval. :)
  8. Feb 15, 2009 at 6:46 AM
    Delmarva
    Tucson, AZ
    lol... thanks... next time I'll know better not to go crazy with the grease... :laugh:
  9. Feb 15, 2009 at 6:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When just installed, I only give 2 or 3 pumps from the grease gun. Then wait a week, and grease them until I haer the "pops" of the grease.
  10. Feb 15, 2009 at 6:55 AM
    Delmarva
    Tucson, AZ
    That's good advice... where were you when I installed the things... :laugh:
  11. Feb 15, 2009 at 6:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I....ummm.......um....I........mmm.....Hey, Look over there!
  12. Feb 15, 2009 at 7:13 AM
    IB Slingin
    IB Slingin Well-Known Member
    Cant you just take a small nail to the zerk fitting and "bleed" the excess grease without having to remove them?
  13. Feb 15, 2009 at 7:18 AM
    Delmarva
    Tucson, AZ
    lol... no worries... I was only a member of that "other" website at the time... :laugh:
  14. Feb 15, 2009 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    you can, but its faster just to remove the zerk. Trying to push that little ball check down IS a pita.
  15. Feb 15, 2009 at 11:04 AM
    ETaco23
    Evan
    PNW
    Thanks for the replies guys! I probably wouldn't have greased them at all if I didnt ask about it... I'll make sure to lube them up...... but not too much! Gotta love the Lube!!! ummmm.... yeah!
  16. Jul 3, 2009 at 8:22 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    So I should pump in grease until I hear a popping sound? And will any grease work?
  17. Jul 3, 2009 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I prefer Mobil 1 grease in the UCA's. Yes, pump them until you hear them pop. HOWEVER, Dont pump too much into them, as the bushings will bulge out, then you will have to take the zerks off, or even loosen the UCA bolt, and bleed the exess out.
  18. Jul 3, 2009 at 8:28 PM
    bermise
    Houston
    08 TRD off road
    I hope I hear the pop before I see the bulge!!
  19. Jul 3, 2009 at 8:29 PM
    bermise
    Houston
    08 TRD off road
    And chris4x4, what kind of oil do you use in your rear differential?
  20. Jul 3, 2009 at 8:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And here is the tricky part. You wont see the bulge right away...maybe not until you drive on it a few days. Have you installed them yet?
