Lubricating drive shaft or propeller on 2006 4x4 Tacoma's...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeeKay21, Dec 18, 2008.
  1. Jan 26, 2009 at 4:29 PM
    #81
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Thanks guys for all the info . . . TW is the BEST! I'm coming up on this service at my next oil change and am glad this thread came up. One question I have is, how much torque is supposed to be on the "propeller shaft bolt?" I found this but is 101 ft-lbs correct? I also found this but it doesn't contain the torque value.
  2. Jan 26, 2009 at 4:35 PM
    #82
    Snyperx
    Snyperx Seniore Marcos
    Drive shaft is greased. Now, if you haven't seen the thread, I need to get the damn front diff. oil changed. Stupid freaking plugs!!!:frusty::frusty::frusty::frusty::frusty:
  3. Jan 26, 2009 at 4:41 PM
    #83
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Let me know if you get it! :eek:
  4. Jan 26, 2009 at 4:59 PM
    #84
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey have you asked around about the front diff fluid change? I'm sure there are tons of people that have done it?:confused:
  5. Jan 26, 2009 at 5:50 PM
    #85
    Snyperx
    That's why I started a separate thread on it:D
  6. Jan 26, 2009 at 5:57 PM
    #86
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah true! Has chris 4x4 gotten back to you?
  7. Jan 26, 2009 at 6:14 PM
    #87
    Snyperx
    I think he replied to the thread I started.
  8. Jan 26, 2009 at 6:20 PM
    #88
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay.
  9. Jan 27, 2009 at 8:35 AM
    #89
    ph16drive
    Paul
    Clevelandish
    Anyone know the torque?
  10. Jan 27, 2009 at 10:32 AM
    #90
    Snyperx
    We I used the PB Blaster stuff and it didn't help one damn bit. I am going to call around to a couple of the local garages to see if someone can toss it on a lift and change it for me. I would think it would take less than 30 minutes to do, cost maybe $20? Hell I'll even do the work.
  11. Jan 27, 2009 at 10:42 AM
    #91
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    haha... you just need some air tools or a breaker bar with some muscles. Try putting breaker bar on it, and stand on the end of the breaker bar.
    I did this when lug nutz were stuck on my wheels. There was only one time when it didn't work, then I called my friend which is a body builder and got it loose, dood acutually picked up the front end of the car..... I was impressed...
    Just take it to a backyard mechanic and have them loosen it for you. Should be free, then go home and do the work. Just say, man can you use your air tools to loosen this bolt.... I'm too much of a girly man.... look at my twig like arms..... JUST JOKING!
  12. Jan 27, 2009 at 10:47 AM
    #92
    Snyperx
    papa,
    I have the air tools and the breaker bar actually, the problem is I don't have enough clearance on my ramps to use the 17" breaker bar. I can't get enough leverage. I have a impact wrench, but not the needed impact type hex socket. I don't want to use non-air tool rated sockets, they could shatter from the impact wrench force.
    I might do what you said in take it some where and just have them loosen the plugs then go home and finish it myself.
  13. Jan 27, 2009 at 10:49 AM
    #93
    papabear050
    Yeah,
    Or you can get a mini torch and heat up the plugs a little, careful not to melt anything and take to it. If that doesn't work, yeah take it to a shop. Just be careful
  14. Jan 27, 2009 at 10:54 AM
    #94
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Heat on a diff plug is not a good idea, if you get it hot enough to do any good you are gonna have charcoal sludge inside the pumpkin
  15. Jan 27, 2009 at 11:11 AM
    #95
    Snyperx
    I don't think I'll do the heat thing, but I did try and tap the plugs with a hammer.
  16. Jan 27, 2009 at 12:29 PM
    #96
    sonjay
    sonjay Well-Known Member
    Try taping your wrench with a hammer, you can use your non-impact socket with the impact just be careful. 1/2" drive socket I hope?
  17. Jan 27, 2009 at 12:54 PM
    #97
    Snyperx
    Nope, the 10mm hex socket I have is only a 3/8. I might run to Harbor Freight Tools and pick up a set of hex 1/2" impact drivers. I think I can get a set of 6 for like $24. Gives me an excuse to buy more tools:D
  18. Feb 2, 2009 at 12:58 PM
    #98
    Snyperx
    Well I bought some impact hex sockets and tried using my impact wrench to get the drain plugs off the front diff. No go. They are frozen solid. Looks like I am going to be taking the truck some place.:frusty::frusty::frusty:
  19. Feb 2, 2009 at 1:42 PM
    #99
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I remember trying to get the socket head bolt out of my front diffential on my 95 Tacoma. I could never get it out. Why can't they use a regular bolt there?
  20. Feb 2, 2009 at 2:44 PM
    #100
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    WW those pics wont load for me.. can u email them? or repost please I 'd like to find them on my 2006 4x4 Thanks..
