Lubricating suspension components?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Dec 21, 2023.
  1. Dec 21, 2023 at 4:26 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    How often or do you guys lubricate your suspension components like lower control arm pivot points etc? To avoid squeaking and binding, rust?
  2. Dec 21, 2023 at 4:27 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I generally just try blast grit out with a hose before it gets too bad
    I only lube my leaf springs if they start squeeking
    Gfenza89[OP] likes this.
  3. Dec 21, 2023 at 4:42 PM
    Gfenza89
    I got some amsoil metal protector spray and sprays the lower control arm bushings, upper control arms, and strut mounts just to keep them in good shape and avoid any squeaks which I know these trucks are known for lol
  4. Dec 21, 2023 at 9:18 PM
    TacoTuesday1
    FL
    better parts have zerk fittings.
    stock parts are either worn or not.
  5. Dec 21, 2023 at 9:32 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Most aftermarket stuff suggest lube after first 500 miles and then every 5k miles after dependant on usage. I usually relube after every trip but my truck is a dedicated trail pig
