Lubrication for a semi auto handgun?
Discussion in 'Guns & Hunting' started by Lane Cypert, Jan 10, 2010.
  1. Jan 10, 2010 at 12:05 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I use Hoppe's oil. After, of course, #9.
  2. Jan 10, 2010 at 12:49 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    CLP or MilTec.
  3. Jan 10, 2010 at 2:52 PM
    Lane Cypert
    Lane Cypert [OP] Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I have been using the Miltec so far and I am impressed with the way it hols up thus far! The past two times at the range it has stayed well lubed after 150+ rounds through my Sigs! I believe all new Sigs come with a sample of Miltec as well! Does anybody else use anything that hasn't been mentioned so far?
  4. Jan 10, 2010 at 3:48 PM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    youll might think im weird, but there isnt a drop of oil/grease on any of my guns.
    i clean them with brake clean, dry them with compressed air and call it a day. i will wipe the outside with silicone wipes to keep any rust away.
    i have never had any malfunctions and they dont appear to wear any worse
    brett
  5. Jan 10, 2010 at 6:11 PM
    nutnfancy
    nutnfancy Well-Known Member
    2017 TRD Off Road
    holling, look who is the know it all now.:D do your research before hand :cool:
  6. Jan 10, 2010 at 6:59 PM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    After a thorough cleaning, my pistols get lubricated with FP-10 and I apply TW25 grease along the slide and frame rails. I also float a single drop of FP-10 over the grease on the slide as well.
  7. Jan 10, 2010 at 7:01 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2
  8. Jan 10, 2010 at 7:09 PM
    Pitt1552
    Pitt1552 Well-Known Member
    PA
    2010 Regular Cab 4x4
    I also use Militec and have had fine results with it.
  9. Jan 10, 2010 at 10:24 PM
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
    My bad................ Sorry:eek:
  10. Jan 11, 2010 at 5:20 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    hoppes, a bore snake, an old toothbrush and a silicone rag
  11. Jan 11, 2010 at 5:22 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I usually use either Rem-oil, or 3-in-1 oil.
  12. Jan 11, 2010 at 5:31 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I use Breakfree CLP on all of my firearms.
  13. Jan 11, 2010 at 5:34 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x3
    I've also used 3in1 oil. Had a friend who swore by Lubriplate on his 1911's.
  14. Jan 11, 2010 at 5:45 AM
    usmcgoose
    usmcgoose One shot is all I need
    Virginia
    05 Tacoma 4X4
    From an armorer perspective with the Marine Corps, it depends on the make of the gun. If the stock is synthetic, CLP and other solvents tend to eat at the polymers in the lower reciever when left on too long. Any oil that is 'safe for synthetic' is what I would recommend going with. Otherwise, the CLP is great (used it for years).
  15. Jan 11, 2010 at 8:46 AM
    #35
    lizard1
    lizard1 Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    I've been using Mobile synthetic 5/30 for years. Soak all firearms in a bucket for 6 hrs. Remove and wipe clean. Wear gloves and face mask to protect self from oil blow back. Just my .02 worth like everyone else. ;)
  16. Jan 11, 2010 at 8:52 AM
    #36
    jason1kyle
    jason1kyle commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    clp works but i prefer rem oil since its easier to use out at the range and i use cle on a daily bases with all sorts of semi autos to full autos
  17. Jan 11, 2010 at 11:55 AM
    #37
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    I've always been told Hoppes by my hunting buddys! They should know they use there guns in the worst conditons possible, out on the ocean hunting Eider Ducks!
  18. Jan 11, 2010 at 2:49 PM
    #38
    Lane Cypert
    Lewisville, Texas
    Do we have any gunsmiths on the forum? I would like to hear their recommendations.
  19. Jan 12, 2010 at 8:55 AM
    #39
    jason1kyle
    JOHNSON CITY, TN
    i've always heard hoppes is good but i've used clp and rem oil in the freezing cold, deserts, rain, and just about anything u can imagine and it always works aslong as u have a clean gun
  20. Jan 12, 2010 at 11:28 AM
    #40
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I use hoppes and rem oil
