Lubricating drive shaft or propeller on 2006 4x4 Tacoma's...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeeKay21, Dec 18, 2008.
  1. May 31, 2009 at 5:22 AM
    #121
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    ok, i've read thru this whole thread and i have a question to make sure i fully understand. i bought some gl2 spec synthetic grease(valvoline synthetic) and it says moly fortified. is moly lube and moly fortified two different things or is it the same thing? cuz if its the same thing i'll be returning this grease to find one thats not moly fortified.
  2. May 31, 2009 at 12:34 PM
    #122
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I used the Mobil 1 Synthetic grease. The Valvoline should be exactly the same. It will work.
    Here are a few pics.
    Note the grease spray on the under side of the cab.
    This u-joint required 3 pumps of grease. You can see from the grease marks that a lot of the grease has sprayed out and it is in need of grease.
  3. May 31, 2009 at 2:51 PM
    #123
    danteisme
    South Western PA
    nice pics, they make it real clear to see. when i go do this, i may as well grease the whole truck. i know a lot of newer vechicles(at least their replacement parts) they are internally greased, they have no grease fittings. how many grease fittings are on the truck total? mine is a reg cab by the way.
  4. May 31, 2009 at 3:24 PM
    #124
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    These are great pictures of what happens when you use Mobile 1 synthetic grease. You'd be much better off using the Co-op Moly guard or any grease that has Moly in it to get away from the grease spray, and it'll stay in your joints much longer.
  5. May 31, 2009 at 3:27 PM
    #125
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Moly grease flings off just as bad, if not worse, than the Mobil 1.
  6. May 31, 2009 at 3:33 PM
    #126
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    If you wanna believe that or the pictures its up to you. I use Co-op Moly Gueard on mine and have no where near the grease spray as these lithium mobile 1 grease pictures.
  7. May 31, 2009 at 3:35 PM
    #127
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool. Maybe your not greaseing them as much as others?
  8. May 31, 2009 at 3:40 PM
    #128
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    Ya right , we are all stupid and just keep pumping grese into them zerks until its dripping on the ground. Come on, the synthetic grease doesn't work as well and the pictures prove it. Some people will tell you anything but look at the pictures. If you want that on the underside of your truck go ahead and pump Mobile 1 synthetic 1 into them.
  9. May 31, 2009 at 3:44 PM
    #129
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take it easy, Dude. Im not calling anyone stupid. If you dont like it, Dont use it.. I have used about every grease I can think of, and I have never had any issues with the Mobil 1. Everything else I have used in the past has flung out just as bad. Now, Do something to get your heart rate down...
  10. May 31, 2009 at 3:53 PM
    #130
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    I love it when people respond and its called overeaction. Politicians do this until they are called on the carpet then its you are overeacting. Like you should try the Moly guard instead of pushing Mobile 1 synthetic grease. When you do and post some pictures of it then you might keep people from responding.
  11. May 31, 2009 at 4:02 PM
    #131
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    All I wanna know is, WHO WANTS TO GREASE MY SHAFT????
    HAHAHAHAHAHA!
  12. May 31, 2009 at 4:04 PM
    #132
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    Just keep me out of that neighborhood.
  13. May 31, 2009 at 4:42 PM
    #133
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not getting out of the game THAT easy! :)
  14. May 31, 2009 at 4:56 PM
    #134
    gemstar76
    gemstar76 Member
    CO
    TACOMA
    Ok but dont leave me lubed up like that, Hahahah. Chris it appears somewhat like we were having a excess lube problem. I think no matter what grease you use you do need to get some in them joints. Even if it means pumping more than needed. But please clean up the excess so you dont leave a mess.
  15. May 31, 2009 at 9:08 PM
    #135
    DDD
    Derek
    Santa Clarita, CA
    Those pics were taken while I was adding the Mobil 1 Synthetic. This is the first time I have greased the drive shaft. The grease that has sprayed on the underside of the cab was the stock grease. I put 1 pump into the rear 2 fittings, and 3 pumps into the front. Obviously the stock grease had been leaking out of the front u-joint for some time.
  16. Jun 1, 2009 at 4:45 AM
    #136
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I use Lucas Red and Tacky #2, good high temp, high pressure grease. I run heavy equipment and am constantly greasing stuff. Its better to over grease than under grease, especially in a dusty or wet environment
  17. Jun 9, 2009 at 5:35 AM
    #137
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Does anyone have actual pictures of their 2006 drivetrain lube points?
  18. Jun 9, 2009 at 4:14 PM
    #138
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I had a tube of the coastal lube in my grease gun and did all the zerk fittings.(OVER DID IT) Had grease all over the place, so I degreased the areas with a STRONG solution of "PURPLE CLEANER" and it actually broke the paint down a bit, the original paint was dull and pale compared to the areas I didnt clean, so I hit it with some krylon paint, then I thought, grease overspray really doesnt hurt anything, other than cosmetic reasons, the grease actually is a defacto rust preventative, right? I'm not saying lube up your chasis with grease but undercoating is made out of a petrolium base,right? SO don't do what I did, just wipe it off and call the rest rust preventative. BTW, I have since switched to mobil one synthetic red grease. No difference in excess over spray out of the joints, I think a good thing to remember is just grease the fittings and clean up the excess. I think the only true way to see any u-joint wear is to press them out, and the only reason you would do that is if you had a failure, atleast they are not like the u-joints I had on mt 1974 Datsun 260 Z, they were staked in and not a serviceable part, once they broke then tou had to find a new drive shaft, that happened to me. In closing, just grease them with something you like, your truck will reward you for the preventative measures.
  19. Jun 9, 2009 at 8:31 PM
    #139
    DDD
    Derek
    Santa Clarita, CA
    Umm, just go to post #123 in this thread...
  20. Jun 27, 2009 at 9:25 PM
    #140
    Climber
    Climber Well-Known Member
    New Mexico
    09 4x4 Double CabSR-5
    I looked through all the postings here and didn't see a clear answer to this question: if you add grease at the middle fitting on the rear drive shaft, does some of this get through to the slip joint? In other words, is there a grease passage from that middle U-joint to the slip joint, or does one HAVE to disassemble the shaft as described in post number 6? I've got that irritating thud or clunk when I come to a full stop and/or when releasing the brakes. Sounds like lubing the slip joint is the fix.
    Thanks for any guidance.
