Lubrication for a semi auto handgun?
Discussion in 'Guns & Hunting' started by Lane Cypert, Jan 10, 2010.
  1. Jan 12, 2010 at 11:33 AM
    #41
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    Breakfree where it needs oil but tetra grease on the slide and lugs. I love tetra grease it doesn't wear off quickly. I've shot 200 rounds of 9mm in a single range visit and had no problems with a pistol that constantly had issues when I used oil.
  2. Jan 12, 2010 at 11:36 AM
    #42
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    As a firearms instructor and Beretta Certified armorer the best thing I can recommend is Rem Oil. Grease lubricants test to attract more dirt and after time will get caked up. Remove your slide and put a small drop in each of the metal areas where you can see wear. Use it sparingly. Put the slide back on, rack it a couple times and then wipe down the frame with a clean rag.
  3. Jan 12, 2010 at 11:37 AM
    #43
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    CLP and Breakfree are both great! Hoppes 9 is by far the best cleaning solvent on the market...IMO...and it smells great too!
    The only time I ever grease a gun is when it is going to be stored for a LONG period of time. I grease the internals thoroughly and wipe it down with a silicone impregnated rag being extremely careful not to get the oils from my hands back on the gun.
    The down side of greasing a gun is it has to be cleaned and oiled THOROUGHLY before it is fired again.
  4. Jan 12, 2010 at 8:19 PM
    #44
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Miltec is fantastic. After i clean my guns i wipe off the excess miltec and they NEVER get a single spot of rust. Even after a over a year. That is amazing to me. Never happened with any other stuff.
  5. Jan 12, 2010 at 8:26 PM
    #45
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Another vote for Hoppes after Hoppes. A good wipedown, and frequent use...
  6. Jan 12, 2010 at 8:42 PM
    #46
    only49ersfan
    only49ersfan Well-Known Member
    Myrtle Beach, SC
    09 Tacoma 4X4
    Not much. Step bars, K&N air filter
    Hoppe's semi auto to clean and rem oil to lube. Then I use a silicone cloth. I use that combo on my XD-40 sub, ruger P90, ak-47, sks, rem 870, marlin 795...and the rest of them. dont have time to list them all :)
  7. Jan 15, 2010 at 5:32 PM
    #47
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    I have been using castrol motor oil for my pistols and AR15's for the last 10 years. 1qt last forever..:)
  8. Jan 15, 2010 at 5:37 PM
    #48
    Slotback
    Slotback Triple Option
    Texas
    10 PreRunner
    Another +1 Good stuff.
  9. Jan 18, 2010 at 3:03 PM
    #49
    kiddwvman
    kiddwvman Well-Known Member
    leon
    WV
    06 4 banger
    weathertec floor liner,tinted windows,bilstein 5100 front .85,5100'S rear,window vents,K@N air filter
    breakfree clp i had good results with gun butter too
  10. Jan 18, 2010 at 3:16 PM
    #50
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    i typically lubricate my glock with sand after every 5000 rounds. never had a ftf or fte. just kidding i use rem oil on all my guns- long guns, short guns, wheel guns, semi autos and it works like its supposed to.
    buy some big dessicant silica gel packs and put em in your safe or gun case for long term storage.
  11. Jan 19, 2010 at 11:25 PM
    #51
    akcoyklr
    akcoyklr Member
    Paul
    delta junction, alaska
    2000 sr5 v6 tacoma
    None Yet
    Militec-1 , use it up here in alaska cause regular gun oil gums up when it gets cold. Met the owner of the company when i attended the beretta armorer course. rem-oil with teflon second choice.
