Lubrication points under chassis?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Nov 10, 2021.
  1. Nov 10, 2021 at 1:16 PM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    Maybe 2020 was the end of zerks year?
  2. Nov 10, 2021 at 2:04 PM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    2021, no zerks
  3. Nov 10, 2021 at 2:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Wow
  4. Nov 10, 2021 at 3:14 PM
    Chaosh1
    2021 Tacoma TRD Pro
    Yea, i keep telling myself i must be blind or something. i just cant imagine not one
  5. Nov 10, 2021 at 3:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is what it would look like if you had it:
  6. Nov 10, 2021 at 3:36 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    None on my 2020. Owner's manual still shows them as a maintenance item to lube them. You know stealerships are charging people for the work anyway. Has anyone who knows they don't have them and uses the stealership for maintenance (0.0001% of this forum) seeing lubing of prop shafts showing up on the paperwork? If so, gotta question any other maintenance they charge you for.
  7. Nov 10, 2021 at 3:48 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i don't understand why the manual says to lube them if they don't exist
  8. Nov 10, 2021 at 4:24 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same here on my 2020 with no zerks.
  9. Nov 10, 2021 at 5:13 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Late 2017 has 2 on front shaft, 0 on the rear.
  10. Nov 12, 2021 at 8:12 AM
    Dual Port
    Dual Port Active Member
    B. D.
    21 Tacoma Silver V6
    Dealership guys usually don't grease them even when they're present. Big argument about that and failure to check diffs/txcase on my end with bad results.......
  11. Nov 12, 2021 at 9:22 AM
    joncure
    VA
    That sucks. That’s why I was crawling under truck looking for them. I don’t like depending on others to do fairly easy yet often neglected maintenance.
    I have a Jeep CJ7 that has zerks everywhere. Couple that with a slow oil leak and everything under it stays nice and lubed up and rust free!
    Chaosh1 likes this.
  12. Nov 12, 2021 at 3:41 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    The 2016's have a combination of 5 zirks (early 2016, on driveshaft), 3 on driveshaft late 2016, and some later 2016 even zero, so sealed using sealed ujoints.
    Mine is early 2016, 5 zerks. I grease them myself, I do not trust Toyota to do that since the ones after 2016 have no zerks. Note the last point, it might vary year to year. I have not researched every model year.
    Bought my truck used, and when I got it there was very little grease in the u-joints despite it being first serviced by the Toyota dealer. Don't trust that, just grease them yourself until the clean stuff comes out. Works for me for the 4 different 4x4's I have owned the last 35 years.
    My truck is off-road at least 30 times per year, about 3,000 or more off-road miles each year and that is in some pretty harsh remote conditions in BC. I am still on my original u-joints, at 51,000 miles now. I grease them about every 3 months. My off-road driving is mud, horrible washboard roads, roads with thousands of foot deep potholes, and no end of ATV trails and rock climbing like in the pic. Four 4x4's used heavily for off-road, and no lift on any of them. Just slow and easy and measure your routes.
    I have needed to replace front inner bearings, cv axles, and hub assemblies due to the hard roads. The driver side needle bearing tends to fail pretty early on the 3rd gen Taco if you off-road a lot. Mine had over 1/2 inch of play up and down at the front diff when the needle bearing went. Front end wobbled like a drunkard. There is also a more permanent fix for that issue, you can find it here on Tacomaworld.
    I have not greased anything else on my truck, with the exception of the rear leaf springs. During off-road use they get pretty baked in sand and mud and squeak like crazy. There are permanent solutions for that also on TAcomaworld, but I just power spray them off and blast a little WD-40 in between the leafs and the brackets. Works like a charm plus every trip is so harsh that I have my truck up on ramps in my garage inspecting for damage anyway. Simple to clean the leaf springs at that point and grease the u-joints.
    Greg.Brakes.Tacos likes this.
  13. Nov 21, 2021 at 2:12 PM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    @ppat4 Where are these five zerks? And what grease should I use?
  14. Nov 22, 2021 at 7:40 AM
    ppat4
    Paul
    Kelowna, BC
  15. Nov 22, 2021 at 8:48 AM
    #35
    NewMexiMan
    2016 SR 5 Speed
    @ppat4 Thanks, I appreciate it.
