Lubricating drive shaft or propeller on 2006 4x4 Tacoma's...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeeKay21, Dec 18, 2008.
  1. Dec 18, 2008 at 5:05 PM
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey does anyone know how to lubricate the drive shaft/propeller shaft for 2006, 4x4 Tacoma's or if it can even be done?
  2. Dec 18, 2008 at 5:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you looked under yours to see if there are any grease zerks?
  3. Dec 18, 2008 at 5:14 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah but I wasn't sure if it was it. Let me go take a pic for you chris. Hey remember, I'm not a mechanic like you! Haha!!!:D
  4. Dec 18, 2008 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Look for them around the "U" juints.
  5. Dec 18, 2008 at 5:27 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Are those the grease zerks?
  6. Dec 18, 2008 at 5:44 PM
    ofrd4fun
    ofrd4fun Well-Known Member
    Vancouver BC
    05 DC 4x4
    FJ Cruiser wheels, air bags, 5100's @1.75, TC UCA's, bi-xenon HID's
    Once a year I grease the part I think you're talking about! Just to the rear of the carrier bearing on the drive shaft is a rubber bellows that protects a splined slip joint that allows the drive shaft to "shorten" as the rear axle travels up. Block the wheels so the truck won't roll!!!!! I removed the factory clamp at the front of the boot and removed the 4 bolts that hold the end of the drive shaft to the differential. You might need a mallet to knock the drive shaft loose. Put some kind of marks on both sides of this splined joint. It's important to keep all those u-joints in phase. Lower the driveshaft to the ground and carefully slide the joint apart. Regrease the splines and slide back together. Re-torque the bolts at the rear diff. I replaced the factory clamp on the rubber boot with a S.S. hoseclamp and added another one just on front with the screw portion 180 degrees from the first to kinda "balance" things out.
    While you're under there you may as well grease the zerks on the u-joints front and rear.
    It probably sounds more complicated than it is. I thinks it's about a 1/2 an hour to do everything listed above.
    Cheers
  7. Dec 18, 2008 at 6:07 PM
    sonjay
    sonjay Well-Known Member
    WW FireFighter, those indeed are zerk fittings, and you can pump grease into them! Clean them off tho so you don't pump dirt in. Should be done every service. There is also some on the front drive shaft, they are inside and somewhat difficult to get to. Pump until you hear/see grease come out. couple pumps is usually all thats needed.
  8. Dec 18, 2008 at 6:31 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah on those pictures the very top picture is the bottom front of the truck, 2nd picture is the bottom middle of the truck and the last picture is the bottom rear of the truck. There's only one zerk fitting per propeller shaft. If that's even what its called! Haha!
  9. Dec 18, 2008 at 6:36 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez that was a lot more then i was looking for but thanks!!! I'm just going by my Tacoma maintenance book that came with the truck. I missed my 18 months or 15,000 miles servicing. I always do the oil chages and tire rotations on time but if you look at the booklet, it has "lubricate propeller shaft and to re-torque the bolts." That's the only thing I missed. But I think both you and sonjay are right. I think all I have to do is grease up those U-joints. That's what they are right, in those pictures I have? Those are the U-joints right?
  10. Dec 18, 2008 at 6:40 PM
    ofrd4fun
    Vancouver BC
    05 DC 4x4
    Yes, those are the ones.
  11. Dec 18, 2008 at 6:46 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Now I'm going to buy a grease gun here pretty soon. Are the zerk fittings a universal fitting for grease guns?
  12. Dec 18, 2008 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should be. I think there are only 2 sizes (correct me if Im wrong), and the Tacoma has the larger one.
  13. Dec 18, 2008 at 7:12 PM
    sonjay
    I'm pretty sure its the larger one. I like the grease guns with a pistol grip I think there called. one handed operation.
  14. Dec 18, 2008 at 7:52 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah there's a bunch for sale on ebay with the pistol grip. Now what kind of grease should I use?
  15. Dec 18, 2008 at 8:05 PM
    sonjay
    It should give a spec in the manual. I use red or green stuff? Don't get black grease or moly. Other then that most oil companies make good stuff. If it gets cold where you are get a good all season grease.
  16. Dec 18, 2008 at 8:30 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I see a lot of lithium grease. Will that be okay?
  17. Dec 18, 2008 at 8:36 PM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    I would stay away from lithium grease for u-joints. If its warm where you are use a GL1 or if its cold use a GL2 spec grease. Also you don't need to spend the money on synthetic grease for u-joints, a petroleum base will do.
  18. Dec 18, 2008 at 8:41 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah its super cold right now where I live! Its like 10 degrees out right now!!! So if I get GL2 grease for the cold, should I re-grease with GL1 in the summer time? Also, what is GL1 and GL2?
  19. Dec 18, 2008 at 10:50 PM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    I need to get this done soon myself
  20. Dec 19, 2008 at 8:32 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    Is there 5 or 8 zerk fittings total for a Double Cab, anyone know?
    Aren't you supposed to use Moly for the U joints and a different grease for the rest.
    I'm slightly confused on this subject.
